RusWolf
AAF Winterimage UFS 910 OBI BA
(Uploader: krauss)
am: 18.01.2010 03:57
upgedatet am: 18.01.2010 04:10
Beschreibung:
aaf
+ AAF Panel 7.9 (added VideoTune | several fixes and updates)
+ Volume Adjust (menu -> settings -> VolumeAdjust)
+ Cleanup Wizard (menu -> settings -> system ->...)
+ Crashlog Wizard (menu -> settings -> system ->...)
+ MediaCenter (IMDb Support | new Videplayer Filelist | WeatherPlugin | WebRadioFS)
+ miniuboot r1.3 update (for lzma compressed kernel, better compression and a littel more speed)
+ Repairmodus (when error or bootloop)
+ usbspeed (test usb storage speed)
+ mixed lzma/zlib compression for /var (better compression and a littel more speed)
+ usb-storage.usbwait123 kernelparameter (setting the boot sequence)
+ ntfs read/write support (you can aktivate this in aaf panel)
+ much fixes in samba server
+ only boot E2 on error (you can aktivate this in aaf panel)
+ new onlineflash tool (with verify and tv output)
+ new system layout (for more /var free)
+ partition load for problem storages (you can aktivate this in aaf panel)
+ some fixes in ramswap
+ wget, fsck, mkfs (precentage display on vfd and tv)
+ much other fixes
Danke an sh-receivers-developers für das super Basis Image und an alle die dieses Image ermoeglicht und getestet haben.
http://97.74.32.10/database/image/AAF_M1645_g108_USB_e2.tar.rar
(Uploader: krauss)
Beschreibung:
aaf
+ much other fixes
