Имидж от группы CuBiC eІ
vadiaravolk
Cubic Enigma2 Image rev02 experimental public release
git checkout of 23/04/2011
Enigma2-date
Plugins from 22/04/2011
Skins on 22/04/2011
Driver from 21/03/2011
Information:
The Camfeed is partly in place. Rest is the day
Picone & Settings also be paid over time to the Feed
Changelog:
Picon may be under / media / usb / stored picon
Cubic Cam Feed
Emu scripts are now in / usr / camscript and the emus we put in / usr / bin / ab
Various patches in the settings
Cubic Tools menu (menu backup, offline installer, system info, Addon Manager, Cam menu fstab editor, change the root password, delete all CrashLogs)
Cubic Skin
Cubic Conveter and renderer
gbox Support
Encryption indicator (CO ISNV ...)/( hard in the skin. planned on using the menu and deselect)
Share Info Display (hops, ECM ....)/( Hard Time in the skin. planned on using the menu and deselect)
Cam display (CCcam 2.2.1 or scam3.59 etc.) / (fixed in the skin. planned on using the menu and deselect)
Gui Restart the Image menu
Integrated: media player, Web Interface, Network Browser, hotplug, Auto Resolution, Media Scanner, Network Wizard, satellite finder, video mode, Positionersetup
Fix umlauts in some menus
Smargo / USB Mouse Support
    38,7 KB · Просмотры: 2
    46,1 KB · Просмотры: 2
    38,5 KB · Просмотры: 2
    33,8 KB · Просмотры: 2
    21,4 KB · Просмотры: 2
    23,8 KB · Просмотры: 1
allllex
Официальный сайт поддержки (нужна регистрация)
Они определили режим обновления имиджа - около 4 недель.
http://www.da-cube.net/forumdisplay.php?f=18
Эмуляторы добавляются постепенно, по мере подгонки. Они доступны с сервера онлайн
allllex
allllex
Новая версия имиджа:
Release: Dreambox Cubic 1.2.0 Image
Based on Dream Multimedia 3.2 Image
Driver Date: DM800 = 16.02.2012 ; DM800se = 28.03.2012 ; DM7020hd, DM8000, DM500hd = 22.03.2012
Cubic OE Date: 27.03.2012
enigma2 Date: 14.02.2012
Neu: Cubic HD Skin
Neu: Cubic Panel has now a version specification (Currently, the panel v.1.2.4)
Neu: Cubic Panel About shows now some image information more (Imageversion, Branch, Kernel, Hardwaretype)
Neu: Menu to run directly Scripts on the panel Cubic
Neu: Cronmanager to execute scripts timebased
Neu: Crashlog Reporter - Crashlogs sends directly to the developers from Cubic (at Cubic Panel Disabled. You kann activated them if you want use this)
Neu: Shareinfobar with gbox Support (On / Off switchable)
Neu: Own Second Infobar (If a foreign Skin will bring the part will be ignore our SecondInfoBar)
Neu: epg.dat can be stored on USB
Neu: openWebIF in the Image
Fix: Cam is active display shows nothing if no cam is active. Now displays "no cam running"
Fix: If the CamName is too long, this entry is cut off
Fix: Some translations in Cubic Panel
Änderung: Offline Installer has now a GUI restart query
Änderung: Online Addon Installer has now a GUI restart query when an addon was installed or updated.
Änderung: Altered newsfeed reader
Änderung: Modified software manager (Shows now modules and settings)
minor fixes in various files!
unnecessary Pyhton code in our files deleted
Support of D-Flash (Plug-in is on the feed)
Support of nano
http://www.da-cube.net/vbdownloads.php?fileid=1498&do=file
Может быть там нужна регистрация. Перезалил сюда:
http://depositfiles.com/files/vulpqjo66
allllex
Вышли порно-плагинчики к этому имиджу:
pornhub_0.4b
xhamster_0.3
eporner_0.5
Запускать через синюю кнопку.
А по русски, не?
Русский шрифт в подвеске.
  • enigma2-plugin-extensions-eporner_0.5_mipsel.zip
    75 KB · Просмотры: 28
  • enigma2-plugin-extensions-xhamster_0.3_mipsel.zip
    870,8 KB · Просмотры: 42
  • enigma2-plugin-extensions-pornhub_0.4b_mipsel.zip
    459,9 KB · Просмотры: 33
  • Essai.zip
    35,3 KB · Просмотры: 17
allllex
Выпущена новая версия имиджа на базе OpenPli 3
CuBiC 2.0 public Beta build010
attachment.php
Features:
enigma2 Base OpenPli 3
CuBIC Core - based on openPli 3.0
Linux Kernel - Vu+ 3.1.1, Dreambox 3.2.25, Xtrend 3.4.3
DLNA Server
UPNP Browser
Online Update
CuBiC HD Skin
Share Bar with gBox Support
YAMP Music Player
Multi Language Support in our Panel (Ungarian, German, (Russian with Build 011) (We search for translators)
Online Feed
For Hardware:
DM800 SE
From DaCube Team:
Change: Addon Manager to seperate Call Menü
Fix: epg.dat HDD Spin problem
Fix: Startproblem scam, gbox, mgcamd (Install from our Feed or use our offline Cam Package)
Fix: BackupSuite was not working
Fix: CronManager
Change: OnlineUpdate shows now installable Packages before an upgrade runs
New: YAMP integrated
Remove: MediaPlayer
http://www.da-cube.net/vbdownloads.php?fileid=2044&do=file
CuBiC 2.0 offline Cam Paket
http://www.da-cube.net/vbdownloads.php?fileid=2014&do=file
Обязательно установить идущий в пакете файл libcrypto-compat
Иначе эмуляторы работать не будут.
Имеется эмулятор mgcamd, больше ничего толкового нет.
Реакции: Eol
