Имиджи для AB IPBox 91HD
nikomar
NLB9341 for all 91/900/910Image release: NLB-9341-v1.320
Prepared by : Dexter
Release date : May 3. 2009
Changes:
* updated - Based on DGStation SVN9341
* emu - updated - Hypercam 1.03
* emu - updated - IncubugCamd 0.82
* emu - updated - mbox 0.5 Build 08
* carddriver- updated pacco carddriver 090502.
* skins - deepblue, grey and blue updated to r9341.
* plugins - updated - favpip v2.1.1
* plugins - updated - bitrate 0.0.6
* plugins - fancontrol 0.1 (change config to /var/etc/fancontrol.config to activate)
* newcs - removed cardlevel from all config files. (seems to cause problems)
http://rapidshare.com/files/228692728/nlb9341-250.zip
nikomar
AB_91HD_r9580_290509_
AB_91HD_r9580_290509_usb_all_noboot.zip
1. Added automatical services moving when PMT PID is changed on channel. 2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642. 3. Fixed the bugs that doen't display TTXT on the specific page. The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V 4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2) Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2) 5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below. - Press “1” : Jump to 10% of the recorded file - Press “2” : Jump to 20% of the recorded file - Press “3” : Jump to 30% of the recorded file ………… - Press “0” : Jump to beginning of the recorded file 6. Updated Russian language. 7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later. Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!
http://download.abcom.sk/index.php?&direction=0&order=&directory=02 AB IPBOX HD/11 91HD_Images
Lowik
Вышла новая DGS-прошивка r10336
Image version : r10336
DB version : r9274
http://dev.dgstation.co.kr/release/cuberevo-250HD/cuberevo-250HD_r10336.080131.zip
This README is for CubeRevo HD model series.
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a format that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom service and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
3. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
2. The timeshift function of multiroom will release on the next.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one.
nikomar
SifTeam 0.3.0 r10513
Changelog DGS:
DGS release r10513: ( 21/Aug/2009)
1. Fixed a few bugs for Post-Descramble
2. Return to previous method that select subtitle language in Language settings Menu
3. Fixed some bugs for Multiroom Service.
Protocol for mutiroom service is changed from this version. So, older SW(r10427) is not compatible with this SW(r10513).
Changelog SifTeam:
SifTeam-0.3.0
From this release I add DGS Multiboot options *
From default start without check or format HardDisk (requested) **
Is possible don't start any Service at startup ***
Personalized SAMBA and NFSD config ****
Any change in panel
* Press number button which you want on RCU when start decoder.
Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
** Remove file:
/var/etc/.dont_format_hdd
/var/etc/.dont_check_hdd
..and return as default system
*** Make file:
/var/etc/.dont_start_samba If present, at startup don't start samba
/var/etc/.dont_start_nfsd If present, at startup don't start nfsd
/var/etc/.dont_start_httpd If present, at startup don't start httpd
/var/etc/.dont_mount_usb If present, at startup don't mount usb
/var/etc/.dont_start_vsftpd If present, at startup don't start vsftpd
**** Make directory:
/media/ENIGMA1/movie
From other decoder with enigma1 firmware (for example SifTeam Firmware)
Add this command for share disk with samba:
smbmount "//192.168.1.9/ENIGMA1" -U root -c 'mount /hdd/ -u 500 -g 100'
Add this command for share disk with nfs:
mount -t nfs -o nolock,nfsvers=2,rsize=8192,wsize=8192,proto=tcp 192.168.1.9:/media/ENIGMA1 /hdd
192.168.1.9 is IP of IPBOXHD shared disk, ..change with your IP!!
In all Sifteam Firmware is possible add this command at bottom of file /var/etc/rcS.d/S99user_start.sh
and automount at startup.
http://dreambox.sifteam.eu/index.php?dir=9000HD/r10513/
utel09
nlb10513_91hd_27092009.img
P.S. Для вложения большой файл...[/HIDE]
janigor
DGS release r11102: ( 18/Oct/2009)
1. Improved sync of dvb-subtitle .
- if correct PTS from the stream, no problem
But if wrong or missing PTS data from the stream, it possible to time difference with A/V and subtitle.
2. Changed concept for Streaming Player function
- watching one channel, another channel streaming independantly
3. Added unicable function on LNB type of satellite configuration menu as C, Ku, UNIV, Unicable
- Caution : At this moment ,you have to install unicable for each of tuner because it is not supported both tuner 1,2 in one menu at the same time
4. Improved visibility of menu font
5. Small many bugs fixed
http://dev.dgstation.co.kr/release/cuberevo-250HD/cuberevo-250HD_r11102.181320.zip
SiFteam
http://dreambox.sifteam.eu/index.php?dir=9000HD/r11102/&file=250-usb_update.tar.gz
12ALI1974
SF addons for AB/DGS images-IPBox91HD
vom 19.10.09
Change log:
File desciption:
SF addon for AB IPBox 9X0HD
  • usb_db_ipbox91_ab_20091019.rar
    3,1 MB · Просмотры: 119
