Имидж (USB RC5) в новой структурой драйверов. Мультизагрузка имиджей.
VadimIv
Очередная бета версия.
Для USB с новыми драйверами и новым ядром.
Для DOM со старыми драйверами и обновленным ядром.
Для прошивки нужна новая версия AZUp 1.2.8
Dear Beta Testers,
As we told to You, RTi team completly reconstructed skeleton of Drivers, and like we also said, we transited to a new kernel ( 2.6.29-13 ), which have a lot of FIX'es and goodies which we will use.
Now all Drivers are divided, so code is light than a previous, and we will go step by step in testing of all parts. Like We said, and promised, there You will see drivers for DVB-T, DVB-C and ISDB-T too.
After You install , patch.bin ( we need to upload it, stay tuned ! ), You will have Enigma 2 booted, but dont expect to have working SAT, Terrestrial or Cable part, as we will go step-by-step to make all as much as possible to perfect
You have been selected to join to this Beta Testing phase as we fully believe in You, and We hope that we can expect fully feedback from Your side, as all of this will result in really STABLE and FULLY Functional Enigma 2 on AzBox HD Devices.
Some things will go faster in fixing, and some maybe slower, after we start testing phase, and put patch.bin, BETA TESTING Phase can start. We will also try answer on all of Your questions, but please read carefully this post, so dont' ask questions like : I have installed E2 but i dont have signal from any satellite and so on !!!
Here is list of new drivers :
llad.ko
em8xxx.ko
irvfd.ko
smp8634-rmcw.ko
smp8634-dcc.ko
smp8634-ruai2c.ko
smp8634-rmi2c.ko
smp8634-rmsha1.ko
smp8634-rmhdmi.ko
smp8634-rmedid.ko
smp8634-rmcec.ko
smp8634-ruahdmi.ko
smp8634-i2chw.ko
smp8634-i2chal.ko
smp8634-i2chaltc.ko
smp8634-DVBT.ko
smp8634-DVBC.ko
smp8634-ISDBT.ko
smp8634-DVBS2.ko
smp8634-NIM.ko
smp8634dvb.ko
http://www.azbox-enigma.eu/RTi/forum/showthread.php?227-NEW-STRUCTURE-Info-and-Files
VadimIv
  • AZUp_1.2.8.rar
    133,9 KB · Просмотры: 33
Vitaliy_S
opilochnik
old вроде как и раньше гребеночка присутсвует не уст сгс меню не через флеш
не через телнет
new таже ботва с сгс, попробовал 1080п - зеленка
VadimIv
Так почитайте тему: http://www.azbox-enigma.eu/RTi/forum/showthread.php?226-New-Structure-FAQ
Это тестирование новых драйверов, поэтому и USB версия, что-то работает, что-то нет.
SCART вроде заработал...
Поставьте версию для DOM с новым ядром и старыми драйверами.
Vitaliy_S
А смысл, новое ядро дерганье HD каналов не уберет, интересны были новые драйвера, а с ними даже тюнер не определяется.
georg30
Два раза ставил в ДОМ - запоказывало,плагин "New Menu" - не устанавливается,(установил в ручнуюmpcs),ресивер сейчас подключен
К телевизору "элт" -какая картинка -не посмотрел(на Ж.К.),заторопился - снёс!
allllex
Все ставится только руками. Никакие .ipk не прокатывают.
И еще. Если я хочу открыть в Тотале файл для правки, то фиг открывает.
Тюнер у меня не определился, а эмуляторы установил, но не проверить.
Вообще то Риппер предлагает для тестирования такой вариант:
1.Живую энигму2 DOM_old_Drivers_new поставить на DOOM стандартно, а тестовую USB_New_Drivers на USB.
2. Если надо вернуться для кино, просто вытаскивается флешка и перезагрузка.
3. Если хочется потестить, то вставляется USB флешка и перегрузка. Тестируй...
Nikolayevih
На USB версии, тюнер не работает.
А вот версия для DOM, рабочая.
userscripts_2.4-r4_mipsel и мжкамд раскидал по папкам и запустил руками. Все работает.
IGORX
Так и до нормального (рабочего) мультибута недалеко:).Кто ставил отпишитесь, плиз как там время на LCD в слипе.
Vitaliy_S
Интересно что тестировать, если тюнер не определяется...
Никто не пробовал пихать старый smp8634-DVBS2.ko ?
allllex
Тестировать можно не только тюнер... Есть мультимедиа, ютуб, сеть.
VadimIv
А симлинк нужно создавать для нормального запуска mgcamd?
ln -s /dev/dvb/adapter0/ca0 /dev/dvb/adapter0/ca1
SCART - RGB, YPrPb не проверяли на USB версии? USB-DVD?
allllex
Внимание, для версии на USB флешке выпустили новые драйверы. Загрузитесь с флешки и просто замените файлы из подвески final.zip
Кроме этого замените файл bootup по пути /etc/init.d
Что нового:
Support for RF Modulator ( Please test, and report if it is working ).
Changing of Resolution ( Added in driver, please wait for Plugin for E2 it is under work ).
Contrast settings ( Added in driver, please wait for Plugin for E2 it is under work ).
Hue settings ( Added in driver, please wait for Plugin for E2 it is under work ).
Saturation settings ( Added in driver, please wait for Plugin for E2 it is under work ).
Brightness settings ( Added in driver, please wait for Plugin for E2 it is under work ).
Aspect ratio ( currently in coding stage )
Будет работать и так, и для тестов можно не создавать. Кроме первичного долгого запуска эмулятора других глюков пока не обнаружено.
Только тогда параметр { B } 06. если с сим-линком, то параметр { B } 00 в mg_cfg.
Двойная загрузка создана только для того, чтобы можно было "смотреть кино", когда тестировать кончили. В нее не будут вносить никаких улучшений и модернизировать драйверы. Это вам не для тестов, а для "нормального" просмотра в семье, как переходный вариант. Модернизироваться будет только версия на флешке.
  • bootup.zip
    1,9 KB · Просмотры: 11
  • final.zip
    1,9 MB · Просмотры: 10
VadimIv
То-есть можно внутри оставить и DSTeam, а эту установить на USB?
allllex
В принципе да. Но когда это новое ядро появится и в новой версии DS, вот тогда можно будет ее поставить в DOOM. А сейчас так не получится, потому что у DS старое ядро, а на флешке новое. И имиджи с разными ядрами наверное так просто переключаться не смогут. Но попробовать можно, ничего страшного не случится.
Можно попробовать так:
Загрузить в DOOM предлагаемую Риппером версию для DOOM. После этого сверху через AZUp накатить последнюю DS, но при загрузке в AZUp снять галку с Copy kernel
Тогда ядро останется новым а имидж будет от DS. Вот такой вариант должен прокатить. После этого поставить тестовый имидж на флешку. Ядра одинаковые, и проблем не должно возникнуть.
