ukrosat
AAF Multimedia Edition UFS910 Flash
Image Info
http://www.aaf-board.com/wbb2/thread.php?threadid=59795&page=1
AAF Enigma2 MultiMedia Edition (Image 25) Changelog:
SH4 Duckbox Projekt:
+ Libeplayer3 (besseres Streaming Verhalten/mehr Stabilität bei Wiedergabe)
+ Better performance when jumping through recordings during playback
+ fix dma bug
+ Fixed sporadic hangs during playback also in Diff4
+ bugfix from Schischu regarding hanging while loop
+ fix help menu and softwaremanager
+ fix unknown mp3 audio selection
+ Fixed GS when Teletext is invoked an no tuner is configured
+ [ffmpeg] add videoshoot support and convert jpg > mvi support
+ [ufs912/atevio7000] merge stv090x; ORF bugfix
+ fix a bug in libeplayer3 handling
+[ufs922] evremote2 --> must fix epg_key
+ [evremote2] Change atevio7000 handling
+[nuvoton] now uses irq instead of polling
+ [micom] bugfix
+ [ufs912, 922] micom now uses irq to receive fp events. longkeypress support
+ [evremote2] enable longkeypress for Atevio7000
+ [ufs912] fix avi reboot bug
+ [ufs912] Tunertreiber aktualisiert
AAF:
+ Overclock/Übertakten (außer UFS-912)
+ fix PIP zoom
+ PluginBrowser Preview Support (standard)
+ Cardreader Support (at700/7000)
+ AafPanel Icon Support
MediaCenter Update:
VideoPlayer:
+ Cover Ansicht (4x3 cover like Xbox Xbmc)
+ Fullcover Ansicht (like ProjektVallery)
+ Cover/imdb download von Imdb/TheMovieDbProvider/TheTvDbProvider/Mtv integriert
+ Cover und infos fuer Filme/Serien/Musikvideos
+ Automatisches Update der IMdb Daten moeglich
+ Special Folder support fuer Cover Ansicht (Ordner mit Serien/Section Bilder like Xbox Xbmc)
+ Random (Shuffle Support)
+ Verbesserte Steuerung
+ Apple Movie Trailer (außer TF7700)
+ MyVideo Player
PicturePlayer:
AudioPlayer:
+ Screensaver (Title Text)
+ Screensaver (PNG1)
+ Screensaver (PNG2)
+ Screensaver (MVI SAVER)
+ Screensaver (MVI IMDB)
Webinterface Update:
Webinterface auf version 1.6.2 upgraded
+ add AAF-Panel
AAF-Panel:
+ add SoftcamPanel
+ add FlashUpdate
+ add Backup&Restore
+ add ImageInfo
+ add OverClock over WebIF (bis auf UFS-912)
+ Screenshot Video und ALL
Видео с ютуба:
http://www.youtube.com/watch?v=zA06V9rbS2o
alex1059
Не знаю у кого как, но у меня при установке во внутрь энигма запускается только при первичной настройке, а потом никак не хочет запускаться. Вроде стартует, доходит до надписи на дисплее и все. Сброс и все по новой. На флешку эта энигма стала без проблем и все работает. Если у кого-нибудь такие-же грабли, отпишитесь.
ukrosat
У меня после установки вообще не запустилась энигма..после повторной установки (переименовав в miniFLASH.img.) работает нормально..кстате..плагин ютуб работает очень неплохо..
sharapov23
Имедж прикольный!всяких крошечек сочинили видео по моему видео осталось прежним(дрова как были так и выбросим)Ставится через MPI хорошо проблем нет.(катя немец)
alex1059
Все разобрался. Оказывается не со всеми скинами работает эта энигма. Если оставить скин по умолчанию, то все нормально. Кто-то пробовал другой скин?
ukrosat
У меня стоит по умолчанию..а какой лучше него?
Меня всё в нём устраивает,кроме возможности смотреть и название фильма (епг) и его краткое описание,причём на каналах Платформы описание слева имеется с кратким анонсом фильма..
Такая возможность имеется в имидже РКТ последем для юзб,но там не изменяется количество каналов в общем списке в отличии от этого имиджа..
VlaSky
В этом имидже питон открытый, так что можно редактировать или добавлять своё.
Например, закидываем вот этот файлик и епг отображается на всех каналах полностью.
Закидываем в каталог /usr/lib/enigma2/python/Components/Converter/ файл EventName.py из этого архива. И перезагружаемся (можно только GUI). Всё.
  • EventName.rar
    492 байт · Просмотры: 119
Yuriksat
Проверьте, пожалуйста, есть ли этот имидж в AAF Panel-System-Flash Online Update
Спасибо!
VlaSky
Со скинами всё в порядке. Попробовал один скачал, второй поставил свой переделаный
оба нормально работают.
Добавлено через 21 час 53 минуты
Кто пробовал разгонять проц, офигенно летает!
И загружается быстрей, и файлы тянет на которых раньше еле пыхтел.
Только ставьте 366 на 400 мегагерцах сам загибоется.
alex1059
Это как. Поясни пож.
VlaSky
AAF-панель - Настройка - OverClock
1 разгонять только при загрузке
2 выставляем частоту
3 сам не понял
4 уменьшаем частоту в ждущем режиме
Я думаю на проц куллер обязательно надо ставить, а то не дай бог накроется.
У меня он стоит и дует прямо на процессор.
slatka
Как в этом имидже переключать звуковые потоки? Желтая кнопка не работает.
sergejzik
сначало зелённая- потом жёлтая и там всё увидишь
VlaSky
Да всё нормально, пробуй, только 400 я думаю многовато.
LMik
Вроде бегает.
Теперь следующая проблема - почему-то совсем мало места, с установленным mgcamd и руссификацией не хватает на скин dreamtvHD. Ужось :(, видимо придется ставить на УСБ флеш.
VlaSky
Закидывай всё на свап флешку и будет всё нормально.
