Lenina
Куратор "IPBox"
AAF F1 Image for IPBox 9000 USB/USBFULL
Wintertime AAF changelog since last release:
Based on Tideglo 0.92:
+ Update kernel on 2.6.23.17-0123
+ Enigma2 nighly 13/03/2010
+ Wifi Support
+ Fernbedienug Speed up
+ Many system enhancements
+ Fix CI CAM Support
+ Update Cuberevo VFD plugin
+ Update TimeShift
Updates to the base image + 0.85
0.80 + Upadtes the base image
Updates to the base image + 0.75
- Occur PERMIT HD Rucker,
- No card reader support for lack of drivers.
AAF: (based on M2603)
+ Station list update
+ Menus restructured and clearer
+ If no sound after boot option "AC3 by default to No (contact occurred sporadically on)
+ IMDB plugin included
+ WebradioFS green screen fix
HDD Standby Update + (SATA support)
+ Translation updates + supplemented missing languages
+ Update Auto Resolution Plug
+ Add split-screen extension by Gutemine
+ Fixed Media Center Mounting Problems
+ Add new font Tuxtxt
+ Add functional state shift
+ Speed up mounting network
+ Fix boot show video
+ Improve mounting
+ Fixed no sound switching tv channels
+ Fix Media Player GS
Mod + Update to Windows Media Player 2.5 (with the play of Mount RAR RAR files and aspect ratio selection)
+ Nemesis BlackBox SD Skin searching for Scart
+ New Tuxtxt Font
+ Tuxtxt position optimized
+ Shift state indicator in the Default Skin
+ Media Center Audio Player Is Taking cover the hot cover.jpg cover.png /
+ Added GraphMultiEPG with Picon Support
+ Standby just for the media with more than 50GB
+ Scart switch in the (soft) Standby
+ FAT filesystem check added to the menu
+ Shutdown menu update
+ Update Addon Manager 2.0
+ Fix panel AAF VideoTune
+ Some minor fixes
+ Updated Tuxtxt
+ Fixed handling Tuxtxt
+ Fix SWAP preparation
+ Fix online update functions
+ Fixed Time and Date problem
+ Update Infinity HD Skin
+ If desired video with DTS sound output is under AAF-Panel-> Preferences-> Startup oldaudiofw put to yes.
DOWNLOAD IMAGE AAF F1 Image für IPBox 9000 USBFULL http://hotfile.com/dl/34781627/97ee988/AAF_F1_Image_IP-Box9000_FULLUSB.rar.html или http://97.74.32.10/database/image/AAF_F1_Image_IP-Box9000_FULLUSB.rar
DOWNLOAD IMAGE AAF F1 Image für IPBox 9000 USB http://hotfile.com/dl/34781875/a4ad20c/AAF_Formel1_Image_IP-Box9000_USB.rar.html или http://97.74.32.10/database/image/AAF_Formel1_Image_IP-Box9000_USB.rar
AAF F1 Image für IPBox 910 USBFULL http://97.74.32.10/database/image/AAF_F1_Image_IP-Box910_FULLUSB.rar
AAF F1 Image für IPBox 910 USB http://97.74.32.10/database/image/AAF_F1_Image_IP-Box910_USB.rar
AAF F1 Image für IPBox 900 USBFULL http://97.74.32.10/database/image/AAF_F1_Image_IP-Box900_FULLUSB.rar
AAF F1 Image für IPBox 900 USB http://97.74.32.10/database/image/AAF_F1_Image_IP-Box900_USB.rar
AAF F1 Image für IPBox 91 USBFULL http://97.74.32.10/database/image/AAF_F1_Image_IP-Box91_FULLUSB.rar
AAF F1 Image für IPBox 91 USB http://97.74.32.10/database/image/AAF_F1_Image_IP-Box91_USB.rar
Поставил USBFULL на 9000, интересная анимация при включении и выключении, мжкамд стартует. Для моунта внутреннего винчестера пришлось подправить fstab, так как средствами ПО не нашел. Во встроенных плагинах есть Перманенттаймшифт, но запустить его не получилось. Запускал вручную кнопками "Пауза"-"Плэй". В таймшифте добавлена полоска прокрутки, приятно. Дерево для скачки плагинов и аддонов в онлайне есть.
Подправленный кеймап для выхода из таймшифта по кнопке "Стоп" (испытан при установке на внешней флешке на IPBox_9000)
+ Wifi Support
+ Update TimeShift
+ Improve mounting
+ New Tuxtxt Font
+ Some minor fixes
+ Updated Tuxtxt
