Lenina
Куратор "IPBox"
With best reagrds from ACT team
ACT_095_E2_usb version
based on Enigma 2 Nightly Build of tideglo: 0.9.5 version
Tideglo release 095 changelog:
- back to STLinux 2.2 because of some audio bugs on STLinux 2.3: when i will fix it, we will go again on stlinux 2.3
- added wmv file player
- added multi descrambling feature: i tested it only with incubusCamd 0.99 wich fully supports multidescrambling
for e2 (previous version don't work, and i don't know if other softcams works or not, just test them)
- fixed some memory crash on h264 channels
- fixed remote controller buttons with teletext activated
- fixed DVDPlayer crash
- DVDPlayer buttons are now better showed than before
- supported DTS audio on mkv files
- other MediaPlayer fixes
- updated greek language
- updated bulgarian language
- added samba (not started by default, you have to add it on the rcS_user.sh if you need it)
- added cp2101 external card reader drivers (load it in rcS_user.sh if you need it: /lib/modules/cp2101.ko)
- added ralink rt2870 wireless chipset drivers (load them in rcS_user.sh if you need it: /lib/modules/rt2870sta.ko)
- added Freesat EPG support
- by default the sci-ng driver (pacco's 1.4 version) is loaded at enigma2's boot: this is a temporary option, i built a
sc driver but still getting many memory errors, i don't know when it will be full ready
- update Enigma2 CVS to 02/05/2010
- enabled again PIP function, watching 2 channels on PIP will make slow live channels playing, so it does not work at 100%
ACT_095 changelog:
reworked ACTpanel again(now it look more like a panel)
ACT blue panel can be started now by blue button
updated ACT panel with more options like:
mountmanager panel
sambaserver panel
openvpn panel:can be started by start and stop script(not tested!!
reworked,modified and updated emumanager+ ACT extra v2.0:
added oscam and incubus v0.99
removed extention button from emumanager
1x button red=extention
2x red button=emumanager
emumanager can be found also in act panel
new scriptstarter(removed non useable script)
added epg importer
set Glamour_X-Infinity skin as default
add skin DMConcinnity-HD
added own addon server for plugins,skin,emu
Known Bug :
use DHCP = network not activated
dont use DHCP then it says network activated but no ip address
then use DHCP again then network is activated with ip address
Download Links :
Cuberevo / IPBox 9000 HD
http://www2.hostinoo.com/ffe4go1scymu/ACT_095v2_E2_9000_usb.tar.gz.html
Cuberevo-mini / IPBox 900 HD
http://www2.hostinoo.com/vs2unyks6ezk/ACT_095v2_E2_900_usb.tar.gz.htm
Cuverevo 3000 / IPBox 910 HD
http://www2.hostinoo.com/hioaudnhu52z/ACT_095v2_E2_910_usb.tar.gz.htm
Cuberevo 250 / IPBox 91 HD
http://www2.hostinoo.com/9j0b8di1vfy3/ACT_095v2_E2_91_usb.tar.gz.htm
Best Regards...
Cubebox
ACT_095 changelog:
mountmanager panel
sambaserver panel
added epg importer
Known Bug :
Download Links :
Best Regards...
Cubebox
