AAF Weihnachtsimage IP-Box USB & Flash version
Seryi134
9000/910/900
Bootvideo
Rebootvideo
image Info
AAF Weihnachtsimage V3.0 IP-Box 900/910/9000[/b] USB & Flash Image
Basis Team Ducktales (Tideglo) 0.7.0
release 0.7.0
- fixed mute volume on channel change
- mute over SPDIF is now working
- added mp4 runtime detection
- added http mp4 streaming
- added m2ts file
- added stty
- added netstat
- added traceroute
- added grab for GUI screenshots (it does not work with live-tv screenshots)
- fixed many bugs on video drivers (don't remember all because most of drivers code were completly reviewed)
- applied better quality on video drivers (IMHO now on sd channels is really better than before)
- fixed many bugs on audio drivers (most of them on codec side)
- fixed (??) snr/agc value on tuners (especially in the sharp tuner)
- fixed bug on starting network at boot
- changed bootlogo with a new default
- reorganized general driver structures
- fixed subtitles *.srt and *.ssa when there is '.' char in the file name
- fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at enigma2 boot)
- fixed a bug that causes DNS to be rewritten at reboot or at network restart when dhcp is activated on the router/net (if you have dhcp activated dns will be always given by dhcp server)
- fixed a bug that make dhcp always activated
- fixed record from standby
- fixed record from deep-standby
- fixed timer bug for record scheduled events
- fixed volume bug on web-interface
- fixed menu factory reset (thanks skaman)
- fixed panscan mode on almost all possible cases
- fixed audio volume on SCART wich was lower than HDMI
AAF Panel 7.7
MediaCenter
aaf
+ image auf python2.6 umgestellt
+ nogfx als default-skin
+ AAF Panel 7.7
+ AC3 Auto Volume
+ new onlineflash tool (with verify and tv output)
+ MediaCenter (IMDb Support | new Videplayer Filelist | WeatherPlugin | WebRadioFS)
+ Networkbrowsermod 0.9
+ Boot-/Shutdownvideo support
+ AAF-Boardviever
+ simple Bitrate-Viever
+ Repairmodus (when error or bootloop)
+ und vieles mehr
Bekannte Probleme:
- Manchmal nach dem Zappen kein Ton (Ton oder Kanal umschalten hilft)
Shutdown Video
Danke an Team Ducktales für das super Basis Image und alle die dieses Image ermoeglicht und getestet haben.
RapidShare: 1-CLICK Web hosting - Easy Filehosting 900 USB
RapidShare: 1-CLICK Web hosting - Easy Filehosting 900 FLASH
RapidShare: 1-CLICK Web hosting - Easy Filehosting 9000 USB
RapidShare: 1-CLICK Web hosting - Easy Filehosting 9000 FLASH
RapidShare: 1-CLICK Web hosting - Easy Filehosting 910 USB
http://rapidshare.com/files/324979285/AAF_Weihnachtsimage_IP_Box910_Flash.rar
Взято с форума http://forum.sifteam.eu :)
Lenina
Куратор "IPBox"
Там же пишут, что некоторые файлы залиты некорректные. Так, например архив 9000 USB точно коррумпирован, сам уже напоролся, а вот для внутренней флеши нормальный. Проверяйте сначала скаченные файлы под свои ресы или ждите новых.
Nikolayevih
Кто поставил AAF Weihnachtsimage IP-Box Flash version отзовись как впечатления?
Русского языка нет. Только английский и немецкий. Эму нет. Эму менеджер зарыт- надо искать. Пока разбираюсь.
При загрузке, выводить ip ресивера на дисплей.
den2000
Пишут , что запись по таймеру исправлена. Проверьте пожалуйста.
Не стартует ли рес опять после задания ?
Vladimir1969
Русский язык и ЭМУ ставятся через Блю панель, шара работает, тестю дальше.
Nagornuk
root/sifteam - для имиджей от SiFteam, включая Е2
root/neoplan - для сборки Е2 от iscan
root/ipbox - для имиджей от ABCom, включая Е1 и Е2
root/<пусто> - для E2 от PKT
root/relook - для имиджей от DGS и nlb
Спасибо Janigor....
satellite
Спасибо Janigor....
для имиджей PKT пароль : root/ ipbox
eugeny13
привет.поставил при включении вышибает IP а так вроде ничего и диск увидел.а скинсов других нет????
привет.на следущий день,когда включил не увидел диск.просто класс
nikolasi
А скинов и не будет других пока сами конвертеры и рендеры не переделаете под питон 2.6-все старые под питон 2.5 при том рус файлы а они с питоном 2.6 не дружат:)Найдете нужные конвертеры-рендеры не компилированые тоисть не в рус формате скины будут работать.Хотя сомневаюсь что найде-ру свои никто не выставляет:)
edarot
ну что кто нибудь нарыл скины и может еще что по этому моду??
