Эмуляторы и кардсерверы..
NewCS-1_60-beta
v.1.60 *beta*
Fixed ECM/EMM Cache, should now be OK again. (strange noone noticed this one long time ago?!)
Added support for DM800 Sci. (needs more testing though..)
Completely rewritten Chameleon, now called Chameleon2.
Removed support for the Feynman protocol as its wasnt a success, and we dont have time to maintain it.
Fixed bug to address comports higher then com9 on win32.
Fixed EMM bug on irdeto.
Fixed bug where user would be disabled when changing the users through WEB-console.
Added provider 0106 and 0907 in nagra2.
Added support for the QNAP NAS's.
Added support for the Freetz routers.
Now using Kamikaze env. for compiling OpenWRT binaries.
Fixed -march=i386 on i686, should now be i386 compatible.
Added boxdetect for more platforms. If your box isnt detected ok, please post your /proc/cpuinfo.
Fixed WEB-console on win32, added it on all archs.
Added backup of configfile before writing to it. (/tmp for linux, and C:\temp for win32)
+++ maaany other bugfixes and cosmetic fixes.
1.-- Chameleon v2 - the newcs P2P ------- --- -- - - -
Chameleon has been completely rewritten.
We now use our own encryption algorithm, instead of ssl. It seemed that the embedded libraries meant for small devices, just arent
stable enough for our use. With this change we removed 90% of the segfaults in newcs.
Chameleon and Chameleon2 is *NOT* compatible, config section has changed to <chameleon2> to reflect that.
The principles is *almost* the same as in Chameleon v1. We no longer have distributed card lists though, a client has to scan the net
for a given caid/provider. ATM. _only_ mgcamd works with chameleon, you have to set <cardlevel>1</cardlevel> in the newcamd user, and it
will get a bunch of virtual cards that it can use. (the autoscan and more dynamic way of doing this is beeing worked on).
This is still a work in progress )
We will be happy for any feedback
http://forum.sat-expert.com/attachm...d1211365063-katrain-emuliatory-newcs-1.60.rar
http://rs323.rapidshare.com/files/11...newcs-1.60.rar
krycek
А у меня такая проблемка - тот сервер шары, к которому я подключён, нормально шарит виасат только на на mgcamd1.29,
а на 1.30 затыки каждые несколько секунд :( Так вот в имидже Nabilosat0.3, который я юзаю в панели аддонов можно
скачать только 4 версии 1.30, а 1.29 нету, где взять - ума не приложу, ни один mgcamd из обычного комплекта не подходит :(
alexeyf
А как Самд3 или Ньюкамд поставить в Джемени 3.80 ?
А то шару дают по ним.
Заранее спасибо
vitek049
Здравствуйте подскажите пож почему при установке e2-mgcamd_1.30a-newcs_1.60.tar.gz в dm 800 после перезагрузки ресивера все равно в blue panel этого эму не видно? пробовал ставить и в ручную с назначением атрибутов 755 и из панели-все равно никак не видно:(
Free_mic
могу ошибатся-но на AB ipBOX
ставят от Kathrein UFS 910
я не пойму, м моем 7025 при нажатии синей кнопки открывалось меню с плагинами шары, а тут только таймер, в меню установить планины не вижу откуда скачать MgCamd_1.31 и его конфиг,и также Camd3.902. Подскажите плз, что то торможу, обновил все через инет.
Энигма стоит tenigma2 rel24 Oct 25 2008
pau22
Новый CCcam 2.1.0
-keep persistant ecm counts for clients
-i2 emu
-IGNORE NODE option (see CCcam.cfg)
-emm caid tunneling
-Added seca handler to prefer or ignore SECA2 or SECA3 (see CCcam.cfg)
  • CCcam-2.1.0.zip
    1,8 MB · Просмотры: 47
Diablosss
есть MPCS для DM800 нормально работаюший с SID- ами ?
то что нашол вроде 1/6b не правильно работает с SID . может есть более новая версия ?
Diablosss
нет... есть некоторые функции с которыми я думаю MgCamd не справитса, а может и справитса просто я не знаю.
а именно нужно идент привязать к серваку...
например есть два сервака сервер1 и сервер2
сервер1 шарит только +++
сервер2 шарит +++ + HD
так вот мне нодо чтобы все обычные SD каналы показывало с сервера1, а HD каналы с сервера2.
но не выходит. как только переключу на HD, посэтого переключаюсь на SD шара продолжает идти с сервер2
Добавлено через 7 минут
интернет сглючил..... Админы поправьте плиз
bonchik
А разве нельзя на Дриме привязать идент к конкретному каналу ?
Diablosss
а можно ? =)
на опенбоксе можно =) а на дриме не знаю как это сделать
sat.evo
Модератор Evolution
Подскажите есть где то подробное описание как настроить дрим 800й под сервер,есть официальная карта нтв+,хочется шарить внутри сети еще пару тюнеров
Rhezus
официалка уже работает на дриме?
если да - то просто добавляешь в newcs.xml нужных юзеров и все.
sat.evo
Модератор Evolution
Официалка уже работает!Но если можно по подробнее,в какие строчки именно прописывать юзеров,и как оно должно выглядеть,если не трудно можете выложить пример?
sathacko
зареься и прочитай может поможет hххp://www.allrussian.info/index.php?page=Thread&threadID=43809&pageNo=2
