/usr/local/src#apt-get install mercurial libncurses-dev
/usr/local/src#hg clone http://jusst.de/hg/multiproto
/usr/local/src#cd multiproto/
на всякий случай
/usr/local/src/multiproto# cd /lib/modules/
/lib/modules# cp -a 2.6.22-14-generic 2.6.22-14-generic.backup
/lib/modules#cd /usr/local/src/multiproto
/usr/src/multiproto# make
/usr/src/multiproto# make install
/usr/src/multiproto# depmod -a
/usr/src/multiproto# modprobe stb6100
/usr/src/multiproto# modprobe stb0899
/usr/src/multiproto# modprobe lnbp21
/usr/src/multiproto# modprobe budget-ci
/usr/src/multiproto# dmesg
карточка встала
[ 4084.208000] saa7146: register extension 'budget_ci dvb'.
[ 4084.208000] ACPI: PCI Interrupt 0000:04:09.0[A] -> GSI 22 (level, low) -> IRQ 20
[ 4084.208000] saa7146: found saa7146 @ mem f8ace400 (revision 1, irq 20) (0x13c2,0x1019).
[ 4084.208000] saa7146 (0): dma buffer size 192512
[ 4084.208000] DVB: registering new adapter (TT-Budget S2-3200 PCI).
[ 4084.244000] adapter has MAC addr = 00:d0:5c:68:13:57
[ 4084.244000] input: Budget-CI dvb ir receiver saa7146 (0) as /class/input/input6
[ 4084.556000] stb0899_write_regs [0xf1b6]: 02
[ 4084.556000] stb0899_write_regs [0xf1c2]: 00
[ 4084.556000] stb0899_write_regs [0xf1c3]: 00
[ 4084.556000] _stb0899_read_reg: Reg=[0xf000], data=82
[ 4084.556000] stb0899_get_dev_id: ID reg=[0x82]
[ 4084.556000] stb0899_get_dev_id: Device ID=[8], Release=[2]
[ 4084.556000] _stb0899_read_s2reg Device=[0xf3fc], Base address=[0x00000400], Offset=[0xf334], Data=[0x444d4431]
[ 4084.556000] _stb0899_read_s2reg Device=[0xf3fc], Base address=[0x00000400], Offset=[0xf33c], Data=[0x00000001]
[ 4084.556000] stb0899_get_dev_id: Demodulator Core ID=[DMD1], Version=[1]
[ 4084.556000] _stb0899_read_s2reg Device=[0xfafc], Base address=[0x00000800], Offset=[0xfa2c], Data=[0x46454331]
[ 4084.560000] _stb0899_read_s2reg Device=[0xfafc], Base address=[0x00000800], Offset=[0xfa34], Data=[0x00000001]
[ 4084.560000] stb0899_get_dev_id: FEC Core ID=[FEC1], Version=[1]
[ 4084.560000] stb0899_attach: Attaching STB0899
[ 4084.560000] stb6100_attach: Attaching STB6100
[ 4084.560000] DVB: registering frontend 0 (STB0899 Multistandard)...
root@mythtv:~# ls -l /dev/dvb/adapter0/
total 0
crw-rw---- 1 root video 212, 4 2008-01-30 11:38 demux0
crw-rw---- 1 root video 212, 5 2008-01-30 11:38 dvr0
crw-rw---- 1 root video 212, 3 2008-01-30 11:38 frontend0
crw-rw---- 1 root video 212, 7 2008-01-30 11:38 net0
