C3LN VDR 0.1 for Ipbox 9000HD
Lenina
Куратор "IPBox"
C3LN VDR 0.1 of VDR HD for CubeRevo - Ipbox 9000HD
C3LN - VDR-1.7.4 for CubeRevo
release 0.1: Cause the fourth is too much
This is the first beta release of VDR for the cuberevo.
VERY IMPORTANT : SETUP YOUR DISPLAY RESOLUTION AND DISEQC!!! SEE BELOW...
VERY IMPORTANT 2: THIS RELEASE NEEDS A DHCP SERVER IN YOUR NETWORK IN ORDER TO SETUP DISPLAY RES AND DISEQC
VERY IMPORTANT 3: WHEN USING CHANNELSCAN, SWITCH TO CLASSIC OR STTNG PANELS SKIN BEFORE SCANNING AND SWITCH
BACK TO AVANTGARDE REELSKIN AFTER FINISHING THE SCAN, THAT WAY YOU WILL HAVE A PROGRESS BAR
If you want to post bug reports, at least do the following and provide the following info:
- reproduce the error, unreproducable errors for this release are not accepted
- write down the steps to get to the bug from a fresh reboot
- write down which channel, sattelite, transponder etc.
- is the channel fta or scrambled
- how do you get the keys (cccam client, newcs etc)
- preferably try to reproduce it on astra 19.2
Setting up diseqc needs to be done in /var/vdr/etc/diseqc.conf
Features
- both tuners working, for recording and live
- shoutcast radio
- dgs picture quality
- channelscan function
- trickmode on SD.
- support for dvb-s2 (both cx and st tuners)
- support for dvb-c (might be slow on a scan)
- support for dvb-t (might be slow on a scan)
- built-in cccam/newcamd/gbox etc client
- built-in support for softcam.key
- for cam config see /var/vdr/etc/plugins/sc all vdr-sc options are available
- 3 different skins, classic, ttng and reelbox skin included
- newcs and oscam (as cardserver to vdr-sc) are included, but not configured.
- ssh and telnet started by default
- Pacco's carddriver.
Limitations
- support for CubeRevo/IPBox9000 only (I don't have any of the other boxes)
- no dvb-s tuner support.
- no timeshift
- trickmode on HD can be buggy, best not use it now
- subtitles do NOT work
- no PIP
- limited usage of front vfd (only shows stationname).
- no setup for revo specific hardware (needs to be done through files)
- no audio channel switching is possible for now.
- no teletext, can be enabled, but misses a lot of pages and eats up a lot of cpu cycles
- no support for hardware cam's.
- standby is not supported
- timer recordings are untested, please post your results
- rotor isn't supported unless it can be done through diseqc.conf, also untested (no rotor here).
- probably lots more
Configuration
username: root
password: relook
initially setup with dhcp, to change this edit /var/interfaces
Setup of screen resolution:
Manually while running: echo x > /sys/class/revo/display_res
where x is one of:
1: Pal (576i 50Hz)
2: NTSC (480i 60Hz)(untested)
3: 720p 50Hz
4: 720p 60Hz (untested)
5: 480p 60Hz (untested)
6: 1080i 50Hz
7: 1080i 60Hz (untested)
To make the setting to be set at reboot: edit /var/default/api5
To enable teletext:
Edit /var/default/vdr and add -P osdteletext to VDROPTS.
in /var/etc/init.d/user you can run any application (like newcs) prior to starting vdr.
This image does NOT format your harddisk (just to make sure everyone knows).
http://www.sat-universe.com/attachment.php?attachmentid=195414&d=1266098950
Информация отсюда http://www.sat-universe.com/showpost.php?p=551023&postcount=1
Lenina
Куратор "IPBox"
VadimIv
На 910 - будет работать? Снег есть?
Lenina
Куратор "IPBox"
Аннотацию прочитал, что-то жедания не возникло на 9000 ставить. Может быть если другого ничего не выйдет на неделе попробую. Если кто поставит опишите ваши резюме.
chewbacca
Модератор "AzBox"
А какое это имеет отношение к е2?
VDR - это вообще отдельный софт, насколько я знаю.
VadimIv
А где о нем можно почитать, желательно на русском (но не обязательно).
Собственно вопросы:
- Снег? - если это Энигмоподобный софт
- Ирдето? - если DGS-оподобный.
P.S. Мультибута, на сколько я понял там нету?
Lenina
Куратор "IPBox"
Ветки и разделы плодить не хотелось, тем более, предварительно прочитав описание, поэтому и сунул сюда просто для ознакомления. Наверное мало найдется желающих пробовать эту штуку. Тема скорее всего завянет сама собой, а если будет продолжение, то недолго и перенести в другой раздел.
Добавлено через 57 минут
И все же не вытерпел... Устанавливаю во внутрь во флашь... Ждите первых впечатлений, если загрузится... Продолжение следует.
Загрузилась... При выборе русского в меню - не буквы а квадраты. Видать шрифтов нет пока. Остался на английском...
По меню погулял, интерфейс не сложный, но все основные настройки можно сделать только путем редактирования файлов по сети. По фтп соединился, поковырял... Но файлы не поддаются редактированию (перезаписи). Поэтому не смог ни одного открытого канала отсканировать, хотя бы качество видео полицезреть. Завтра попробую поглубже познакомиться.
зы Все же несколько каналов с 75 гр. увидел. На первый взгляд качество изображения уть хуже чем на DGS, но возможно это передача такая. Возможно разрешение выставлено низкое - с этим еще надо разбираться...
Винчестер 500 гб распознался, запись производится, но при воспроизведении сыпет квадратами.
azkr
а как настроить сеть между компом что то не могу найти настройки поставил себе тоже во внутриню флеш
VadimIv
Ну просто если трабла вылечена, то вряд ли бы она появилась в новой прошивке:)
А что она таки на базе DGS, ты ставил, проверял?
Ирдето вылечено в DGS начиная c 11425 (или фикс)!
Нет - это совсем не DGS судя по этому форуму [HIDE-POSTS="7"]http://allrussian.info/index.php?page=Board&boardID=61&8088ab9e[/HIDE]
Может для 910-го сваяют..
Lenina
Куратор "IPBox"
username: root
password: relook
Я просканировал свою сеть используя программу IP Tools http://www.ks-soft.net/ip-tools.eng/ и определил адрес своего реса. У меня получился 192.168.1.33 Попробуй или этот поставь или сеть просканируй.
Реакции: azkr
VadimIv
Попробовал stick version - что-то не хочет грузиться (никаких попыток) ни с HDD ни с флешки...
Lenina
Куратор "IPBox"
Lenina
Куратор "IPBox"
C3LN Image v0.2 for Ipbox9000
21.03.2010
New release of vdr for cuberevo/9000hd is released.
This time a usb stick version, if someone needs a flash version please let me know.
Changelog: (full readme in the archive)
release 0.2: But the second wasn't enough
USB release first, flash-version will follow if requested
changes/new features:
- EPG key now opens programguide
- Recordings key now opens recordings
- fixed extended epg (tested with dutch canaldigitaal), MHW1, MHW2, NagraGuide, Freesat and some more
- fixed most could not set feed errors
- added rotor plugin (not enabled by default, add -Protor to VDROPTS, you need to disable diseqc to use the plugin)
- added webtv (point browser to http://ip-of-box:3000) using streamdev-server
- added epgsearch plugin
- added chanman plugin, to allow grouping by provider, sort by name, or use groups inside the channellist.
fixed bugs:
- channelscan: scan aborted instantly
- add video dir to /media
- play button after ffwd/rev.
DOWNLOAD IMAGE
http://www.megaupload.com/?d=4YNHYQJ3
