AB Enigma1HD beta for 9хHD 27.10.2009
Viraje
AB Enigma1HD beta for 9xHD - 27.10.2009
Changes:
+ Added start automatically when you run Check Disk Key Up.
+ Updated the setting by Thor 1W and Astra 28.5
+ Fixed Timer recording recording of the indicators signal corrected
+ corrected display Nameserver and gateways in the network settings
+ corrected display the EPG selected CZ CZ or SK
+ added menu display window "recording" on the screen when you start recording
+ Video output added setup wizard when you first start, taken automatically switches between video output pending confirmation.
+ Added display TXT subtitles (closed in the election of the audio tracks) Using 1080 exit can change display font to bigger headlines, but it does not support diacritics (the corrected version of the IALS). To change the font, turn on the teletext akomko you age program, press the MENU button and check the "true type font, exit the menu.
+ Corrected display time for disleji off (91HD) + Added buttons for quick restart frozen (at uni DO 9000HD/910HD buttons
Known Issues
- DVB-C tuner doesnґt work
- works upper CI slot only, after inserting CAM module you have to restart it in menu of box.
After every restarting of box you have to put out CAM from box and put in to box and reset CAM in menu of box.
- DVB subtitles are not working
- installed games donґt work in 720p and 1080i mode. (work in 576i and 576p mode)
- doesnґt work CIFS
- after start playback from HDD, picture breakdown - it is necessary start playback again
- When SHARP tuner is inside box - signal indicators donґt work
Next repairs, which will be solved:
- playback - ts, divx, mpeg
- dvb subtitles
- video scaling for 544x572 4:3
- other known issues
9000
900
910
91
Не обращайте внимания на usb в названии архива, внутри img имэйдж!!![/HIDE][/HIDE][/HIDE][/HIDE]
janigor
Аддон для Е1 от 27.10.2009
  • SF_addon_for_9xxxHD_271009.zip
    10,8 KB · Просмотры: 18
janigor
nikolasi
Игорь-для комби на 99 серию-аддон подойдет для е1 от этой версии?
