DM800HD Clone Patched Images (Sim 2.01 SSL#84D OE2.0)
halfhalf
BlackHole2.1.5.NewSkin.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.21.04.2015
BlackHole2.1.5 New Skin DM800HD CLICK LINK
Openpli4.Apache.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bytexas.22.04.2015
PermanentClock
Flashexpander
navibar
Signalfinder
VlcPlayer
AutoCamSetup
DeviceManager
Satfinder
RAEDinit
cam
cccam_2.3.0-r0
CCcam.channelinfo
CCcam.prio
CCcam.providers
SoftCam .Key
MetropolisHD
Openpli4 Apache DM800HD CLICK LINK
2015 DREAMBOX ALL IMAGES CLICK LINK
2014 DREAMBOX ALL IMAGES CLICK LINK
halfhalf
BlackHole2.1.5.FASTANDSMALL.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.02.05.2015
02/05/2015:
* Skin Default: New Small and Fast Skin Beyonce F1
* ChannelSelection: Fixed go to CurrentService For
- All services
- Satellites
- Provider
* BlackholeAddons Upadated:
- ADD skin armycurvehd
- ADD skin armyghosthd
- ADD skin ghostblackhd
- ADD skin briostdhd
- ADD skin dreamy
- ADD skin rihanna6
- ADD skin rihanna7
- ADD skin rihanna8
- ADD skin factory10
- ADD Plugin IptvList Updater
BlackHole2.1.5.FASTANDSMALL DM800HD CLICK LINK
halfhalf
BlackHole.2.1.6.OPERA.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.28.05.2015
28/05/2015: New Enigma2 Compiled 28-05-2015
Skin Default: Beyonce F1 Updated
Add option for record indication in service list
Todo: alternative services and possibly different ways to indicate if a service is currently recorded
Also check in alternatives (groups) when they are recorded in servicelist
And make the check a separate function that possibly can also be called from python
- ADD Plugin OpenOpera V1.0 MOD Raed
BlackHole.2.1.6.OPERA DM800HD CLONE
APRIL 2015 DREAMBOX IMAGES
2015 ALL IMAGES DREAMBOX
2014 ALL IMAGES DREAMBOX
halfhalf
BlackHole.2.1.6.UPDATE.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.04.06.2015
04/06/2015: *New Enigma2 Compiled 04-06-2015
* ParentalControl: add advance protection for:
- you can Protect MainMenu
- you can Protect Configuration
- you can Protect movieList
- you can Protect Plugin Browder
- you can Protect Standby Menu
* Subtitle Settings: ADD More Option
- Teletext Subtitle Color
- Rewrap Teletext Subtitles
- Subtitle Position
- Subtitle alignement
- Subtitle border width
- Subtitle font size
- Subtitle delay when timing lacks
- Use DVB subtitles position
- Subtitle delay when timing is bad
- Delay foe external subtitles
* MovieList Fixed:
- After Recording you can see all Movies without Pressing on Menu
BlackHole.2.1.6 UPDATE DM800HD CLONE
halfhalf
BlackHole2.1.6.NewFIX.DM800HD.CLONE.SIM2.OE2.0.bymarwen.SSL84D.12.06.2015
12/06/2015: New Enigma2 Compiled
* skin_default Beyonce F1: Add Transparency for infobar and Secondinfobar
* Satfinder / Automatic scan / Manual scan: Add
transponder scan to Satfinder plugin, add related visual
buttons for "OK"- and "Cancel"-functions to all above
* Make services after the serviceScan selectable
* Add option "Network scan" yes/no for Automatic scan
If not, it is much less time to scan
BlackHole2.1.6.NewFIX DM800HD CLONE
MAY 2015 DREAMBOX IMAGES
halfhalf
BlackHole.2.1.6.JUNE.END.FIX.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.26.06.2015
26/06/2015: - New Enigma2 Compiled 26-06-2015
-Enigma2: Fix New Patch for Picon and you can use all picon sizes
-Renderer Picon Patched
-Add parental protection on EPG information
-Add buffer status indication when starting webstreams
-httpstream: you can record a http stream
-Picload :Fix Memory leak and file handle leak fix
-gpixmap.cpp: Don't use broken hardware alphablending
It is also the reason why a transparent picon will occur
as a "hole in the UI" instead of just being invisible
BlackHole.2.1.6 JUNE.END.FIX DM800HD CLONE
halfhalf
BlackHole.2.1.7.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.12.07.2015
12/07/2015: * New Enigma2 Compiled 12-07-2015
*Add new feature for old style remote controlling
When enabled you now have the Neutrino way of remote control:
-Enable 'neutrino' style zap controlling:
When enabled the arrow buttons around the OK button
will follow the 'neutrino' style zap controls instead of the enigma2 style
-Enable 'neutrino' style channel select controlling:
When enabled the left, right, CH+/-, B+/-, P+/- buttons
*Make reverse bouquet buttons configurable
*Allow plugins to recursivaly close via menus
*MultiContent: Add flag to make it possible to scale pixmaps
*downloadWithProgress: support https with connectSSL
Downloading https page fails with "Connection was closed cleanly"
because downloadWithProgress uses connectTCP instead of connectSSL.
Using connectSSL for https solves the problem
Old Style zap Neutrino
Remote Control for
keymap.xml
/usr/Share/enigma2
BlackHole.2.1.7 DM800HD CLONE
halfhalf
halfhalf
BlackHole.2.1.7.NEWFIX.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.21.08.2015
21/08/2015:* New Enigma2 Compiled 21/08/2015
*skin_default: fantasy_hd updated
*Now usb keyboard Fixed for Blackhole
* rcinput et al: Implement hotplugging input devices
Add an interface to add/remove devices. Add a netlink socket to
listen for incoming hotplug events and (un)register input
devices.
Now you can (un)plug a keyboard while E2 is running.
* Network: Allow hotplug for network adapters
This allows to insert (e.g.) a WiFi stick while E2 is running. The
adapter will then be visible in the network menu.
*sanity check for fallback service when is wrong service reference in bouquet
*keymap.xml Fixed for InputAsciiActions
*Prevent plugins from crashing enigma at startup
*instantiateSummaryDialog allowing summaries to be created for non-modal screens
*Encoding.conf fixed for Thor 0.8W and Remove UPC-Direct Astra-1 transponder
BlackHole.2.1.7.NEW.FIX DM800HD CLONE
http://link.im/a9xoO3
halfhalf
BlackHole.2.1.7.September.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.07.09.2015
07/09/2015: New Enigma2 Compiled 07/09/2015
* BlackholeAddons: updated
* ADD New Patch for Teletext:
-Allow users to change key mapping via keymap.xml. As a result of it
volume and mute is working when teletext is visible
-Press Txt to open Teletext
-Press Menu to open Teletext Menu
* ADD Drivers for Usb keyboard: you can Plug your usb keyboard and Reboot dreambox
-kernel-module-usbhid
-kernel-module-usbserial
* ADD Arabic Language to VirtualKeyBoard
* ADD Azerty Keyboard
* Keyboard: use default.kmap by default
* Hotplug: updated
* InfobarPosition Fixed Crash: ADD Universe
* FixedMenu: Fix GS when trying to access a invalid Tuple
BlackHole.2.1.7. September DM800HD CLONE
DREAMBOX ALL IMAGES 2014 - 2015
halfhalf
BlackHole.2.1.7.ENDFIX.DM800HD.CLONE.SSL84D.SIM2.OE2.0.bymarwen.27.10.2015
* New Enigma2 Compiled 27/10/2015
* BlackholeAddons V1.5 updated
* Skin.py Fixed by RAED : Now Blackhole Adapted to openpli Skins
* New Fix for gstreamer-0.10
* Add cursor functionality to Virtual Keyboard
* VirtualKeyBoard: Add SMS input
* VirtualKeyboard skineable
* ADD Arabic Language to NumericalTextInput
* skin_display.xml Patched
* ADD skin_subtitles.xml
* picload: fix parsing the background color.
Transparancy was not taken into account when parsing
background color string in setPara().
Thanks Rob for reporting.
BlackHole.2.1.7. ENDFIX DM800HD CLONE
halfhalf
OpenPLi.4.0.Gstreamer1.7.0.DM800HD.CLONE.SSL84D.SIM2.OE2.0.byhoura.25.12.2015
Changes since previous release:
- mx3L's gstreamer revert which fixes mp4 playback from remote locations
- Spark drivers updated to 20151113
- Using aio-grab from oe-alliance which includes fixes for sprak receivers
- New Japhar IPTV List (thanks to ToySoft).
- Removed the linux 2.6.18 kernel patch for ignoring the vermagic as it might be the cause of some instabilities.
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
By mx3L which fixes mp4 playback from remote locations.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cd[​IMG]tinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support
- Spark images includes the pti.ko from OpenATV so softcam's should work now.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
- On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
Because sometimes it doesn't scale back to fullscreen.
I've included the MX-HQ7 skin for use as workaround.
- On Zgemma Star you cannot use fullHD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well
OpenPLi.4.0.Gstreamer1.7.0 DM800HD CLONE
halfhalf
