Прошивки от команды Black Hole без обсуждения!
janigor
В этой теме выкладываем только прошивки от Black Hole.
Обсуждение прошивки от Black Hole в этой теме! :)
Первый имидж от BlackHole team
http://www.prismcube-community.net/board/index.php?threads/black-hole-prism-release-0-1-2.120/
Black Hole Prism 0.1.2
This is the very first Public release, the start of a new era for the Black Hole Team.
We are very proud to offer and release our support for the new PrismCube Ruby.
Our image is based on the latest Official 1.2.0 Prismcube software and for this
reason, any bugs that you find in the official images, may also be present in the
Black Hole Prism image.
Black Hole main features:
Black Hole Boot Logo
Black Hole Menu
Blue Panel
Addons Panel
Tools Panel
Shutdown Panel
Telnet access
2x FTP access
Black Hole Addons panel:
In here you will have the following options:
Install a local Bhp Package:
Manual installation of Black Hole Prism packages
Uninstall Panel:
Uninstall Black Hole Prism packages *requires uninstall files to be included when .Bhp package was installed.
Online Addons managment:
We have our own online addons server, so that we can host some addons for you
that we feel will enhance your experience with your Prismcube, however as we
can not host every addon out there, we have also given you the option to add
your own 3rd party addon servers (we will not offer support for these servers or
there content, we are just offering you the flexibility and ease of use).
You also have the option to edit or delete any 3rd party servers you have added.
Black Hole Tools Panel:
Here we have given you the following options:
Map screenshot to rc button:
Use Mute or XBMC button to take a screenshot.
Import E2 settings (Channel list):
Use your Vu+ box channel lists
Export E2 settings (in Black Hole Tools):
Edit your Prismcube channel lists with your favourite E2 settings editors.
Bhp Packages Builder:
Build your own .Bhp packages.
Black Hole Shutdown Menu:
We have added the shutdown menu to give you more flexibility, in here you can either
Shutdown your Prismcube,
Reboot your box or just
Restart the Gui (user interface).
Ftp access:
There are two ftp types of access available in Black Hole images for Prismcube, one for the filesystem and one for recordings, a standard version of telnet is also included.
Ftp access (Filesystem)
port: 2121
user: root
password:
Ftp access (Recordings)
port: 21
user: root
password: 0000
Telnet access:
user: root
password:
Known bugs:
The import / export e2 settings support is purely experimental.
It may not work with long channel lists ( > 2 satellites) and could also lose the channel crypto system info. Anyway we strongly recommend you perform a new scan after importing a channel list.
We want to thanks Marusys for the continued support to the Team and all the Beta testers (you know who you are)
DISCLAIMER
THE BLACK HOLE PRISM IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY MARUSYS AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK HOLE PRISM IMAGE DOES NOT CONTAIN ANY EMULATOR, KEYS, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK HOLE PRISM IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE
THE BLACK HOLE PRISM IMAGE IS OPEN SOURCE. THE BLACK HOLE SOURCE REPOSITORIES WILL BE SOON AVAILABLE ON LINE.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
Jarik
Black Hole Prism 1.2.1 http://yadi.sk/d/geqdONOwBaHdi
New bootlogo by Army / Новый бутлого
New Elmo drivers SRCDATE = "20131022" / Новые драйвера
Updated Settings Converter Обновление настроек конвертера
Added md5sum files check in u-boot for safe flash update. / Добавлен файл проверки md5sum для безопасного обновления флеш
[WLAN] Added driver for Mediatek 7610U chipset (802.11a/b/g/n/ac standards) Добавлен драйвер для Mediatek 7610U
Moved Ftp access to default port 21. / Вход по ФТП по умолчанию по 21 порту.
Fixed pincode dialog not to pop up on main menu when age limit is activated./ Исправлена ошибка диалогового окна с пин кодом при включенном возрастном ограничении
Added "delete all channels when removing a satellite". / Добавлено " Удалить все каналы" при удалении спутника
Updated language packs ( German, Czech and Slovak ). / Обновлены языковые пакеты
Separate services between maruapp and xbmc using systemd.
Fixed filter problems. Исправлены ошибки фильтров.
Fixed bugs on time setting./ Исправлены ошибки установки времени
Fixed progressive jpeg decoding memory consumption problem. / Исправлены проблемы загрузки памяти при декодировании jpeg
Updated channel logo images. Обновлены логотипы каналов
Fixed zapping bug when changing channel modes./ Исправлены ошибки переключения и изменения режимов каналов.
Black Hole Menu/ Меню Black Hole
Blue Panel / Блю панель
Addons Panel / Панель Аддонов
Tools Panel / Панель инструментов
Shutdown Panel / Панель перезагрузки
Telnet access / Телнет доступ
2x FTP access/ 2 типа доступа по ФТП
Ftp Доступ(Файловая система)
порт: 2121
пользователь: root
пароль:
Ftp Доступ (Записи)
порт: 21
пользователь: root
пароль: 0000
Телнет Доступ
пользователь: root
пароль:
Источник прошивки ТУТ
seal
Администраторы
Black Hole Prism 1.2.1B
What is new ?
Added uldr.bin.uartboot
Added OpenVpn
Added Services Panel
Added Standby option in Shutdown Menu
Added NFS connection panel
The Black Hole Nfs panel allows you to connect your PrismCube to your Nas or your Vu+ boxes very easily. The new mount point will be immediately available in all Xbmc resouces menus: pictures, video, music, programs and system.
You can also stream tv channels from your Vu+ box via Nfs connections.
Of course your Vu+ box will need to have the Black Hole image installed and the Nfs server and Tuner Server features active.
Скачать
AlexM_LV
Black Hole Prism 1.2.2
Based on offcial 1.2.2 image.
Whats New ?​
- Fixed minor channel list bugs
- Fixed channel zapping bug
- Fixed current channel number bug on live plate
- Fixed EPG UI display to be updated immediately when starting a recording
- Fixed "Send to PVR" in PVR manager
- Fixed channel list to update satellite info immediately
- Fixed focus issues on FTI window and Antenna Setup window
- Fixed focus issues on main menu in media center
- Fixed addon repository update notification bug
- Added Multi-feed icon on live plate and timeshift plate
- Added a dialog for recovering broken DB
- Added active standby and deep standby menu in main menu
- Added "No Service" in channel status
- Deleted 1 pixel at top left corner of OSD
- Updated German, French, Czech and Slovak translation
- Updated Prismcube addons
- Fixed sort button to not available in favorite group
- Fixed move menu only available in "All channel" mode and favorite group
- Fixed channel list to display only tunable sub channels in recording
- Fixed multiple left key input issue on timeshift
- Fixed play icon bug on timeshift
- Fixed recording bug on standby mode
- Added Fast Scan icon
- Added move and delete menu in Fast Scan group
- Fixed bug on timer record when active standby state.
- Fixed Latin character display on front VFD
Прямая ссылка на прошивку
Jarik
Black Hole Prism 1.3.2
- Исправлена ​​ошибка аудио трек Выберите Ошибка в ПГИ
- Поддержка PIP
- Добавлена ​​событие ' NoService ' на ПГИ
- Изменен PIP UI
- Исправлены ошибки по ПГИ Blank
- Обновлен испанский, чешский и словацкий перевод
- Добавлена ​​14 дней EPG в прямом пластины и расширить диалог EPG
- Исправлена ​​сортировка каналов в списке каналов ( синхронизация -> асинхронный )
- Изменен номер канала из 4 цифр до 5 знаков
- Исправлены ошибки на яичницу- записи канала
- Только с помощью DTS основной полезной нагрузки , когдааудиопоток DTS-HD
- Улучшение потокового мультимедийного файла игру
- Добавлена ​​HDD спящий режим в активном режиме ожидания
- Добавлен выплеска файл , который появляется при запуске графического интерфейса
- Изменены EPG от 14 дней до 28 дней
- Исправлена ​​удалить все записи в файл ошибок , когда режим TimeShift
- Добавлена ​​русская QWERTY РКО
- Фиксированный набор скорости ошибок при воспроизведении.
- Исправлена ​​SOF процесса мелких насекомых на время воспроизведения.
- Исправлены ошибки на записи о PMT версии.
- Обновлен PVR аддоны в XBMC.
- Добавил pvr.iptvsample аддоны .
- Исправлена ​​Fan Control ошибка при коробка активен состояние ожидания
http://yadi.sk/d/bJEfvYgzDtdGm
seal
Администраторы
Black Hole Prism 1.3.4 Experimental​
The Black Hole Prism image has switched to the new experimental development branch and for this reason, any bugs that you find in the official or development images, may also be present in the Black Hole Prism image.​
Whats New:​
Xbmc:
Update xbmc to official release V12.2
test for media player buffering issue when streaming large size files and DTS-HD auido stream
test for using dts core only on playing mkv files.
lirc session thread priority set to 1 for rcu performance.
Misc:
Fixed bugs on fan control when active standby
Modified media play buffering
Added Fast Scan in first installation menu
Resized GUI splash image
Updated German, Czech, and Slovak translation
Fixed streaming h.264 video that SPS and PPS not stored issue
Fixed a zapping mode reset bug
Added MPEG2 SW decoder to fix decoding SD picture problem
Known bugs:
DISCLAIMER
LICENSE
THE BLACK HOLE PRISM IMAGE IS OPEN SOURCE. THE BLACK HOLE SOURCE REPOSITORIES ARE AVAILABLE @ http://git.prismcube-community.net.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Скачать
Black Hole Prism 1.3.7 Experimental
Имидж Black Hole основан на экспериментальном имидже Prismcube и по этой причине, любые ошибки, которые вы найдете на официальных имиджах или для разработчиков, также могут присутствовать в имидже Black Hole Prism.
Что нового в 1.3.7:
- Обновлен xbmc Frodo до версии 12.3
- Оптимированы функции получения аддонов, получения репозитория
- Отключено фоновое кэширование изображений
- Исправлен баг аудио проблемы при поиске медиа-потока
ПРЕДУПРЕЖДЕНИЕ: Нажмите кнопку i на пульте дистанционного управления, чтобы начать обновление, когда система загружается.
  • BlackHole-1.3.7-elmo_usb.part1.rar
    95 MB · Просмотры: 14
  • BlackHole-1.3.7-elmo_usb.part2.rar
    95 MB · Просмотры: 12
  • BlackHole-1.3.7-elmo_usb.part3.rar
    11,7 MB · Просмотры: 18
Black Hole Prism 1.3.8 Experimental
- Добавлено Black Hole splash лого (спасибо dpeddi)
- Обновлен Xbmc до 1.3.8 rel.
- Изменен формат HDMI интерфейса ( после смены разрешения на 1080p и нажатия кнопки на пульте не сохраняет разрешение, надо ждать несколько секунд до смены разрешения. )
- Обновлен перевод OSD
- Переназначены желтая и синяя кнопки ( Желтая : Аудио и Видео настройки, Синяя : PIP вкл/выкл)
- Добавлен PIP в медиацентр при проигрывании видео
- Добавлена загрузка по FTP в меню обновление прошивки из zip файла
- Добавлена иконка уведомлений закладки
- Исправлена ошибка создания главы в закладках
- Исправлена ошибка фаворитов в списке каналов
  • BlackHole-1.3.8-elmo_usb.part1.rar
    98 MB · Просмотры: 27
  • BlackHole-1.3.8-elmo_usb.part2.rar
    98 MB · Просмотры: 11
  • BlackHole-1.3.8-elmo_usb.part3.rar
    6 MB · Просмотры: 11
BLACK HOLE PRISM 1.5.0
Что нового от Black Hole Team:
Прогноз погоды в OSD (graphics by capa)
aio-grab e2 с полным скриншотом osd и video (code by dpeddi)
Что нового от Marusys:
Исправлено: остановка проигрывания медиа до достижения конца файла Исправлено: не воспроизведение звука после использования функции frame seek
Исправлено: появление экстра кнопки после использования HDMI формата
Исправлено: скрыть меню Перезагрузить GUI (Примечание: отменить это можно раскомментировав строку, если вы являетесь разработчиком, можете использовать это меню)
Исправлено: ошибка смены канала в режиме EPG
Исправлено: различные исправления для PIP
Исправлено: мелкие ошибки в Timeshift
Исправлено: открытие файла .m3u
Исправлено: ошибка просмотра таймера уведомлений в активированном режиме ожидания
Исправлено: расширенные данные EPG, неправильно разделенные
Исправлено: отрывистое проигрывание A/V при стримминге
Изменено: улучшеная загрузка миниатюр
Изменено: автоматический перезапуск после обновления каналов из Prismcube менеджера и сброс настроек
Изменено: OSD и Audio секция языков
Изменено: плавный поиск видеокадра нажатием клавиши FF / RW в XBMC Media Play
Новое: стриминг эфира TВ канала на компьютер или мобильное устройство
Новое: сохранение и восстановление системного имиджа
Новое: таймер в главном меню
Новое: новая информация в кнопках окон меню
Новое: SMB поддержка в обновлении софта из zip файла
Новое: поддержка 64GB и 128GB SSD
  • BlackHole-1.5.0-elmo_usb.part1.rar
    98 MB · Просмотры: 25
  • BlackHole-1.5.0-elmo_usb.part2.rar
    98 MB · Просмотры: 16
  • BlackHole-1.5.0-elmo_usb.part3.rar
    16,4 MB · Просмотры: 14
BLACK HOLE PRISM 1.5.1
Что нового:
• Исправлено: ошибка списка каналов
• Исправлено: ошибка удаления таймера
• Исправлено: отсутствие CAS информации для быстрого поиска каналов
• Изменено: немецкий, чешский и словацкий переводы OSD
• Изменено: оптимизация навигации
• Изменено: EPG оптимизация
• Изменено: добавлено больше функционала для редактирования каналов фаворитной группы
• Новое: включение/выключение следующего EPG сообщения в расширенных настройках
• Новое: включение/выключение часов дисплея в режиме Live TV на экране в расширенных настройках
• Новое: включение/выключение часов дисплея на передней панели в расширеных настройках
• Новое: добавлена помощь для принудительного обновления репозитория
Скачать PrismCube Black Hole 1.5.1 :)
Black Hole Prism 1.5.2
Исправлено: Ошибка некорректного названия канала в фаворитных группах в режиме редактирования
Исправлено:
Маленькие ошибки при сканировании каналов
Исправлено:
ошибка сортировки каналов при использовании PIP режима
Исправлено: нет звука в PIP режиме после смены скринов
Исправлено:
ошибка звуковой дорожки в PIP режиме
Исправлено:
некорректная информация по быстрому поиску после перезагрузки
Исправлено:
отсутствие словацкого перевода в XBMC
Исправлено:
исчезновение часов в режиме LIVE после перезагрузки
Исправлено: ошибка файлового браузера XBMC
Исправлено:
поддержка NTFS и VFAT формата в файловом браузере
XBMC
Исправлено: ошибка проигрывания музыкальных файлов в XBMC
Исправлено:
ошибка быстрого поиска каналов
Исправлено: Прогресс бар прекращает обновление в конце медиа-файла
Исправлено: XBMC сбой во время остановки медиаплеера при поиске файла
Изменено: польский, чешский и словацкий OSD переводы
Изменено:
поддержка 1080p24 разрешения
Новое: цветные кнопки в PIP режиме
Новое: включение/выключение подтверждения переключения каналов ( Список каналов -> различные опции )
Новое:
поиск в списке каналов
Новое:
смена разрешения меню при проигрывании видео файлов в XBMC
Новое: Скрыть непроверенные дополнения - предупреждающее сообщение (Получить Дополнения -> Выбрать репозиторий -> кнопка i -> Добавить в проверенный репозиторий)
Новое:
информация о PIDs, силе и качестве on live plate
Новое: помощь информация в виртуальной клавиатуре
Известные проблемы:
Неисправлено: PIP стабильность в быстром сканировании избранной группы и закодированных каналов
Неисправлено: возникли проблемы для подключения к скрытой сети Wi-Fi
Неисправлено: отсутствие слепого поиска
Неисправлено: HDMI-CEC отсутствует
Неисправлено: HbbTV отсутствует
Скачать Black Hole Prism 1.5.2
Black Hole Prism 1.5.3
V1.5.3 от 23/02/2014
Список изменений:
Исправлено отображение названия канала на VFD дисплее после смены PIP экрана и режима Live
Исправлено
переименовано OneCable в UniCable
Исправлено
режим просмотра в медиаплеере
Исправлено
ошибка при создании Backup и восстановлении системы
Исправлено ошибка названия канала при быстром поиске
Исправлено
ошибка поиска канала в списке каналов
Исправлено
Navigating Archive and Timershift window regarding to PIP
Исправлено ошибка загрузки канала в списке каналов
Исправлено
ошибка поиска каналов в режиме провайдера
Исправлено
PIP audio swap в проигрывании архива и медиафайлов
Изменено установлен активныйStandby по умолчанию
Изменено
чешский, словацкий, и польский OSD переводы
Изменено
оптимизация уровня звука
Изменено
сделан видимым синий уголок в калибрации видео на маленьких телевизорах
Изменено
немецкий, чешский, словацкий, и польский OSD переводы в XBMC
Изменено новые PIP иконки
Изменено
позволяет смотреть передачи Live TV в Media
Новое сортировка каналов по провайдерам
Новое
включение/выключение логического нумерирования каналов
Новое
Вспомогательная информация в диалоге поиска каналов
Новое
"Loading new language" диалог после смены OSD языка
Новое
добавлена вспомогательная информация в калибровке видео
Новое
"Live Streaming" и "Web Interface" функции в расширенных настройках (Web Interface port:1313 )
Известные проблемы:
Скачать Black Hole Prism 1.5.3 :)
Black Hole Prism 1.5.4
V1.5.4 от 28/02/2014
Список изменений:
Исправлено: Web Interface ошибка EPG
Исправлено: Ошибка назначения кнопкки XBMC на кнопку для фаворитов в главном меню
Исправлено: Ошибка списка каналов PIP в режиме тюнеров петля
Исправлено: Ошибка переключения звука в PIP Изменено: Быстрое проигрывание медиа файла
Скачать Black Hole Prism 1.5.4 :)
BLACK HOLE PRISM 1.5.5
Что нового
…от Black Hole Team:
Новое: Встроен полный скриншот (включая видео) из Web Interface и через telnet (by dpeddi)
…от Marusys:
Исправлено: ошибка в режиме просмотра медиаплеера
Исправлено: несоответствие аддона
Исправлено:
диактрическая ошибка в web interface
Исправлено: ошибка показа списка записи в web interface
Исправлено: кнопка BACK для выхода из окга телетекста
Исправлено: падение XBMC вызванное сбросом данных EPG при отключеном режиме live TV
Изменено: автоматическое проигрывание видео 1080 24p (установка -> расширенные -> экспериментальные)
Изменено: добавлено расширенное EPG в web interface
Изменено: применено "скрывать подтверждение переключения" в простом списке каналов
Новое: добавлена информация на экране загрузки когда обновление софта закончено
Новое: добавлена вспомогательная информация для стрима на странице в web interface
Новое: текущее EPG событие для каждого канала в списке каналов (Список каналов -> Экстра опциии -> Разное -> Показать больше EPG)
Новое: расширенное EPG информация в правой стороне списка каналов (Список каналов -> Экстра опции -> Разное -> Показать больше EPG)
Известные проблемы:
Неисправлено: Стабильность некоторых CI модулей
Неисправлено: Broken pipe issue in web interface
Неисправлено: Лимит размера EPG данных
Скачать Black Hole Prism 1.5.5 :)
BLACK HOLE PRISM 1.7.2
Что нового
Исправлено: Зависание потокового видео
Исправлено: Мигание экрана в меню настроек сети
Исправлено: Ошибка управления дисплеем в режиме HbbTV.
Исправлено: Синхронизация уровня звука между режимами HbbTV и эфиром.
Изменено: Оптимизация простого списка каналов
Новое: Горячие кнопки для перехода на другой список фаворитов в списке каналов и в простом списке каналов
Новое: Добавлена возможность использования пользовательских пиконов каналов.
Новое: Полный скриншот ( включая видео ) из WebUI
Новое: Поиск вашего IP Prismcube из WebUI ( *http://www.fwupdater.com/prismcube/* )
Новое: Кнопка записи на каждом канале в списке в WebUI
Новое: Добавлен аддон XBMC субтитров как аддон по умолчанию
Новое: Настройка пути для записи ( Конфигурация -> Опции записи )
Новое: Поддержка HbbTV
Новое: Добавлен HDMI CEC
Известные проблемы:
Скачать Black Hole Prism 1.7.2 :)
BLACK HOLE PRISM 1.7.3
Что нового
Исправлено: Зависание аддона в окне браузера
Исправлено: Ошибка перезагрузки списка каналов после изменения языка меню
Исправлено: Проблема с загрузкой ресивера если логотипы каналов и файл "ChannelLogo.xml" удалялись из папки "channellogo" через ФТП
Исправлено: Проблема рассинхронизации видео и звука
Исправлено: Ошибка калибровки меню в PIP
Исправлено: Ошибка вывода на экран телетекста, когда он есть
Исправлено: Перемонтирование NAS после смены IP адреса
Изменено: Переключение экранов PIP (эфир <-> запись воспроизведение, эфир <-> воспроизведение медиа в ХВМС)
Изменено: Немецкий и польский перевод
Новое: Поддержка записи на USB накопитель
Известные проблемы:
Скачать Black Hole Prism 1.7.3 :)
BLACK HOLE PRISM 1.7.5
Что нового
Новое: Поддержка скина Aeon Nox в Black Hole панели.
Новое: Добавлен город по умолчанию в BН Meteo.
…от Marusys:
Исправлено: Ошибка загрузки EPG.
Изменено: Обновлен русский OSD перевод.
Изменено: Предустановлено обновление аддонов XBMC.
Изменено: Рекомендация для пути монтирования, если вы ввели несуществующий путь
Изменено: Обновлен польский OSD перевод.
Изменено: Формат Label в XML.
Изменено: Обновлены немецкий, русский и польльский OSD переводы.
Изменено: Оптимизирована скорость окна EPG.
Исправлено: Другие мелкие ошибки при записи на NAS.
Исправлено: Меню настроек YouTube и HbbTV в расширенных опциях.
Исправлено: Обновление списка файлов в архиве если подключается/отключается USB.
Исправлено: Некоторые незначительные проблемы записи на NAS.
Исправлено: Ошибка списка каналов при просмотре в режиме расширенного EPG.
Исправлено: Мелкие ошибки в списке каналов и live plate.
Исправлено: Обновление прав на запись в сервере NAS после обновления пути для записи.
Новое: NAS режим в слайд меню архива (показывается только если сервер NAS подключен ).
Новое: Поддержка YouTube TV.
Новое: Поддержка Cross EPG ( rytec, opentv, etc )
Известные проблемы:
Не исправлено: PIP стабильность в быстром сканировании избранной группы и закодированных каналов
Не исправлено: возникли проблемы для подключения к скрытой сети Wi-Fi
Не исправлено: отсутствие слепого поиска
Не исправлено: обновление XBMC до Gotham
Скачать Black Hole Prism v 1.7.5 :)
Black Hole Prism 1.7.7
Что нового:
Исправлено: Временное отсутствие приема команд от пульта управления
Исправлено: Некоторые незначительные ошибки в скинах confluence и aeon nox
Исправлено: Некоторые маленькие ошибки в cross epg аддоне
Изменено: Добавлена кнопка слева и справа в цифровом диалоге Aeon Nox's
Изменено: Быстрая загрузка списка каналов в WebUI
Изменено: Немецкий, чешский, словацкий и польский OSD переводы
Известные проблемы:
Скачать Black Hole Prism 1.7.7 :)
janigor
Black Hole Prism 2.1.0
Whats New:​
From Black Hole:
•Support new skins
•Aeon 5 G
•Bello G
•Metropolis G
From Marusys:
•[NEW] XBMC Gotham 13.2 support
• [NEW] Aeon Nox 5 skin for Gotham
• [NEW] Metropolis skin for Gotham
• [NEW] Bello skin for Gotham
• [MODIFIED] German OSD translation update
• [MODIFIED] Default EPG grid timeline ( 4 hour -> 2 hour )
• [FIXED] Unicable recording
• [FIXED] Standby hang-up issue
• [FIXED] Web interface remote control
• [FIXED] Focusing bug on EPG channel view
• [FIXED] Display extend EPG bugs
• [FIXED] Manual timer edition bug
• [FIXED] Updating pre and post recording time bug
• [FIXED] Focusing bug on recording path in installation menu
• [FIXED] Setting video and audio bug in first installation menu
• [FIXED] Drawing EPG grid timeline bug
• [FIXED] EPG update bug after tune in EPG grid mode
• [FIXED] Recording deletion issue on post recording time
• [FIXED] Audio language change bug
• [FIXED] Empty FTA/CAS list issue in channel list
• [FIXED] Broken character in web interface
• [FIXED] Slow PIG close in channel list
• [FIXED] Displaying Dolby/Dolby Plus icon on live plate
• [FIXED] Saving channels after channel update
• [FIXED] Live plate GUI
• [FIXED] Running record color bug on EPG
• [FIXED] Timeshift plate GUI
• [FIXED] Displaying CAS icon
• [FIXED] Displaying Lock/Unlock info
• [FIXED] Saving video output setting
• [FIXED] EPG update after changing channel
• [FIXED] Channel change by view timer bug
• [FIXED] Locked tv channel's audio issue after changing to radio mode
• [FIXED] Opening Youtube TV
Known Issues:
•[UNRESOLVED] PIP stability in fast scan fav group and scrambled channels
• [UNRESOLVED] Having trouble to connect to hidden wifi network
• [UNRESOLVED] Blind scan missing
WARNING: Press i button on remote control to start update when system boots.​
Known bugs:
https://mega.co.nz/#!tl8QHCbb!WWkEf51n881KpPn1MPHMUKctMrc0YmZgjrRLjMAvRSA
