Вот пришлось повозиться. Инструкцию и имеджи прилагаю.
Description:
Image Recovery This enables a complete square of the new flash Kathrein UFS-912 in case of error or for the return of E2/Neutrino to original system. There is no intervention required by RS-232.
Application:
Importing the Recovery Image is normally via USB.
* Step 1: For this, the recovery image on a USB stick copy. (Folder structure retained)
As you see can be found on the USB stick is now following folder structure:
kathrein
| -> Ufs912
| -> Ufs912BArgs
* Step 2: If no change between E2/Neutrino back to the org. System can continue to take place directly to step 7.
Rename the folder:
ufs912 to ufs912Img
ufs912BArgs to ufs912
* Step 3: Insert the USB stick is now in the front USB port of the box turned off.
* Step 4: The box on and keep the TV / RADIO key on the box to "EMERGENCY BOOT" in the display.
* Step 5: Remove the USB stick as soon as' UPDATE SUCCESS! " the display of the box is.
* Step 6: Rename folder:
ufs912 to ufs912BArgs
ufs912Img to ufs912
* Step 7: Using the USB stick is now stuck in the front USB port of the switched-off box.
* Step 8: The box on and hold the TV / RADIO key on the box to "EMERGENCY BOOT" in the display.
During the procedure, the box automatically reboot several times.
* Step 9: Remove the USB stick only appears when another image on the TV.
Current status: ufs912_recovery_v2.0B2_1.1.zip
Disclaimer - Disclaimer:
The use of this Image Recovery at your own risk. For damage to equipment that is caused by any inaccuracies in this recovery image, the author can not be held liable.
The submarine ² (BIOS of the box) is not affected.
