AZBox Beta Firmware: 0.9.3661
Тема в разделе "Firmware (прошики, ПО)", создана пользователем Viraje, 5 ноя 2009.
  1. Viraje
    Viraje Супер-Модератор Команда форума
    14 май 2007
    3.227
    2.718
    for both AZBox Premium HD & AZBox Elite HD
    # FIXED
    - Correct a bug regarding the message for screen capture.
    - Correct a bug, do not proceed the progress bar at FTP up/download.
    - Correct a bug when it occured the FTP login was failed.
    - Correct some bugs of the file manager: Icon images / Multi language messages
    - Correct a bug regarding DVB-T&C TS discriptor.
    - Correct the gritch noise bug on the HDMI audio.
    - Correct a bug regarding the setup display options.
    - Correct the bug regarding LEDs on the front panel (AZBox Premium)
    - Correct the alphabetical sorting bug of the favorite channel list
    - Correct the bug to remember the last channel.
    - Correct the scan SAT bug
    - Correct the TV buffering problem.
    - Correct the MKV player bug whick is not displayed videos
    - Correct the time display problem at MKV player
    - Correct a memory leak at the new audio driver
    - Correct the audio bug which is occuring when the radio was played long time
    - Correct the video bug which regarding display mode like as pan & scan display
    - Correct a fast forward problem to go forward faster.
    - Upgrade the YouTube player
    # ADDED
    - Add new driver for better A/V performance (under testing)
    - Add a function to insert many function keys on the USB keyboard.
    - Support multi-audio of TS files.
    - Add subtitle ID and audio ID at the individual channel.
    - Add a decoder recovery routine for correct the radio distortion bug.
    - Add a function to be able to select the Dolby output mode (Line mode / RF mode)
    - Add scripts when called at standby and wakeup
    /DISK2/etc/standby.sh
    /DISK2/etc/wakeup.sh
    - Add new driver for Samsung ATSC tuner.
    - Modify the azbox SDK and test application
    - Add a radio wallpaper register module
    - Add the page up/down function at file manager.
    - Add a information bar for ATSC
    # IMPROVED
    - Modify the main menu position.
    - Modify the DEMUX structure to be able to parse several PMTs in the same time.
    - Increase IPTV ability to get several types of streams.
    - Modified for EPG
    + EIT pool
    + EIT filters
    + Memory Pool
    + Memory menager etc.
    - Modify the EIT parser to add a function regarding ATSC
    - Modify the scanning PMT method for using multiple PMT filters.
    - Optimization of the DEMUX_INFO structure for using the multiple PMT parser at movie player.
    - Apply the multiple PMT parser at the movie player.
    - Optimization the memory of the audio player.
    - Support VBR at the MP3 player
    - Modify web browser and RSS news cause by change the driver.
    - Modify to set subtitle at center
    - Modify to display full screen at photo viewer.
    - Change some video decoder options to solve the mkv file player problems
    - Change some audio decoder options to solve the glitch noise problems
    - Change the recording file size to 4GB from 3GB (will be changed next release to detect the max file size from system)
    - Modify the network setting timeout for wifi to 1 minute from 30 seconds.
    Best Regards,
    The OpenSAT/AZBox Teamhttp://www.azupd.com/0.9.3661/patch.bin
    w0lf нравится это.
Похожие темы
  1. Viraje
    Ответов:
    0
    Просмотров:
    2.895
  2. Viraje
    Ответов:
    0
    Просмотров:
    2.092
  3. Viraje
    Ответов:
    0
    Просмотров:
    2.303
  4. Viraje
    Ответов:
    0
    Просмотров:
    3.172
  5. Viraje
    Ответов:
    0
    Просмотров:
    9.614
Загрузка...
Поделиться этой страницей
