Имиджи для AB IPBox 9000HD
DZOI
Kinoshnik
SifTeam r9207
Обе ссылки мёртвые :(
Если кто успел скачать-выложите пожалуйста на рапиду или ещё куди нибудь
chewbacca
Модератор "AzBox"
DGStation/Abcom CubeRevo Series nlb svn9207 v1.31
WEBIF
login: root
password: relook
Prepared by : Dexter
Release date : April 4. 2009
Changes:
* updated - Using DGStation release SVN9207
* emu - added - Hypercam 1.1
* emu - added - replace.list config for german provider support
* webif - new carddriver change between dgstation and custom driver, if issues are found.
* skins - deepblue, grey and blue updated to r9207.
http://rapidshare.com/files/217364694/nlb9207.zip
nikomar
AB_9000HD_r9207_060409_usb_all_noboot.zip
AB_9000HD_r9207DRE_060409_usb_all_noboot.zip
1. Add russian (cyrilic) translate to latin letters for front display (thanks for Janigor for your help) 2. Fixed : Channels with nonstandard characters in name , e.g. "+" show on display as channel number only. Note 1. Files "...r9207DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!! Known issues(on going). 1. Artefact with Premiere HD channels from satellite or cable. Caution. 1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10". 2. You have to change the name of updated sw into "usb update.img" when you upgrade the sw by the USB memory stick.
http://download.abcom.sk/index.php?&direction=0&order=&directory=02 AB IPBOX HD/08 9000HD_Images
AB 9341
AB r9341 30.04.2009
Change log:
1. Added automatical services moving when PMT_PID is changed on channel.
2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
3. Fixed the bugs that doen't display TTXT on the specific page.
The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
- Press “1” : Jump to 10% of the recorded file
- Press “2” : Jump to 20% of the recorded file
- Press “3” : Jump to 30% of the recorded file …………
- Press “0” : Jump to beginning of the recorded file
6. Updated Russian language.
7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!!
4x6hp
r9341 from ABCOM
DRE
non DRE
[/HIDE]
janigor
аддон для 9000
SF addon rel 30.04.2009 for image r9341
Change log:
- update setting, add 1W to DiSEqC position D
- update database version
webif and ftp access: root/ipbox
SF addon rel 30.04.2009 with SifTeam addon included for image r9341
SF addon with complete installation of SifTeam panel.
Thanks to SifTeam and ab-forum creators for your work ( www.ab-forum.info )
Change log:
- add 2 tuner descramble from cards and share (for config use newcamd.list files in var/keys)
- red button - fav pip plugin start
- green button - SifTeam panel start
- yellow button - video zoom mode change (3 modes)
- Automatic key update (you can change in /var/etc/SifTeam/conf/crontab)
- Online content download (plugins, settings...)from SifTeam server
- many next adds :)
[/HIDE]
4x6hp
r9341 from DGS
Image release: NLB-9341-v1.320
WEBIF
login: root
password: relook
Release date : May 3. 2009
Changes:
* updated - Based on DGStation SVN9341
* emu - updated - Hypercam 1.03
* emu - updated - IncubugCamd 0.82
* emu - updated - mbox 0.5 Build 08
* carddriver- updated pacco carddriver 090502.
* skins - deepblue, grey and blue updated to r9341.
* plugins - updated - favpip v2.1.1
* plugins - updated - bitrate 0.0.6
* plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
* newcs - removed cardlevel from all config files. (seems to cause problems)
barsuk72
DGS release r9580:
( 29/May/2009)
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 250-hd in filebrowser
6. Change hdd clean process on hddinit script
7. Syunchronized sleep Mode as power_control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update tp information Thor0.8W and Astra 19.2E
10. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Caution.
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
http://dev.dgstation.co.kr/release/cuberevo/cuberevo_r9580.292050.zip
barsuk72
AB 9000HD r9580 290509 usb all noboot
5. Mapping blue key as check key for 91HD in filebrowser
6. Change HDD clean process on hddinit script
9. Update TP information Thor0.8W and Astra 19.2E
Note.
Caution.
http://rapidshare.com/files/242691998/AB_9000HD_r9580_290509_usb_all_noboot.zip.html
chewbacca
Модератор "AzBox"
nlb9580_9000HD_release
DGStation/Abcom CubeRevo Series nlb svn9580
Unofficial Custom release - no limits board --> http://www.nlb.to/board
WEB-IF
login: root
password: relook
Image release: NLB-9580
Prepared by : Rainman
Release date : June 18. 2009
Changes:
* updated - Based on DGStation SVN9580
* emu - updated - IncubusCamd 0.85
* emu - updated - mbox 0.6 Build 0006
* skins - only original skin, other skins removed ...only "cool"-skin working !
* satangels keyupdater included
Thanx to my friend Dexter for getting me started in building images !
Thanx also to all the beta-testers, especially to Minicat for testing my very first beta :cheesy
http://rapidshare.com/files/246014043/nlb9580_9000.zip
