DM800 Official Firmware
Тема в разделе "Имиджи/Image для DM", создана пользователем market223, 11 ноя 2010.
  1. market223
    market223 Супер-Модератор Команда форума
    24 окт 2006
    8.148
    8.513
    release-dm800-3.0.0(opendreambox-1.6)
    Enigma2: Release 3.0
    Machine: Dreambox dm800
    Date: 20101111
    Issuer: Dream Multimedia
    Link: http://sources.dreamboxupdate.com/opendreambox/1.6/dm800/images
    MD5: a6d527d21ab9ef180015baca7b6db5d9
    Description:
    CHANGELOG DM800 RELEASE 3.0.0 (prev. was 2.8.4)
    System-Environment
    Opendreambox 1.5 -> Opendreambox 1.6
    upgrade linux kernel from 2.6.12 to 2.6.18
    better usb support
    better overall performance
    fixed playback of TS files bigger than 4GB from DVD
    fixed unresponsive network interface
    fixed slow network speeds while reading from cifs mounts
    better hotplug support (enable read/write access to automounts)
    faster startup from deep standby
    enigma2 (20100628 rel28 -> 2010111 rel30)
    [System]
    introduced support for unicable switches and lnbs
    add possibility to change the default recording filename
    add possibility to configure input device delay and repeat settings (i.e. remote control and keyboard)
    ignore mute/volume keypresses in standby
    fixed invisible mute symbol after tuxtxt close
    fix frequently ineffective timeshift/record stop
    handle keyboard entries in wizard correctly
    some improvements in skin engine
    add possibility to change the behavior of a short power button press via usage config
    add possibility to change the composition of recording filenames via usage config
    fixed a timer sanity check bug
    [Servicelist]
    add possibility to show a progress bar per service event in the channel selection (see usage config)
    update default favouritelist and servicelist
    [ParentalControl]
    fixed invisible lock symbol in parental control edit lists
    fixed some parental control problems
    [Movieplayer]
    fixed broken SRT subtitles
    properly add timers from inside the movie player
    add support for rtp/rtsp playback (e.g. used by ZDF Mediathek plug-in)
    [Menu]
    moved subtitle selection to audio track selection menu
    [Translations]
    general translation updates and fixes
    fixed arabic support (inversed order of rows)
    [Softwaremanager]
    ask to overwrite configuration files during upgrade
    add configuration screen on menu button
    show files that will be backed up inside own info screen
    better offline plug-in management
    [Plug-ins]
    MyTube: fix possible crash while decoding thumbnails
    MyTube: fix video playback and search suggestions
    DVDBurn: fix order and correct association of languages and audio stream files and set a limit of 8
    drivers (20100628 -> 20101111)
    migrated to more recent LinuxTV API (support the official S2 API now)
    add support for new DVB-C/-T tuner module
    add support for new DVB-S2 tuner module
    fixed buffer underrun problems on H264 HD live decode
    fixed buffer underrun problems on AAC-HE live decode
    fixed problems on greek HDTV services
    add new interface to vtuner for better performance
    http://dreamboxupdate.com/opendreambox/1.6/dm800/images/release-dm800-3.0.0.nfi
  2. orangfox
    orangfox Новичок
    16 июн 2008
    2
    0
    А на китайский клон dm800 эту official firmware можно устанавливать?
    И что она дает?
  3. market223
    24 окт 2006
    8.148
    8.513
    orangfox, можно , но только потом будете осваивать прошивку через СОМ порт. Для клонов нужны патченные прошивки.
    orangfox нравится это.
  4. nafan
    nafan Профи в Сат-ТВ
    4 июн 2010
    152
    127
    даже с сим 2.01 #76D ?
  5. market223
    24 окт 2006
    8.148
    8.513
    nafan, да хоть с чем, Если конечно симка не ферарри.
Похожие темы
  1. vic
    Ответов:
    581
    Просмотров:
    110.625
  2. Viraje
    Ответов:
    47
    Просмотров:
    11.431
  3. seal
    Official image VU+
    seal, 10 авг 2010, в разделе: VU+
    Ответов:
    6
    Просмотров:
    7.673
  4. seal
    Ответов:
    1
    Просмотров:
    2.224
  5. wizsatz
    Ответов:
    4
    Просмотров:
    3.202
Загрузка...
Поделиться этой страницей
