guard772008
e2 RSP3.160 STM23 G1213 First STM23 UFS-910 image
18/10/2010
Enigma2 OpenSource Project GIT Duckbox SH4-Rev.1213
We would like to once again express our gratitude for all TDT and active "sh4_duckbox_project" mebers for their entire work that have open our way and guided us.
RSP Kathy Team have the pleasure to offer you the first ufs910 image (BETA) based on STM23 Linux.
You will find most of the validated former options included in the RSP images built on STM22,
but also new options that we hope you will find useful and appreciate our work.
Unfortunately, we have to mention a few minuses that we are still working on to be fixed.
The most important ones are the following:
- DTS Downmix ON and DTS passthrough are not working
- After boot you might hear sometimes anoying noises in your TV speakers. Clear sound and no noises in case you are using the Toslink digital optical output.
- Zapping channels sometimes will conduct on pitch noises in your TV speakers. This is also not applicable to the Toslink output.
For new users:
"RECORD" labeled partition is automatically mounted on /hdd/movie; the other partitions are mounted in /tmp/[device]
- when mounting the HDD you can see only valid Linux partition
- it supports cifs; you have to enable it in the menu and edit the configuration file (var/config/amnt.cfg)
using the appropriate PC IP address, login username and password and the folder name you want to mount.
Ссылка для загрузки:
http://www.megaupload.com/?d=SNPDKZK9
18/10/2010
For new users:
