OCTAGON_SF1008_HD_INTELLIGENCE_V10852__30_10_10
for Octagon HD SF 1008 HDTV - INTELLIGENCE :
Changes :
- Div. bugs fix. (Stability)
- Cutting Network Connnection when Set reboot fix.
- MultiPicture Function add. (Mosaic)
--> Blue Button
--> PS : This function will upgrade soon !
- Lyp Sink issue when recorded TS file playback fix.
- TimeShift Function improved
- Norway language add.
- System timer .. relate rec play fix.
- Online Firmware upgrade Server changed :
--> octagon-germany.de
--> Menu - Installation - Netzwork Setting
--> Firmware upgrade Server
--> Temp Disk save to HDD
- SAT + TP Database upgrade
Online SW upgrade : octagon-germany.de
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate : (Pls use Octacam Mcas Plugin)
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1008
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Date 30 October 2010
Файловый архив.
Обсуждение.
Changes :
--> Blue Button
Файловый архив.
Обсуждение.
