DM800HD Clone Patched Images (Sim 2.01 SSL#84D OE2.0)
halfhalf
BlackHole2.1.3.DM800HD.SIM2.OE2.0.SSL84D.byHouara.14.11.2014.Clone
MeoBoot updated and now compatible with all major images
New Army skin DarkSky
New fade effect in osd
OpenWebIf updated and added Italian translation
Httpstream updated:
- added chunked transfer support.
- connect to TS stream in seperate thread.
- add basic http authentication support.
- add redirect and playlist support.
Elistbox: add setFont function (workaround for Full Hd skins)
media-tree rebuilded module list
opkg install /tmp/*.ipk
BlackHole2.1.3.DM800HD CLICK LINK
OTHER NEW IMAGES CLICK LINK
SEPTEMBER 2014 DREAMBOX IMAGES
OTHER OLD IMAGES CLICK LINK
halfhalf
ruDREAM3.0.DM800HD.SIM2.OE2.0.SSL84D.byHouara.11.11.2014.Clone
-converted from DM800se to DM800
-Patched to DM800 Boxes
-Patched Time limited for watching channels
-Added last drivers 20131228
-Added last version my modded OpenWbif
-fixed WLAN Connection
-Edit Python math to make image full compatible with DM800HD
About Emus How to
1-Form attach download and install emu
2-After installed:
*Blue button
*Select Emu and press OK buttin
About Change emu panel style How to
Exit button
settings
TV
Customize TV
Setup of CAMD profile select mode (simply or expert)
About Hid update check info How to
Exit button
Settings
Software
Settings packages management
check for update = off
About Restart shell (enigma2) How to appear it
Exit button
settings
system
customize system
setup mode = Expert
About remote control How to adjustment
Exit button
settings
system
input device
press ok to dreambox remote control (native) and adjustment as you like ..
Warningon't Make Update Online
In this link you can Download 2 skins for Image
In this link you can Download some plugins for Image
From here you can download my modified DD_Subtiteplayer V2.39 for ruDREAM image only
opkg install -force-overwrite /tmp/*.ipk
PLUGINS SKINS PICONS SUB CLICK LINK
ruDREAM3.0.DM800HD ALTERNATIF 1 CLICK LINK
ruDREAM3.0.DM800HD ALTERNATIF 2 CLICK LINK
---------- Сообщение добавлено в 20:04 ---------- Предыдущее сообщение размещено в 20:03 ----------
---------- Сообщение добавлено в 20:06 ---------- Предыдущее сообщение размещено в 20:04 ----------
Httpstream updated:
halfhalf
halfhalf
Blackhole2.1.3.Genuine.DM800HD.SIM2.OE2.0.SSL84D.byRAED.13.11.2014.Clone
Httpstream updated:
enigma2-plugin-extensions-tspanel_7.3_mips32el.zip
install
Blackhole2.1.3.Genuine.DM800HD byRAED CLICK LINK
Blackhole2.1.3.HD_X1.DM800HD.SIM2.OE2.0.SSL84D.byHouara.14.11.2014.Clone
Blackhole2.1.3.HD_X1.DM800HD CLICK LINK
halfhalf
BlackHole2.1.3.Doscam.CCcam.Mgcamd.OE.2.0.SIM2.DM800HD.SSL84D.17112014.byMarwen.Clone
*bootloader: ssl84d
*New Fix Teleportation by raed
*New bootlogo
*New po arabic language
*Teletext patched and tested
*Positionersetup Patched
*EMU: CCcam2.2.1 ;Mgcamd1.38C;Doscam0.23 TNTsat autoupdate
*New keymap.xml Mod almwad3:
-record with red button
-timeshift with yellow button
*plugin nstreamplayer updated
*Extra Plugins (You Install)
-Wicard plugin
-Tspanel 7.3 Plugin
-DD_Subtitle-Player
-Extrachannelselection_for_blackhole_2.6
or
BLACKHOLE2.1.3 CCCAM and DOSCAM
BLACKHOLE2.1.3 CCCAM and DOSCAM CLICK LINK
BLACKHOLE2.1.3 MGCAMD and DOSCAM
BLACKHOLE2.1.3 MGCAMD and DOSCAM CLICK LINK
halfhalf
BlackHole2.1.3.Doscam.CCcam.Mgcamd.OE.2.0.SIM2.DM8 00HD.SSL84D.23112014.byMarwen.Clone
23/11/2014:
*New bootlogo
*Fixed Arabic Epg Language
*Add Patch Teleportation V2.1
*Skin.xml:Fixed screen Reorder Plugin List
17/11/2014:
*bootloader: ssl84d
*New bootlogo
*EMU:CCcam2.2.1 ;Mgcamd1.38C;Doscam0.23 TNTsat autoupdate
or
BLACKHOLE2.1.3 CCCAM2.2.1 and DOSCAM023
BLACKHOLE2.1.3 CCCAM2.2.1 and DOSCAM023 CLICK LINK
BLACKHOLE2.1.3 MGCAMD1.38C and DOSCAM023
BLACKHOLE2.1.3 MGCAMD1.38C and DOSCAM023 CLICK LINK
halfhalf
BlackHole2.1.3.Update.DM800HD.SIM2.OE2.0.SSL84D.byMarwen.27.11.2014.Clone
28/11/2014:
* New Plugin Blackhole Addons (Blackhole Cams)
* Now you can Download All Cams
* Patch Freesat Epg Data
23/11/2014:
* New bootlogo
* Fixed Arabic Epg Language
* Add Patch Teleportation V2.1
* Skin.xml:Fixed screen Reorder Plugin List
BlackHole2.1.3.Update.DM800HD CLICK LINK
BlackHole2.1.3.Update.DM800HD ALTERNATIF CLICK LINK
halfhalf
BlackHole2.1.3.New.Update.DM800HD.SIM2.OE2.0.SSL84D.byMarwen.30.11.2014.Clone
30/11/2014:
* Original Blackhole Teleportation
*Extra Plugins You Install
-Wicard plugin
-NEW Tspanel 7.4 Plugin
-DD_Subtitle-Player
or
28/11/2014:
* New Plugin Blackhole Addons Mod Marwen (Blackhole Cams)
23/11/2014:
* New bootlogo
BlackHole2.1.3 New Update DM800HD CLICK LINK
OCTOBER 2014 DREAMBOX IMAGES CLICK LINK
SEPTEMBER 2014 DREAMBOX IMAGES CLICK LINK
halfhalf
VTI.8.0.0.DM800HD.SIM2.OE2.0.SSL84D.byHouara.01.12.2014.Clone
With modular, flexible VTi Skin: Atile HD
VTi Bootlogos and Radiomode Logo.
Short press on blue button opens VTi Panel, long press opens Pluginmenu
Support for FTDI chipset cardreader like smargo and easymouse2
Running Softcam shown in the Infobar
MovieList with extended functions
Support for full image backup and restore
Supports VTi image flash online
Restore Plugins, Bouquets, Settings, etc. during installation
Remove preinstalled packages during installation
-I have converted and patched VTI (VU+) Image to Dreambox
-Edited opkg feed
-Fixed WLAN Connection
-Edit Python files to make image full compatible with DM800HD
-Front screen (Not fixed yet)
About remote control How to adjustment >>
menu
setup
system
input device
How to Download Cams and Active it:
1-Blue button > Blue button (Cam Center) > Blue button (Manage Cams)
2-Then select and download what you need
3-To active cam press Blue button > Blue button (Cam Center)
4-Select Cam and press Green button (Start Cam)
Warning:Don't Make Update Online
VTI.8.0.0 DM800HD CLICK LINK
OTHER NEW 2014 END IMAGES CLICK LINK
halfhalf
---------- Сообщение добавлено в 21:23 ---------- Предыдущее сообщение размещено в 19:36 ----------
halfhalf
BlackHole2.1.3.Wifi.DM800HD.SIM2.OE2.0.SSL84D.byMarwen.06.12.2014.Clone
06/12/2014:
*Kernel image updated:Add Support for all drivers Wireless
*Blackhole Addons Server updated:Add all drivers wireless
30/11/2014:
-Wicard plugin
-DD_Subtitle-Player
or
BlackHole2.1.3 Wifi DM800HD CLICK LINK
halfhalf
BlackHole.2.1.4.New.Version.DM800HD.SIM2.OE2.0.SSL84D.byMarwen.07.12.2014.Clone
07/12/2014:
-Wicard plugin
-DD_Subtitle-Player
or
BlackHole.2.1.4 New Version DM800HD CLICK LINK
halfhalf
PKT.Hyperion.v4.5.DM800HD.SIM2.OE2.0.SSL84D.byHouara.08.12.2014.Clone
Added by PKT: Additions to the original device
[ALL] fix cam start at startup tuner
[XPEEDLX] Add Correction time in deepstandby
[ALL] fix scrollbar
[SH4] add new WiFi Driver Manager
- restart GUI is required to detect WLAN stick on main network setup
- all drivers directly from GIT should be supported
- 'try driver' can be selected only when all driver is inactive
- eth0 is automatically up when 'disable driver' is selected
[ARIVA] fix vfd plugin
[ariva] GS fix on ledREC
[SH4] samba update and 2GB fix
[sh4] fix samba setup if IPV6 in kernel is enabled
[sh4] update rtmpdump and librtmp for IPTV Player
[sh4] eplayer image in NOR 32MB optimalization
[SH4] SyncTime - fix update script
[mips] fix tuxtxt encoding
[sh4] Removed CrossEPG from image - now only on feed
[sh4] add Remote Manager
[sh4] add mount by LABEL in HDD Manager
[spark] fix multiboot
[UFS910] fix networking restart
[MIPS] fix start/stop/restart emu on standby
[MIPS] fix NetworkBrowser on sf8
[MIPS] add hbbtv indicator on Silver & Red skin
[ALL] fix detecting network interface and code optimization
[SH4] fix esi cooler standby
[MIPS] Shoutcast update
[all] add Memory Cleaner
[MIPS] fix Channel Control
[MIPS] fix GS on InpuDevice
[all] add NTFS to HDD Manager and ntfs-3g support
[MIPS] fix Start DLNA server
[MIPS] fix time correct on xpeedlx1
[MIPS] fix showing CPU clock
[ALL] add IPTV Player optimalisation
[CUBEREVO] fix BootPlus
[SH4] disable clear cache for UFS910
[MIPS] add missing renderer for better skins compatibility
[SH4] add UFS913
[ALL] fix manual backup restore
[MIPS] add mising files for LCD4Linux
[ALL] many other bugfixes not included in this changelog
NOTE: Some features may not work DreamBox.
* Try it and see
-LCD panel fixed
-Opkg feed fixed
-Added last drivers 20131228-r7.0
-Edit some python files to make image full compatible with DM800HD with plugins
-I have fixed WLAN Connection
How to download emus (Cams)
Menu > Plugins > Green Button (Download) > Enu
How to Active emus (Cams)
Blue Button > EMU Manager
menu
setup
system
input device
PKT.Hyperion.v4.5 DM800HD CLICK LINK
halfhalf
OpenATV4.2.New_5_Skins.DM800HD.SIM2.OE2.0.SSL84D.byHouara.11.12.2014.Clone
OpenATV4.2.Blacky.Green.DM800HD.SIM2.OE2.0.SSL84D.byHouara.11.12.2014.Clone
OpenATV4.2.Blacky.Green DM800HD CLICK LINK
OpenATV4.2.Blacky.Orange.DM800HD.SIM2.OE2.0.SSL84D.byHouara.05.12.2014.Clone
OpenATV4.2.Blacky.Orange DM800HD CLICK LINK
OpenATV4.2.Red_DarkHD.DM800HD.SIM2.OE2.0.SSL84D.byHouara.28.11.2014.Clone
OpenATV4.2.Red_Dark DM800HD CLICK LINK
OpenATV4.2.Black.Pink.DM800HD.SIM2.OE2.0.SSL84D.byHouara.05.12.2014.Clone
OpenATV4.2.Black.Pink DM800HD CLICK LINK
OpenATV4.2.MambasV6.DM800HD.SIM2.OE2.0.SSL84D.byHouara.05.12.2014.Clone
OpenATV4.2.MambasV6 DM800HD CLICK LINK
