Lenina
Куратор "IPBox"
AAF MULTIMEDIA V2 for Ipbox 9000 HD
24/02/2011
GIT 1852
- New Player Engine STM Havana Player 179
- Fix bug STM23 MAC
- Fix fast rewind
- disable unneeded processes 2
- [Libeplayer3] ogg / flac playback
- [libeplayer3] some changes regarding playback flushing after playthrough
- Kartenleser Treiber
- [libeplayer3]decrease debug level due to some performance problems
- [libeplayer3] fix blocking at end of file
- stm23 add ftdi_sio (Unterstützung für externe Kartenleser wie Smargo)
AAF M5873:
- enable libsmbclient
- VideoPlayer fix play same file after eof
- Tuner Treiber update
- Frontpanel Treiber Update
- Online Update Funktion
- kleinere fixes
- [mc] pictureplayer add mp3 support on slideshow
- channel list to a new look
Known bugs / Open issues:
- radio background image is not in the moment
- stream the webinterface without function
DOWNLOAD FLASH 9000 IMAGE http://www.sat-universe.com/redirec...ltiMedia_Edition_IP-Box9000_Flash_V2.rar.html
DOWNLOAD USB 9000 IMAGE http://www.sat-universe.com/redirec...MultiMedia_Edition_IP-Box9000_USB_V2.rar.html
DOWNLOAD UPDATE 9000 USB http://www.sat-universe.com/redirec...edia_Edition_IP-Box9000_UPDATEUSB_V2.rar.html
DOWNLOAD FULLUSB 9000 IMAGE http://www.sat-universe.com/redirec...iMedia_Edition_IP-Box9000_FullUSB_V2.rar.html
Download AAF_MultiMedia_Edition_IP-Box900_FullUSB_V2 http://www.sat-universe.com/redirec...F_MultiMedia_Edition_IP-Box900_FullUSB_V2.rar
Download AAF_MultiMedia_Edition_IP-Box900_USB_V2 http://www.sat-universe.com/redirec...e/AAF_MultiMedia_Edition_IP-Box900_USB_V2.rar
Download AAF_MultiMedia_Edition_IP-Box900_Flash_V2 http://www.sat-universe.com/redirec...AAF_MultiMedia_Edition_IP-Box900_Flash_V2.rar
Download AAF_MultiMedia_Edition_IP-Box900_UPDATEUSB_V2 http://www.sat-universe.com/redirec...MultiMedia_Edition_IP-Box900_UPDATEUSB_V2.rar
Download AAF_MultiMedia_Edition_IP-Box910_FullUSB_V2 http://www.sat-universe.com/redirec...F_MultiMedia_Edition_IP-Box910_FullUSB_V2.rar
Download AAF_MultiMedia_Edition_IP-Box910_USB_V2 http://www.sat-universe.com/redirec...e/AAF_MultiMedia_Edition_IP-Box910_USB_V2.rar
Download AAF_MultiMedia_Edition_IP-Box910_Flash_V2 http://www.sat-universe.com/redirec...AAF_MultiMedia_Edition_IP-Box910_Flash_V2.rar
Download AAF_MultiMedia_Edition_IP-Box910_UPDATEUSB_V2 http://www.sat-universe.com/redirec...MultiMedia_Edition_IP-Box910_UPDATEUSB_V2.rar
Форум разработчика http://www.aaf-digital.info/forum/downloads.php?do=cat&id=40
ivanko
Здесь можно увидеть картинку.--http://www.forokeys.com/foro/images-e1-and-e2-for-all-model/aaf-mme-v2-ipbox-9000-900-910-91-hd/msg266184/
iscan_adm
снег на ней есть?
или только тидегло пока снег поборол?
ток не надо рассказывать что и на предыдущей ааф его небыло, тк там он проверенно был
Lenina
Куратор "IPBox"
снег на ней есть?
Снег не успел проверить. Первым делом проверил включение таймшифта, и на ней он тоже с третьего раза на 9000 включается. Дальше проверять не стал, т.к. таймшифт для меня очень важная функция. Завтра если никто не ответит здесь, тогда сам проверю днем.
ivanko
ipbox910hd- konexsat. Enigma2 AAF уже больше года и пишу ответственно-. не было снега. При грозе или снегопаде-когда сигнал меньше 30-то рвёт картинку...и зелени тоже не видел
nikolasi
Не то...переключитесь на хд канал который по шаре идет и вытяньте шнур со штекера тот что на интернет идет и подождите минут 30-без нета.Если картинка не перейдет в сплошную рябь или тюнер не повешаетса-тогда нормально.А так вы его редко словите а если шаровик нормальный-то почти всегда будет гуд...Италяшки написали что скай хд так и глючит дальше....
Lenina
Куратор "IPBox"
снег на ней есть?
На 9000 HD-Кино (+++) 50 минут без сети - в результате рес завис намертво и на кнопки пульта не реагировал. Разумеется подключение к сети его не реанимировало. Перегружал кнопкой сзади. Снега не появилось, но это его признаки, еще бы больше ждал, наверняка бы выпал.
vig74
HD+++ минут 10 без инета, снег не выпал(чтоб картинка стартанула пришлось переключиться с канала на канал), отключил тарелку минут на 10(подключил картинка пошла). В медиацентре на авишках пауза и перемотка работает(нет перемотки на заданое время). Таймшифт с 3 раза(воспроизведение стартует плавно).
З.Ы. Как-бы не плохо, но после INDB не удобно и не привычно.
tarik888
Снег пока не побороли
ivanko
Форумчане-прошу-помогите. Не разархируется Е2. При том предыдущая от 24.12.2010-нормально,а также последние Баракуды тоже без проблем. Что делать?----------- Command (m for help): p
Disk /dev/sda: 1998 MB, 1998631936 bytes
255 heads, 63 sectors/track, 242 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 188 1510078+ 83 Linux
/dev/sda2 189 242 433755 82 Linux swap / Solaris
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
[SifTeam]$ umount /dev/sda1
umount: /dev/sda1: not mounted
[SifTeam]$ mkfs.ext2 /dev/sda1
mke2fs 1.38 (30-Jun-2005)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
188928 inodes, 377519 blocks
18875 blocks (5.00%) reserved for the super user
First data block=0
12 block groups
32768 blocks per group, 32768 fragments per group
15744 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 30 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
[SifTeam]$ mount /dev/sda1 /mnt/usb
[SifTeam]$ cd /mnt/usb
[SifTeam]$ ls
AAF_M5873_g1852_ipbox910_update_enigma2_p41_P179_USBFULL_nodebug.tar.gz
lost+found
[SifTeam]$ tar -xzvf AAF_M5873_g1852_ipbox910_update_enigma2_p41_p179_USBFULL_no
debug.tar.gz
tar: AAF_M5873_g1852_ipbox910_update_enigma2_p41_p179_USBFULL_nodebug.tar.gz: No
such file or directory
[SifTeam]$
vig74
Форумчане-прошу-помогите. Не разархируется Е2. [SifTeam]$ mount /dev/sda1 /mnt/usb
[SifTeam]$ ls
AAF_M5873_g1852_ipbox910_update_enigma2_p41_P179_U SBFULL_nodebug.tar.gz
lost+found
[SifTeam]$ tar -xzvf AAF_M5873_g1852_ipbox910_update_enigma2_p41_p179_U SBFULL_no
debug.tar.gz
tar: AAF_M5873_g1852_ipbox910_update_enigma2_p41_p179_U SBFULL_nodebug.tar.gz: No
[SifTeam]$
Я обычно переименовываю(сокращаю) до g.tar.gz
doroshe
я извеняюсь новичок с Enigma,сидел на прошивках PGI хочу попробовать AAF MULTIMEDIA V2 for Ipbox 9000 HD где почитать как установить ее и как сама прошивка
