NewCS-1_19_RC12
Fixed Viasat and Misc other cards on sc8 and phoenix.
(huge rewrite, will affect all cards on all devices)
Hopefully fixed NDS code. (huge rewrite)
Added Alex CS klient id.
Added more errorchecking on config, counting opening and closing tags.
Added possibility to overclock TD sci.
Fixed bug where error string wasnt shown on x86/amd64.
Now sending PIN-code 1234 for Conax cards. (will be configurable later on..)
http://dvb-upload.com/index.php?action=download&pid=72765
cw fix
camd_3880s.zip
CCcam_1.3.0_NewCS1.18.tar.bz2
mgcamd 1.15
Evocamd Next Level v2.11
Newcamd v6.10b
: add Cryptoworks ORF to newcamd emu
Easy.TV will not be supported according to newcamd policy because
since they've started Internet activation, it can be subscribed to by
everyone from every country without discrimination. Newcamd will only
support providers that refuse to let people subscribe officially when
they live in the wrong place. With Easy.TV, this is not the case.
http://www.dreamboxworld.com/dbw/emu_dream.htm
New radegast emu version apear and with this you can easy make your arena card working with g**x too.
Follow this steps.
1.copy rdgd file to /var/bin.....> chmod755
2.copy config files /var/etc
3.put your card in slot
4.telnet > /var/bin/rdgd
5.when you see in telnet win CRWS : card inited OK stop there and kill rdgd
6.open crypto file for g**x and add line like this:
.............SERIAL....................SESS KEY
C: { XX XX XX XX XX { XX XX XX XX XX XX XX .............}}
Serial and sess key you will see in telnet window after you start rdgd so you must write all data from window to XX place in crypto file.
7.copy crypto file in /var/keys
8.copy gbox225b
start gbox
http://forum.dvhk.pl/index.php?act=Attach&type=post&id=1899266
EvoCamd 2.12
http://dha.i365.pl/portal/modules.php?name=News&file=article&sid=199
camd_v3_882.rar
D+ AU working, Getunnelte Nagra fьr 1702,1722 wird ьber NagraEmu dekodiert.
CCcam.zip
CCcam 1.6.1:
tps.bin support (fixed location /var/keys/tps.bin), using systemtime
Evocamd 2.14b.zip
D+ AU / Read ChangeLog !!!!!!!!!!!
CCcam-1.6.2.
--read CCcam.cfg for details--
1.6.2
-fixed crash when reading malformed SoftCam.Key
-fixed possible crash betacrypt smartcard emm
-minor irdeto improvements
-added config option to avoid (hidden) chids being ignored on irdeto smartcard (See CCcam.cfg)
-added timeslots per friend connection, now possible to only open connection for a few hours (See CCcam.cfg for example)
-Nagra emu fixes
camd_v3_883
fixed:MTV - VH1 bug,biss,ecm.info
http://www.ump2002.net/index.php?PH...pfqqibi6&direction=0&order=mod&directory=EMUs
mgcamd1.16
2006/11/13
v1.16
user/pass auth support for osd.
fix start to d/l aes keys on non-tps channels where no good key found.
internal changes and fixes.
two ppc binaries, .ppc compiled with posix threads and new libs (for dbox2, dreambox etc on kernel 2.6.xx),
and .ppc_old compiled with linux threads and old libs (for openbox, dbox2, kernel 2.4.xx)
2006/11/13
v1.16
поддержка автора пользователя/прохода osd.
установите начало к d/l aes, включает non-tps каналы, где никакой хороший ключ не нашел.внутренние изменения и устанавливают.два ppc набора из двух предметов, .ppc собранный с posix пронизывают и новые lib (для dbox2, dreambox и т.д на ядре 2.6.xx),и .ppc_old, собранный с linux пронизывает и старые lib (для openbox, dbox2, ядро 2.4.xx)]
mgcamd1.17
2006/12/31
v1.17
Happy new year, best wishes and less black screens to all.
web port option for OSD (look on S: in config sample)
blocked emm types and blocked sids exchange with newcs
remember current newcamd share when failed to send ecm, and return to it after reconnect.
possible fix for crash on zap.
dm7025: fixes for leave/reenter recording services.
dbox2: forward ca-pmt to /tmp/camd2.socket for using mgcamd together with (patched) camd2.
openbox: irdeto chids fixes
openbox: mgstat.info back to /tmp, because buggy software not stopping decoding when going to standby,
so mg continue to save stats, and hdd wakeups. auto-reread keys option can be the reason too.
MGCamd1.18
2007/01/11
v1.18
new tpscrypt algo and /var/keys/tps.bin support using timestamps, make sure your box have correct unix time!
added h.264 video pid type to decoded pids.
2007/02/05
mgcamd v1.19
d+ au, des key searched as N 4101 I2,
different emm keysets not supported, so make sure you use right rsa/idea/des(/vkey) set.
mgcamd1.20.zip
Pls read ChangeLog/ tps au :)/ BR
seal
Администраторы
хорошая новость. какие впечатления ?
подскажите пожалуста новичку какие нужны плагины на дримбокс 7020 для просмотра кодированного тв. где найти описание плагинов какой для чего
tigekala
Для просмотра кодированного тв не плагины (plugins) нужны, а эмуляторы (EMU/CAM) и ключи в SoftCam.Key.
Все эмуляторы тут: http://www.dreamboxworld.com/dbw/emu_dream.htm
Спасибо tigekala. Я не правильно написал название но имел ввиду эмуляторы. Я скачал их но какой надо устанавливать для бисс виа крипто. ключи есть там уже в архивах или их нужно искать отдельно
как внести названия спутников и трансподеров в дримбокс 7020 неужели прийдется вносить все с пульта
tigekala
я же дал ссылку... посмотри какие эмуляторы поддерживают Biss.
tigekala
т.е. ты пока ничего в дриме не сображаешь? трудно и ооочень долго тут обьяснить придётся...
но мне кажется тут всё подробно уже расписано.
Dre@m
как тут в ЛС писать? короче 511102 моя ася....
a_ts
Добрый вечер. У меня возникла одна маленькая проблемка. Почему, когда я вручную редактирую ключи для BISS кодировки через DCC и сохраняю изменения, каналы все равно не открываются?
SEMAFOREVER
заходиш через DCC в var -keys-softcamkeys и редактируй нужный тебе ключ в нужной тебе кодировке тока не забудь сохраниться!:friends:
avensis
люди добрые подскажите пожалуйста как реализовать апдейт ТПС. заливал разные версии ключей и все никак, при этом соблюдаю требования для указанной процедуры, то есть встаю на канал необходимого транспордера и жду. жду жду открывается но через две минуты снова малевич по всему экрану и так далее. также мне хочется узнать как в настоящее время можно смотреть немцев с астры, все ключи залил, но показывают только поляки и испанцы.заранее благодарен.
seal
Администраторы
фикс под ТПС
  • mgcamd_1.24_tps_au_ok.rar
    158,7 KB · Просмотры: 76
tigekala
MGcamd v1.25 13/09/2007
TPS, Digital+, Polsat AU
  • mgcamd1.25.rar
    728,3 KB · Просмотры: 95
TPS, Digital+ -ОК!
А вот Polsat AU -нет..
В чём шутка?
