Имиджи для AB IPBox 9000HD
janigor
azkr
Появился новый имедж
AB IPBox HD/9000HD_Images - official/AB_9000HD_070808_r7932_usb_all_noboot.zip
Popis súboru
AB IPBox 9000HD image based on DGS r7932
* R7932 *
* FIXED
- Instant recording with EPG - STB crashed after stop
- MP3 player - doesn´t play next file
- playback dropouts
- time setting
- doesn´t boot without LAN connection
- Polish and Russian menu language updated
* doesn´t fixed
- doesn´t supported USB HDD , after some time with working USB HDD STB freeze.
* IMPROVED/ADDED
- automount for USB device
- UK/Ireland cable providers database
- plugin start afer cold OFF
- new basic setting for Astra 19.2E, Astra 23.5E and Hotbird 13E with HD channels from Thor 08W
- FAT 32 support for USB stick device
- edit function for photos and MP3 files. You can copy files from USB device to HDD and back.
Recommended uboot 1.3.1 .
Photo album start - Press "Photo" button on RCU
MP3 player start - Press "Music" button on RCU
ftp login/password: root/ipbox
Software upgrade from USB memory stick (host) :
This function supported only uboot 1.3.1 !
• backup important data from memory stick before try to update. Remove all data from it.
• copy image file to USB stick and rename to "usb_update.img"
• run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen.
• turn off the stb(Standby + OK) and insert the memory stick.
• press and hold Standby button until front display shows “BOOTING” and press UP key
(on the front side of the box, not on RC), then front display shows "USB UPGRADE" message..
• uboot will update s/w with usb_update.img from memory stick
• Wait until DONE message displays. Restart your receiver.
janigor
* R7932 *
* FIXED
- MP3 player - doesnґt play next file
- playback dropouts
- time setting
- doesnґt boot without LAN connection
* doesnґt fixed
- doesnґt supported USB HDD , after some time with working USB HDD STB freeze.
* IMPROVED/ADDED
http://rapidshare.com/files/135875850/AB_9000HD_070808_r7932_usb_all_noboot.zip
janigor
NLB7932 based on DGS SVN7932
* Updated to SVN 7932
* fixed: EVOCAMD script now support /var/bin/evocamd
* fixed: MGCAMD script fixed to work with binary /var/bin/mgcamd
* fixed: network DHCP correctly initiated at first boot only
* fixed: skin blue/grey - channel search not working
* fixed: firmare upgrade from webif
* included: cool,nlb_blue_nlb_grey skins from @crash
* --------- no downloads needed
* --------- nlb_blue is default used now
* included plugin: hddtemp v0.0.6 by kneubi
* included plugin: script v0.0.2 by kneubi
* updated: Danish menu language file
* * remember to upload configs/files into /var/keys
http://rapidshare.com/files/135903163/nlb7932_ip9000.zip
SifTeam-0.1.4-r7932
################# SifTeam-0.1.4-r7932 #################
versions.8793303423:SifTeam-0.1.4-r7932.app_db=SifTeam-0.1.4-r7932
[version.desc.SifTeam-0.1.4-r7932.app_db]
Based on "OFFICIAL" SVN revision r7932.
Your database will be reset, if download this version.
*** NO KEY-EMU INSIDE ***
*From 0.1.4:
plugin for system option
http://rapidshare.com/files/135969499/SifTeam-0.1.4-r7932.rar
Viraje
New SIF image 8022
azkr, раз Вам нравятся иминджы от SifTeam, потестируйте и отпишитесь.[/HIDE]
azkr
Появился новый имедж от команды nlb
barsuk72
CubeRevo nlb8022
Unofficial Custom release - no limits board --> http://www.nlb.to
WEBIF
login: root
password: relook
* Updated to SVN 8022
barsuk72
Download here nlb8022v2
updated: mbox II (5.9.2008 update3) now included
changed: mgcamd and mbox can now be stopped from webif
included: default mbox setup with newcs and internal cardreader
azkr
Появился новий имедж от SifTeam можно взять здесь
Viraje
barsuk72
nlb8022v3
zip includes ip900 and ip9000 image.
updates;
include: mbox 10.09.2008
changed: mbox fix for viasat channels
-------: restarting mbox did not clear channel without change channel
changed: soft update script now correctly uses /var/bin/soft
-------: selectable from -assign button- menu too
почтовый включает ip900 и ip9000 изображения.
обновлений;
включают в себя: mbox 10.09.2008
изменение: mbox Коррекция viasat каналы
-------: Перезапуска mbox не ясно канала без каких-либо изменений канал
изменилась: мягкая обновить скрипт теперь корректно использует / var / бен / мягкий
-------: Выбираемых из-присвоить кнопку меню тоже
janigor
Официальный DGS r8107 Cuberevo/9000HD
Based on svn revision r8107.
Need DB version R7934.
DGSTATION IMAGE
change log is as below.
- can read old versions of USB stick
- support RGB output
- support HDD sleep
- can't deleting recording file
- support Multi Mount Manager
some add(8107, 8129, 8138~42)
ftp://dev.dgstation.co.kr/pub/cuberevo/netupg/DGStation/cuberevo_r8107.zip
Альтернативный Sifteam v0.1.7 r8107 Cuberevo/9000HD
*From 0.1.7:
Based on new DGS r8107
Added more change in any script.
Remove Sif_System plugin
..use kneubi script for default.
ftp://9000hd.sifteam.eu/9000HD/Firmware/SifTeam/SifTeam-0.1.7-r8107/usb_all_noboot.img
janigor
AB IPBox 9000HD image based on DGS r8107
* R8107 *
Changelog
Fixed:
- EPG on UPC Direct and Cifra+
- support HDD sleep
Add:
- page skip with L/R button in FAV list
Recommended uboot 1.3.2 .
This function supported only uboot 1.3.1 or 1.3.2 !
If you use older uboot, upgrade first uboot 1.3.2 with USB cable and Flash tools from PC.
http://www.satupdate.net/stahuj/AB ...ial/AB_9000HD_240908_r8107_usb_all_noboot.zip
Неофициальный аддон - unofficial/SF upgrade for AB Images/addon_version-9000HD_sh4_240908
http://www.satupdate.net/stahuj/AB ...AB Images/addon_version-9000HD_sh4_240908.zip
barsuk72
nlb8107
CubeRevo nlb8107
WEBIF
login: root
password: relook
Changes:
* include: svn8107 from DGS
* include: mbox 17.09.2008
* included: Deutsch translation from svn8022
* include: Documentation on nlb mod features included.
barsuk72
CubeRevo nlb8107v2
Viraje
SifTeam 0.1.7 r8107v2 - 06.10.08
janigor
Cli-2.0.0- Based on ABCOM8107 for CubeRevo/ip9000
**** THIS IMAGE CONTAINS NO CURRENT KEYS ****
**** Cli Team ****
**** www.satkings.org ****
**** http://cablelinux.info ****
THIS IS ONLY FOR ip9000
Abcom Changelog > 8107
********* Changelog Fixed: - can read old versions of USB stick -
EPG on UPC Direct and Cifra+ -
support HDD sleep -
can't deleting recording file Add: -
support Multi Mount Manager -
support RGB output -
page skip with L/R button in FAV list Recommended uboot 1.3.2 . Photo album start - Press "Photo" button on RCU MP3 player start - Press "Music" button on RCU ftp login/password: root/ipbox
*Update UK Cable Database
- Add missing frequancy
- Add Dublin Fast Scan ( more fast scans coming soon )
- Add DVB-T Area Chorus
*Working German Translation from Byti
* Working French Translation from old image
*Added missing HD frequancys on 0.8w and 0.5e
*Inadyn Support, please set config in /var/etc
*mgcamd/evocamd/mbox (mbox binary as 'mbox')Support from web interface or green to restart cam
*update Keys at touch of a button ( need to add Url to /var/etc/Keyupdate.url
*Cron Job Support - add crontab file and look in var/cron
*Email 0.3 plugin - Thanks to Kneubi
*script plugin - thanks to Kneubi
*games_plugins(tetris,sudoko,pong) - Thanks to Neumoteam
*Web Tv-Latest(06/10) - thanks to Pacco ( needs Hard Drive )
* RED.sh for easy change of red button use - current update keys
* green.sh for easy change of green button use - Restart Cam
*-yellow.sh for easy change of yellow button use- current show ECM
*FIXED NETWORK BUG-
Thanks to kernel patch by pacco we can now have new kernel that doesnt have any network issues. No more dropped connections under high-load, and ethernet now works great for WEB-TV.
FTP Test on wireless there can run at 1200KB/S!!!!
****Known issues still to resolve
- EPG Still wont save to a database so only loads current transponder to memory
- USB H/D still quite unstable.
- Cli Web interface has issues with internet explorer PLEASE USE FIREFOX for web interface full functions
- will fix terminfo for next release
- will add working openvpn on next release
****We promise some of these are DGS issues and we need to wait on them fixing, but hopefully very soon
Regards
Satman + Cli TeAm!
Thanks to Pacco, Kneubi, Timelord, TopQuark and Abcom Team!!!!
Edited-Thanks @ denktenk for putting in downloads
janigor
RELEASE r8264
NEW RELEASE r8264: Added or improved Function
1. The video player(Divx 3,4 and xvid, mpeg 2, H.264)
: video player can support some file formats such as *.avi, *.mpg and *.mpeg.
you have to change the extention as *.avi, *.mpg and *.mpeg before playback.
press pause : pause state
Pause> pause : pause state
Play button only can be exit from pause mode.
Sometimes, If the file needs higher class CODEC than current one, it may be not played.
If the file itself too high bitrate, it may be not played.
The version of Divx CODEC more than 5.2 doesn't support it.
2. WebTV on webinterface
: First of all, you have to install VLC Player on your PC.
It's tested on Firefox and Internet Explorer 7.
Javascript is required.
Streaming works for 720p channels, but for 1080i there is not enough network bandwidth.
USAGE: Surf to http://(boxip)/webtv/
3. ITV HD(Astra 28,5)
: it should use Advanced Search menu with manually (3401 VPID, 3402 APID, 2326 PCR PID)
http://www.flysat.com/28east.php
4. improved to related USB HDD
: 1 channel recording in a TP and 1 recorded file playback or 1 another channel watching in the same TP.
5. improved channel zapping speed
6. Solve the bug of the USALS
7. Solve the bug of the Diseqc 1.2.
8. Support HDD sleep
: If select timeshift off, HDD willgo sleep mode after 3 minutes.
9. Update DB for DVB-T and DVB-C
: Ireland MMDS(Terrestrial), IRE6887 Quick(Cable), ENG6952 Quick(Cable)
10. improved to related plugin
11. channel list of Grid EPG follow channel sorting
12. bug fixed static IP
13. Added FAST SCAN function for Benelux
known issues
: WSS in Recorded Files.
: HDMI with compressed Dolby digital audio
: DVB subtitle
Above all, we can confirm the effect in the DGSTATION enviroments.
We cannot be sure of the same result.
If not so, contact with us.
e-mail: [email protected]
Thank you.
Cuberevo / ABIpbox 9000HD
azkr
появился имИдж от SifTeam скачать можно здесь Sifteam v0.1.8 r8264
barsuk72
Official DGS r8314
NEW RELEASE r8314: Added or improved Function
1. Fixed Swaping PIP
2. Fixed Audio Language Preferences.
3. Fixed an combination of USALS and Diseqc
