1.05b telesat mod
fenbg
1.05b telesat mod
- AutoDetect HW Version (1w/14w) and automatic setting of cfg files
of the appropriate BOX's version;
- Auto-DiSEqC v.1.0 by telesat® , (DiSEqC 1.1/1.2)
You should edit file : /data/sat/diseqc.cfg
Set up DiSEqC type 1.1 or 1.2 according to the system you have
Syntax is <diseqc_type=1.x> where x=1 or x=2 ,
that means that allowed values are:
diseqc_type=1.1 i diseqc_type=1.2
Set up satellite position
Syntax is: <position> <Satname> , where:
<position> = DiSEqC position stored in
DiSEqC positioner or position stored on DiSEqC multiswitch
values must be between 1 and 99, others are ignored
Position 255 in cfg file means that there won't be sent any command on that satellite
<Satname> = name od the satellite - in the way it is written in the box settings file
check with setdir
- Watchdog for OSDshell added
- Transparent OSD
- Telnet password Add
_______________________________________________________________________
1.05a telesat mod
- Hello message changed (the message you get on switching on/off your receiver)
- camd3 added, but you can also add it by yourself in a very simple way
- new options added in advenced menu:
- CAMD List Update' *1)
- ECM Info
- Netmask , Gateway and DNS podesavanja
- Reboot
*1) CAMD List Update
Scripts are standard one used in, for example, Dreambox/Gemini (somename_cam.sh)
Copy scripts in /data.emu/ folder, give them 755 right,
then, through advanced menu choose CAMD MENU => CAMD List Update ,
wait for a second and you will get message with scripts found and add into menu:
CAMD MENU => CAMD Setup and through it you can choose which CAMD it is going to be active
and in the same time you can turn off the existing one and to turn on the new one selected.
If you have choose the same one - it will restart it.
1.05 telesat mod
IP - 192.168.1.34
FTP - user:root , pass:kathrein
telnet - without password
EMU : Mgcamd , Newcs
- IP adress and other settings from network may be changed from extended meny;
also, you can preview all network settings
- Select active EMU from extended meny. It will restart after sellection,
if you select different EMU - active emu will be stoped and new/selected will be started :)
- Add new emu with scripts' (/data/emu/emuname_cam.sh) but you must edit file : /data/emu/emuactive
- Extended menu offers basic DiSEqC commands and GoTo (stored) position
- Allowing work with PL-2303 USB-to-Serial Bridge Controller
- Channel Info, but at the moment it doesn't work properly - teh reason why Autodiseq is not implemented :(
http://rapidshare.com/files/116385357/1.05b__telesat_mod.rar
thx@telesat
pozdrav
tolli
Вроде ничо такой имидж.
+1!
fenbg
И что тебе не нравиться,нормальной имидж,есть упр.osd,а там все что надо для норм.просмотра.Жаль только что в офф1.05 нет еще кирилицу.Вот так!
tolli
fenbg,
Да мну кириллица не критична. Попривык уже к английскому. Тем более, что руссификатор уже попробовал, знаю что-где. Имидж понравился. Пожалуй пока на нем остановлюсь.
gesha-zap
Добрый вечер. tolli подскажи этот имидж поддерживает работу с мото подвесом или нет.
tolli
gesha-zap,
Еще не пробовал. Но сообщения на экране о позиции спутника при переключении имеются.
gesha-zap
Да, я заметил, вобщемто имидж неплохой, без наворотов, только на пулт отвечает тормознуто, и мне кажется картинка похуже чем в Aaf, хотя это может только кажется.Попробую дальше его помучать.
tolli
Помучал ещё - исчезло Экстра меню. Выводит только на лицевой панели.
Думаю переустановить. Может снес чего ненароком, пока игрался. И со спутника на спутник перестали открываться каналы. БЛИН!
gesha-zap
У меня таже фигня, да и эмулятор виснит не хочет зачастую работать, я откатываюсь обратно на Aaf1.05
olesub
Убери автомат, ставь на 1080 и будет у тебя ОСД!good!
fenbg
@gesha-zap
эмулятор НЕ виснит,Auto-DiSEqC работает,ОСД тоже,что тебе не нравиться интересно...
mgural
имидж понравился ,простенький и все работает быстро, ОСД вызывается через пять секунд после появления изображения , проверял на FTA канале, русифицировал его , спасибо allllex , использовал его русский шрифт Sanka.ttf . Будете ставить сохраните свой конфиг для ручного переключения спутников data/sat/gotosat.mnu потом подставите свои спутники и позиции.
  • telesat 1.05b ru.rar
    47,8 KB · Просмотры: 73
tolli
mgural,
Расскажи куда что распаковывать из архива. Плиз.
mgural
тебе нужно просто заменить соответствующие файлы в Кати и перегрузить аппарат.
Добавлено через 13 минут
только будь внимателен этот РУС. для ТЕЛЕСАТ 1.05б , а у тебя в подписи ПКТ 1.0.
RamasG
у меня екстра меню непоявляеться ни на тв ни на лицевои панели катки с другими имаге проблем нету катка 1wat
fenbg
@RamasG
Проверь у /data/osdshell.cfg
что у тебе newBox=true или newBox=false ?
Проверь и MAC телнетом:
ifconfig|sed "/HWaddr/!d;s/.*=//"| sed "-e s/^.*HWaddr //"
RamasG
font=/data/CENTURY.TTF
#font=/data/ARIALNBI2.ttf
#font=/data/Bimini.ttf
#font=/data/Arial.ttf
outputDevice=1
outputPort=3
entrie_count=4
menu_elements=4
newBox=false
1_sh=CAMD MENU|/data/emu/camd.mnu|MENU
2_sh=SETUP|/data/setup/settings.mnu|MENU
3_sh=CHANNEL-INFO|/data/sat/channelinfo.sh|NORMAL
4_sh=REBOOT|reboot -f|NORMAL
#doublebuffer=false
debugMode=true
вот такои фаил
мас адрес 00-50-FD-FF-75-DA
