Please helm me configure htb+ card ident 50a00
semintelor
I have an active card htb+ ident 50a00 and i don't know to set it.I put in oscam and i get this:
Status Live Log Config Readers Users Services Files Failban CacheEX Scripts Restart
2016/12/07 10:24:17 00000000 s (main) System name = Linux
2016/12/07 10:24:17 00000000 s (main) Host name = dm800
2016/12/07 10:24:17 00000000 s (main) Release = 2.6.18-7.3-dm800
2016/12/07 10:24:17 00000000 s (main) Version = #1 Tue Apr 27 20:55:13 CEST 2010
2016/12/07 10:24:17 00000000 s (main) Machine = 7401c0
2016/12/07 10:24:17 00000000 s (main) Stb model = dm800
2016/12/07 10:24:17 00000000 s (main) creating pidfile /tmp/.oscam/oscam.pid with pid 20853
2016/12/07 10:24:17 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2016/12/07 10:24:17 00000000 s (main) signal handling initialized
2016/12/07 10:24:17 00000000 s (config) 76 provid's loaded
2016/12/07 10:24:17 00000000 s (config) 624 service-id's loaded in 46 ms
2016/12/07 10:24:17 00000000 s (reader) NTV-Card [internal] creating thread for device /dev/sci0
2016/12/07 10:24:17 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
2016/12/07 10:24:17 00000000 s (main) waiting for local card init
2016/12/07 10:24:17 121A69A7 h (webif) webif: decompressed 173231 bytes back into 419224 bytes
2016/12/07 10:24:17 121A69A7 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2016/12/07 10:24:17 74E0282D r (reader) NTV-Card [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2016/12/07 10:24:17 74E0282D r (reader) NTV-Card [internal] Reader sci internal, detected box type: dm800
2016/12/07 10:24:18 74E0282D r (reader) NTV-Card [internal] card detected
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] ATR: 3F 77 18 00 00 C2 EB 41 02 6C 90 00
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] Buffers readed 0 bytes total time_us 74608
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] Init card protocol T0, FI=1, F=372, D=12, N=0
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] Calculated work ETU is 6.89 us reader mhz = 450
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] Buffers readed 0 bytes total time_us 74997
2016/12/07 10:24:20 74E0282D r (reader) NTV-Card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] using ecm #705 for long viaccess ecm
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] type: Viaccess (non-standard atr), caid: 0500, serial: ##########
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] providers: 2 (FFF500,050A00)
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] Maturity level [F]=no age limit
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] Using PIN 0000!
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] Parental lock disabled
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] ready for requests
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [internal] found card system viaccess
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [viaccess] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [viaccess] card detected
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [viaccess] serial: ##########
2016/12/07 10:24:22 74E0282D r (reader) NTV-Card [viaccess] provider: 1, id: ##################, sa: ########, geo: empty
2016/12/07 10:24:23 74E0282D r (reader) NTV-Card [viaccess] provider: 2, id: ##################, sa: ########, geo: FF FF FF FF
2016/12/07 10:24:23 00000000 s (main) init for all local cards done
2016/12/07 10:24:23 00000000 s (emmcache) loaded 57 emmcache records from /tmp/.oscam/oscam.emmcache in 8 ms
2016/12/07 10:24:23 00000000 s (emmcache) emmstats could not be loaded for FRANSAT-Card
2016/12/07 10:24:23 00000000 s (-) -- Skipped 8 duplicated log lines --
2016/12/07 10:24:23 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 3 ms
2016/12/07 10:24:23 00000000 s (anticasc) anti cascading disabled
2016/12/07 10:24:23 7657EB4D c (client) plain dvbapi-client granted (linuxsatsupport, au=auto (1 reader))
2016/12/07 10:24:23 7657EB4D c (dvbapi) dvbapi channelcache loaded from /var/tuxbox/config/oscam.ccache
2016/12/07 10:24:23 7657EB4D c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0500 ECM_PID: 1005 PROVID: 040610
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0500 ECM_PID: 1069 PROVID: 040620
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 ecmpid 2 CAID: 0500 ECM_PID: 1451 PROVID: 050A00
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 ecmpid 3 CAID: 0500 ECM_PID: 1771 PROVID: 060A00
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 ecmpid 4 CAID: 0500 ECM_PID: 1839 PROVID: 060C00
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 found 5 ECMpids and 3 STREAMpids in caPMT
2016/12/07 10:24:24 7657EB4D c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0500 PROVID 050A00 ECMPID 1451 ANY CHID PMTPID 0065 VPID 00C9
2016/12/07 10:24:25 7657EB4D c (dvbapi) Demuxer 0 found 5 ECMpids and 3 STREAMpids in PMT
2016/12/07 10:24:25 74E0282D r (aes) AES Decrypt key 1 not found for 0500@050A00 (aka V 050A00 E1 ...)
2016/12/07 10:24:25 7657EB4D c (ecm) linuxsatsupport (0500@050A00/0B01/0709/170:F10FD80A782AB2C68AFE0E253058A142): not found (106 ms) by NTV-Card - ПерÐ&#1 78;Ñ‹Ð&#1 85; Ð&#1 86;аÐ&#1 89;ал +2 (key to use is not the curren
2016/12/07 10:24:25 7657EB4D c (dvbapi) Demuxer 0 restarting decodingrequests after 20 ms with 1 enabled and 4 disabled ecmpids!
2016/12/07 10:24:25 7657EB4D c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0500 PROVID 050A00 ECMPID 1451 ANY CHID PMTPID 0065 VPID 00C9
Can some one help me with good configuration.
