Lenina
Куратор "IPBox"
Enigma2 NightlyBuild 0.9.5
release 0.9.5
- back to STLinux 2.2 because of some audio bugs on STLinux 2.3: when i will fix it, we will go again on stlinux 2.3
- added wmv file player
- added multi descrambling feature: i tested it only with incubusCamd 0.99 wich fully supports multidescrambling
for e2 (previous version don't work, and i don't know if other softcams works or not, just test them)
- fixed some memory crash on h264 channels
- fixed remote controller buttons with teletext activated
- fixed DVDPlayer crash
- DVDPlayer buttons are now better showed than before
- supported DTS audio on mkv files
- other MediaPlayer fixes
- updated greek language
- updated bulgarian language
- added samba (not started by default, you have to add it on the rcS_user.sh if you need it)
- added cp2101 external card reader drivers (load it in rcS_user.sh if you need it: /lib/modules/cp2101.ko)
- added ralink rt2870 wireless chipset drivers (load them in rcS_user.sh if you need it: /lib/modules/rt2870sta.ko)
- added Freesat EPG support
- by default the sci-ng driver (pacco's 1.4 version) is loaded at enigma2's boot: this is a temporary option, i built a
sc driver but still getting many memory errors, i don't know when it will be full ready
- update Enigma2 CVS to 02/05/2010
- enabled again PIP function, watching 2 channels on PIP will make slow live channels playing, so it does not work at 100%
Enjoy it! Tideglo
http://enigma2.sifteam.eu/index.php?dir=Enigma2 NightlyBuild/Enigma2 NightlyBuild 0.9.5/
release 0.9.5
Enjoy it! Tideglo
