NEU V10865 : OCTAGON_SF1008_HD_INTELLIGENCE_V10865__03_12_10
shuricel
NEU V10865 : OCTAGON_SF1008_SE_HD_INTELLIGENCE_V10865__03_12_10
Changes :
- Tuner signal problem by some TPs fix.
- WLAN bug fix. (TP-Link etc.)
- Russian language support Improved
- STB hangup when start/stop the plugin - Fixed
- Able to change time when recording - improved
- Recovery when hangup while recording only if it is able to play back - improved
- Easy Find LNB bug fixed.
- Easy Find LNB On/Off setting by (F2) button. - Fixed
--> Green Button - Dish Setting & Programm search
- UK DTT Local Channel Number support - Improved
- Netherlands blind scan bug - Fixed (Astra19,E & Astra23,5E)
- STB hangup when decompress JPEG to open - Fixed
- Bug when storage is full by recoding - Fixed
- Skip low symbolrate TP when Auto search - Fixed
- Divx A/V sync bug - Fixed
- File play error after fail opening Divx file - Fixed
- SPDIF does not work when playing MP3 file
- Not able to display the seleted language subtitle when play back - Fixed
- REC delete bug not yet fixed ... will fix soon (asap)
Online SW upgrade : octagon-germany.de
Файловый архив.
Обсуждение.
