Dreambox DM 800-SE HD PVR DVB-S2
allllex
Dream Multimedia официально объявила о начале продаж обещанного нового бокса
Dreambox DM 800-SE HD PVR DVB-S2 Tuner
http://www.dream-multimedia-tv.de/dm800-hd-se-im-handel
И он уже реально появился в тех шопах, в которых его можно было пред заказать.
Заявленная цена - 499 евро.
Наверное в этой ветке и будем пока его обсуждать.
ORIGINAL - NO CLONE
Powerful receiver for digital TV and Radio programs.
Main features are a 400 MHz processor
the Dreambox DM800 SE+ (plus) supports the Linux TV API
have a look to HighDefinition TV on your Dreambox
10/100MBit compatible Ethernet Interface
DVI connector
plug & play Tuner
brilliant OLED display
SATA for use either as internal HDD 2,5" or eSATA
- 400 MHz MIPS Processor
- Linux Operating System
- OLED - Display
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S, optional: DVB-C, DVB-T
- Tuner Module, Plug&Play
- 1 x Smartcard-Reader
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 1 x Scart (RGB, FBAS or S-Video)
- HDMI
- 2 x USB 2.0
- analog modem
- S/PDIF Interface for digital bit stream out (AC-3)
- 64 MByte Flash, 256 MByte RAM
- SATA
- for use either as internal SATA HDD 2,5?
- or to use for extern eSATA
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- automatic service scan
- directly bouquet-lists
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
- extern 12V power supply
DreamBox DM800 SE technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 ? 31 Mbaud/s (8PSK) , 10 ?30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
- for use either as internal HDD 2,5? or eSATAor internal 2,5" HDD
USB
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0APhysical specification:Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H):195 mm x 140 mm x 40 mm
Viraje
"Вань, и я такую же хочу..."
allllex, зная Вас, наверное уже заказали? Когда побалуете обзорами?
seal
Администраторы
Новый цветной дисплей OLE на передней панели Dreambox. На задней ожидается пользователей включают в себя два порта USB 2.0 и выход HDMI для без потерь передачи на ТВ.
Кроме того, используя внешние ESATA жестком диске. На передней скрыты под крышкой два слота для смарт-карт.
Малошумящий вентилятор охлаждает жесткий диск для дополнительного использования. Расширенный тюнер обеспечивает еще более получения стабильности, и новый процессор увеличивает скорость компактных Linux-приемником.
seal
Администраторы
Viraje, 700 бачков и это без доставки. дрим малтимелия просто припухает.
allllex
Нормальная цена для дрима. И можно не ждать, что она опустится. Я ждал, что если опять тянуть резину будут, плюну и куплю VU. Но теперь даже не сомневаюсь в выборе.
seal
Администраторы
allllex, давай его для начала хоть глазами увидим.
Viraje
С одной стороны согласен с Силом, но с другой стороны проверенная в бою железяка с улучшеным процессором и с полноценным ХДМИ(правда его преимущество над ДВИ спорно) не намного и дороже от старого 800.
Как по мне дык тоже цена адекватна по сравнению с обычным 800.
seal
Администраторы
Viraje, а меня чето жабка душанула :)
allllex
А что на него смотреть? Он же не баба, какой будет, такой будет. Только в Латвии в шопе он пока висит как предзаказ и на 100 долларов дороже. Не знаю даже, где лучше брать.
_http://lat.pult.lv/index.php?productID=3980&sent=yes#inquiry
Я хитрее сделал, свой старый 800 отдал заранее детям в обмен на Азик, и развязал себе руки. А что азик не аппарат, они сами на своей шкуре почувствовали. Так что у меня руки развязаны.
И у нового бокса новый тюнер, так что может этот не будет глючить с дайсиками при сканировании...
Viraje
MOB30
Имея 500-ый считю вообще нет смысла запорачиватся, даже с тем, чтоб посмотреть. Цветных дисплее я чтоль не видел ?
Я так же как многие, видимо, 7020HD не дождался и взял пока поигратся Vu+.
allllex
Михаил Евгеньевич, имиджи уже 2 месяца как появляются
MOB30
KIV-62
Да это нормально. В меня вцепилась и не отпускает:)
Но когда ей объясняю что это Дрим то она успокаивается!yea!
Да такая же реакция была и на появление DM 8000 HD,но прошло пол года и
народ начал покупать этого зверя!yea!,тоже самое будет и с DM 800-SE HD.
