V10831 OCTAGON SF1018 HD ALLIANCE
shuricel
OCTAGON_SF1018_HD_ALLIANCE_V10831__21_07_10
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- Trick Mode & Spooling problem fix. (Pls test longer time)
- Maintenance Timeshift during Playback, Functionality Description :
--> Playback Recored files or AV file in Timeshift "ON" condition. Timeshit will be maintain
- Changing Entering Standby Mode (1W regulation supported models only)
--> Before :
- Standby Power "OFF" - Entering 1 Watt Standby Mode(Front OFF) by input [STANDBY] Key in the condition 'ON'
- Standby Power "ON" - Entering Standby Mode to display Time by input [STANDBY] Key in the condition 'ON'
--> After (Standby Mode Menu Item deleted) :
--> Using with Remote Control :
- ON condition : Input [STANDBY] Key one time => Entering Standby Mode to display Time
- ON condition : Input [STANDBY] Key two times within 2 seconds => Entering 1 Watt Standby Mode(Front OFF)
- ON condition : Press [STANDBY] continously => Entering 1 Watt Standby Mode(Front OFF)
--> Using with Front Button :
- ON condition : Input Front [STANDBY] button one time => Entering Standby Mode to display Time
- ON condition : Press Front [STANDBY] buttom two times within two times => Entering 1Watt Standby Mode(Front OFF)
- Improved Timer Conflict issue
- HDD Checking functionality added when Booting or :
--> Menu - System Tools - Storage Manager : Storage Check
- Automatically added in Favorite HD Group when scan HD Service
--> Press FAV Button - HD Folder
- Displaying changed Resolution data on Screen when resolution changes (LIVE Tv Mode)
- Remain 'Standby off' condition when main Power off/on in the condition 'standby off'
- Improved MP3 playback
- Added JPEG ThumNail feature
- Week Day Showing add. by EPG and Sub Menu points
- TRT HD problem fix.
- Search Mode improved for TPs in nearly place
- Minor bugs fix.
- BISS keys update + add. (MENU 8282)
- SAT & TP List update (Eutelsat 7E & Turksat 42E)
- Important : New SDK will use by comign SW realese !
{ System Information : }
- API Version 07.Juli 2010
- Kernel Version 14.Juli 2010
- Treiber Version 14.Juli 2010
- Root File System Version 14.Juli 2010
- Build Version : 3427
Online SW upgrade : oud.gmc.to
Файловый архив
Обсуждение здесь.
