Быстрое переключение каналов на IPBox`ах
kammaz
Всем привет. Подскажите плиз каким наилучшим образом можно сконфигурировать эмулятор mgcamd_1.31 + файлы mg_cf , priority.list и newcamd.list для ++? Предлагаете свои варианты настроек.
Вот мои настройки для mg_cf :
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 01 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
# + tps SID, which pmt pid contains au pid
U: { 01 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
G: { 01 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 01 } 5 30
# network ecm timeout in seconds
K: { 05 }
# newcamd dead routes connect retry, sec
Q: { 15 }
# network shares priority
# 00 gbox, newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd, gbox
# 02 newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } username password
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 00 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E:) time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 00 }
И вот настройки для priority.list :
V: { 02 07 10 }
V: { 03 06 00 }
Настройки для newcamd.list :
CWS = myserverip 4000 mylogin mypasword 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CWS_CONNECT_TIMEOUT = 120
CWS_KEEPALIVE =120
janigor
A: { 00 }
Если не пользуешся карточкой
booom2
V: { 02 36 00 }
а что это за идент?
03 06 00 знаю...
kammaz
V: { 02 36 00 }
а что это за идент?
03 06 00 знаю...
Спасибо, исправил.
Но все же, как увеличить вцелом быстроту переключения каналов на IPBox 900HD, 910HD, 9000HD (не только каналов в ш...е, но и обычных) ?
stoser
даже без эмулятора переключает очень медленно, может замена софта изменит ситуацию?
chewbacca
Модератор "AzBox"
а может нет... :)
pupsik27
подскажите плиз идент Platforma HD для priority.list ?
SergDik
Настроить правильно приорити.лист, игнор.лист и replace.list (чтобы быстро происходило переключения между каналами на разных идентах) и переключение будет очень шустрым.
igorekxx
помогите мне в настройках с орион экспресс открывает до 11 ,15 сек тогда как Платформа и Радуга 2,3 сек вот мои настройки
priority.list
I: { 00 00 00}
I: { 00 04 }
I: { 06 02 }
ignore.list
I: {00 01}
I: {00 02}
I: {00 03}
mg_cfg
# EMM messages
# 00 don't show any EMM's (default)
# 01 show only valid EMM's
# 02 show valid and bad EMM's with complete data display
M: { 01 }
# ECM messages
# 00 don't show any ECM's
# 01 show only valid ECM's (default)
# 02 show valid and bad ECM's with complete data display
C: { 01 }
# AU
# 00 is ignored (default)
# 01 enable AU
# 02 AU Auto
A: { 02 }
# key update
U: { 01 }
# key files folder
# 00 keyfiles in /var/keys
# 01 keyfiles in /var/tmp
T: { 00 }
G: { 01 }
# 00 disable (default)
N: { 07 }
K: { 10 }
Q: { 600 }
# 00 newcamd, radegast, camd3 (default)
# 02 newcamd, camd3, radegast
P: { 00 }
# 01 neutrino
# 02 enigma
O: { 00 }
# 03 default
# 01 show emu ecm
S: { 03 }
# Log options
# 00 Off (default)
# 01 Network
# 02 console
# 03 both
L: { 03 } 192.168.0.191 28007
# cache ecm pids and data used to open channels,
# store pids in /tmp/ca_cache.list at exit, load at startup,
# same syntax as restore.list
# 00 Off (default)
# 01 Ecm pids cache
# 02 Ecm data cache
# 03 both caches
H: { 00 }
# reread files on zap:
# 00 No (default)
# 01 config (including priority and ignore, but not replace/cache)
# 02 config and keys
# 03 both
R: { 00 }
# debug
# 00 off (default)
# 01 on
D: { 00 }
leopold75
Доброго времени суток
...орион экспресс открывает до 11 ,15 сек тогда как Платформа и Радуга 2,3 сек
Коллега, судя по конфигу Вы используете mgcamd
Это не лучший вариант для указанных пакетов - неужели у Вас не "квакает"?
Потому рекомендую для вышеперечисленного mbox - если Вам не нужны
длинные ECM то вообще нет проблем, просто выберите другой ЕМУ в настройках.
Sat_Odessa
# EMM messages
M: { 01 }
# ECM messages
C: { 01 }
# AU
A: { 01 }
U: { 01 }
T: { 00 }
G: { 01 }
N: { 01 } 5 30
K: { 05 }
Q: { 15 }
P: { 02 }
S: { 03 } 80
E: { 00 }
H: { 07 }
R: { 00 }
# debug, summ of
D: { 00 }
# box type
B: { 00 }
C: { 00 }
A: { 00 }
N: { 03 } 5 30
L: { 01 } 172.16.1.1 28007 /tmp/mgcamd.log
# или вообще
# L: { 00 }
E: { 20 }
# если E: { 00 }, то имеет смысл и H: { 00 }
Скорость переключения каналов - есть функция от выдержки пользователя, таланта программиста и "мощности" железа. Проще всего исправить первое, второе - сложнее, ну а третье - это уже совсем сложно, можно даже сказать - невозможно!
