Полезные сочетания клавиш для IpBox 900/9000 HD
seal
Администраторы
Quick keys for CubeRevo/Mini IPBox 9000/900HD
1. USB (host) memory stick download mode : press and hold power button on the front panel, and press upper direction arrow() button at the same time on cold off mode. It displays “USB UPGRADE”, and then run automatically.
Note : usb_noboot.img, usb_kernel_root.img or usb_db.img should be renamed to usb_update.img for new software update, and copy the renamed file to USB memory stick.
2. Shutdown by force : power button + OK.
3. TV resolution adjustment : press and hold power button on the front panel, and press menu button at the same time on cold off mode
4. Serial upgrade mode : press and hold power button on the front panel, and press right direction arrow button at the same time on cold off mode
5. HDD format by force : press and hold power button on the front panel, and press downward direction arrow button at the same time on cold off mode.
6. Network upgrade for factory : press and hold power button on the front panel, and press left direction arrow button at the same time on cold off mode, it is for bulk downloading method in Factory side, not for users
7. USB(client) download mode : press power button and hold until “USB UPGRADE” appears on the front display
seal
Администраторы
Тем у кого не получается начать прошивку с флэшки стандартным способом вот такой совет:
make a partion FAT16
after do not rename the image file like how ABcom says ""usb_update.img""
just send the "usb_update" file to usb stick...
power of the receiver insert the usb stick power on ...after let the stb boot as normal wait for the menu or channel comes on the tv screen
power+ok
then
power+up key on the stb
image upload start in few min...
janigor
Быстрые клавиши для AB IPBOX 900HD/9000HD
ВАЖНО!!!
На вашем приемнике должен быть установлен загрузчик версии 1.3.1 (190508) или новее.
1. Обновление софта с помощью USB-флеши (host):
- сохраните важные данные с USB-флеши перед использованием ее для обновления софта.
Затем удалите все данные с USB-флеши.
- скопируйте имидж для usb обновления на USB-флеш и переименуйте его на: usb_update.img
- выполните "Безопасное извлечение устройства" на компьютере. Используйте иконку в правом нижнем углу экрана.
- выключите приемник (нажмите кнопки ВКЛ. + ОК на лицевой панели) и вставьте в него USB-флеш.
- нажмите и удерживайте кнопку ВКЛ., пока на дисплее приемника не появится
"BOOTING" и нажмите стрелку ВВЕРХ (на лицевой панели, не на ДУ, после этого на дисплее приемника появится сообщение "USB UPGRADE".
- загрузчик начнет обновление софта на софт, который содержится в файле usb_update.img с USB-флеши.
- Дождитесь пока не появится сообщение DONE на дисплее приемника. Перегрузите приемник.
2. Быстрое выключение : нажмите кнопки ВКЛ. + ОК на лицевой панели
3. Изменение разрешения ТВ изображения : нажмите и удерживайте кнопку ВКЛ. на лицевой панели и одновременно нажмите кнопку МЕНЮ, когда приемник находится в "холодном" стендбае.
4. Переход в режим обновления через серийный порт : нажмите и удерживайте кнопку ВКЛ. на лицевой панели и одновременно нажмите стрелку ВПРАВО, когда приемник находится в "холодном" стендбае.
5. Принудительное форматирование HDD : нажмите и удерживайте кнопку ВКЛ. на лицевой панели и одновременно нажмите стрелку ВНИЗ, когда приемник находится в "холодном" стендбае.
6. Переход в режим USB(client) загрузки софта : нажмите и удерживайте кнопку ВКЛ. на лицевой панели пока на дисплее не появится "USB UPGRADE"
