Enigma2 NightlyBuild 0.7.5
Lowik
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
Enjoy it! Tideglo
http://enigma2.sifteam.eu/index.php?dir=Enigma2 NightlyBuild 0.7.5/
Lenina
Куратор "IPBox"
Установил на 9000 внешнюю, поставил Эму-менеджер от Искана, но почему-то мжкамд не хочет запускаться. Может руки кривые... У кого как? Наверное много лишнего сделал, буду Эму-менеджер по новой пытаться переустановить по совету Николаевича на форуме Искана.
P.S. Переустановил Эму-менеджер, мжкамд завелся, но поймал снег на канале Спорт-HD (+++) через 40 минут.
Просьба к Искану или кто знает, можете выложить под эту версию еще и Mount-менеджер?
igoron
по ходу модуля для монтирования сетевых дисков cifs нету....
Что делать?
nikolasi
Есть у меня друг использующий скин rihanna_black.Вот этот скин под эту версию...market223-для тебя пределал...
  • rihanna_black.rar
    629,7 KB · Просмотры: 7
