Имиджи для AB IPBox 9xxHD
andrei2105
AB_910HD_r11662DRE_290110_usb_all_noboot.zip
DGS release r11662: ( 29/Jan/2010) -------------------------------------------------------------- 1. Added Weather Forcast function 2. Added subtitle function of video player(support as *.smi) 3. Improved channel zapping time and overall response time of RCU 4. Updated bitrate plugin 0.0.8(thanks to Kneubi) 5. Updated language table - Finnish(thanks to Christer) - Slovak, Czech(thanks to Rene) - Arabic(thanks to Cubebox) 6. And other small bugs fixed(thanks to pacco, kneubi) 7.Fixed updating channel name of subfeed problem in multifeed function 8.Adopted multifeed function in cable tuner 9.In order to avoid auto formatting of USB memory stick, Modified concept to prevent automatically achieving format under 32GB HDD or USB memory when start up 10.Fixed HE-AAC with MPEG 4 video for DVB-T tuner 11.Added ipkg function 12.Added Arabic language in menu, it will support to Arabic EPG, Subtitle, teletext as well(thanks to Yahya - ACT team ) 13.Updated Lituania language(thanks to Raimunda
http://download.abcom.sk/index.php?...662DRE_290110_usb_all_noboot.zip&directory=02 AB IPBOX HD/10 910HD_Images&
Lowik
Новый имидж DGS r11691 (на оф. сайте пока нету)
ftp://dev.dgstation.co.kr/pub/
P.S.: dev.dgstation.co.kr/pub/cuberevo-модель_своего_ресивераHD/netupg/DGStation/
Gensir
и уже есть там же DGS r11694
DGS release r11694:
1. Fixed memory leak and collision.
2. Updated language table
- Lithunaian (thanks to Raimundas)
Работают, что то исправляют.......
Lenina
Куратор "IPBox"
nlb11694 for IPBox 9000HD released
mage release: NLB-11694_9000 no limits board
Prepared by : no limits board
Release date : Feb 12, 2010
Changes to 11577:
* update: DGStation SVN11694
* update: incubusCamd 0.97
* update: oscam with working config
* update: new sci driver 20.01.10 ... thanx to pacco
* Added MySKYEPG skin (called grey untill new nlb panel get finished)
* Removed cool skin
* Default skin: deepblue
important info:
- this image doesn't owerwrite multiboot, but if you have e2 in flash it should be overwritten first
- mgcamd is default emu ... if you start a new one in nlbpanel then mgcamd and new one will be showed as "running" ...
means, both can be used ... but we suggest to reboot your receiver after changing emu to have only new one running
thanx to Minicat for beeing beta-tester
Download via Rapidshare: http://www.sat-universe.com/redirec...idshare.com/files/349573098/nlb11694_9000.zip
Lenina
Куратор "IPBox"
Для 900/910/9000
AB_r11691DRE_120210._usb_all_noboot and AB_r11691_120210_usb_all_noboot
2. Updated language table - Lithunaian (thanks to Raimundas)
3. Fixed recording to USB HDD on 91HD, 900HD, 910HD
http://www.satupdate.net/soubory/AB IPBox HD/?notop нужна регистрация.
kasvit
nlb11694 for IPBox
Image release: NLB-11694 no limits board
Release date : Feb 15, 2010
Changes:
* Added MySKYEPG skin (called "grey" until new nlb panel get finished)
* Removed cool skin
important info:
900HD-http://rapidshare.com/files/350968894/nlb11194_900.zip
91HD- http://rapidshare.com/files/350978988/nlb11194_91.zip
910HD-http://rapidshare.com/files/350923719/nlb11694_910.zip
ferganec
nlb11694 for IPBox
Changes:
* Removed cool skin
important info:
Спасибо канешна ! вот если бы товарищ постер перезалил с рапиды эти файлы цены бы не было сей инфорции!!! !bad!
Добавлено через 34 минуты
nlb11694 for IPBox
Image / ftp / telnet
Username root
Password relook
Webiinterface
Username relook
Password relook
вдруг вопросы появятся
Lenina
Куратор "IPBox"
Image release: NLB-11694b_9000 no limits boardvisit us on nlb.to/board
Release date : Feb 21, 2010
Changes to 11694:
* busybox 1.15.3
* added samba and ssh
* fixed deepblue skin // thanks to henia888
* myskyepg skin included
* /var/S59_bootscript to add user scripts
* start / stop problem of emu fixed
Download via Rapidshare: http://rapidshare.com/files/353936068/nlb11694b_9000.zip
Lenina
Куратор "IPBox"
cuberevo.r11801 для линейки IPBox
This README is for CubeRevo HD model series.
This document was approved on 6/March/2010 by the DGSTATION.
1. Added current time line on Grid EPG Menu
2. Builted cross epg plugin(thanks to Sandro Cavazzoni)
3. Added RSS news function
4. Added blind scan menu with sharp tuner
5. Updated Fast Scan(NL) from V1.10 to V2.3
6. Updated Webinterface V.1.5.01(thanks to Nils)
7. Changed smartcard driver(thanks to Pacco)
8. Fixed bug for Upgrade via Network
9. Other small bugs fixed.
Notice : We will prepare next version of image within 10 days, and the new image will be supported USB WiFi function in IP setup menu.
Note.
1. Prohibited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. Caution : When encoding the file, Playback via XVID player will be affected by condition of a kind of CODEC, FPS(frame per second) and the Resolution.
And XVID player doesn¡¯t support resolution higher than 720P
therefore, we recommend as below conditions.
1) resolution : equal or under 720p
2) FPS : 24, 25 and 30 fps.
3) A/V Codec
Video Codec : XVID(Without GMC or Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MPEG layer 1,2, MP3, AC3
if XVID file has GMC or Qpel option when encoding, it will not work properly.
if the file was encoded by MPEG 1 or MPEG 2, XVID player doesn¡¯t support Adjusting Sync function and Jump forward/backward function
3. ext3 file system is slower than ext2 normally.
If you will record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function
3. if you want to execute cross epg daemon always from booting, you change the authority of "3.crossepg".
1) connect the STB via telnet(root/relook)
2) move /var/bin/init.d/
3) enter following instruction. ==> chmod 777 3.crossepg
welcome to cuberevo
cuberevo login: root
Password:
System bootup in progress - please wait
[Disconnect bypassed -- root login allowed.]
-sh-3.00# cd /var/bin/init.d/
-sh-3.00# ls -al
drwxr-xr-x 2 502 502 0 Mar 3 02:12 .
drwxrwxrwx 3 502 502 0 Mar 3 02:12 ..
-rwxr-xr-x 1 502 502 228 Mar 3 02:12 3.crossepg
-sh-3.00# chmod 777 3.crossepg
leopold75
Прямые ссылки для удобства (r11801)
Lenina
Куратор "IPBox"
nlb11694_rev.E for IPBox 9000 HD released
Image release: NLB-11694_9000 rev. E no limits board
Release date : Mar 15, 2010
Changes to 11694:
* busybox 1.15.3
* added cardreader driver 1.4 by pacco
* fixed hdd mounting
Please note: This is upgrade only ... you´ll need nlb11694 - image as basis
Download via Database -->
http://www.nlb.to/board/index.php?page=DownloadDBFileDownload&dataID=1222
Lenina
Куратор "IPBox"
DGS_11834
DGS release r11834: ( 19/March/2010)
1. Added WiFi function at IP setup menu.
Ralink series as rt2870 family USB WiFi dongle supported.
2. Updated smartcard driver V.1.4(Thanks to Pacco)
3. Other small bugs fixed.
Note.
3) A/V Codec
Caution.
welcome to cuberevo
Password:
-sh-3.00# ls -al
Lenina
Куратор "IPBox"
NLB 11834 for Ipbox 9000HD
Image release: NLB-11834_9000 no limits board
Release date : Mar 20, 2010
Changes to 11834:
*BlueMoon new default skin
Note: This is a test version
NLB-11834-9000 http://www.sat-universe.com/attachment.php?attachmentid=202327&d=1269126925 (22.17 MB)
redblaster
Тут подправленная версия :
New Image release: NLB-11834-test rc2
Release date : Mar 21, 2010
Changes:
* Added Incubus 0.98
* Added Cam Plugin (for webcam)
* Favpip corrected. --типа работает
* Minor changes
А вот это что за скин :BlueMoon new default skin - кто-нибудь ставил?
Спасибо.[/HIDE]
Lenina
Куратор "IPBox"
А вот финальная.
Final Image release: NLB-11834_9000 2.06 no limits board
Changes to 11694:
* emu incubusCam 0.98
* emu mbox 2.23 4th with gbox fixed
*a added cam plugin
* BlueMoon new default skin
-------Thanks-----
to Pacco for great UCR driver
to czarny for BlueMoon skin
----(web)cam plugin readme ------
cam.plugin is small plugin that allow to you see jpeg streams from Webcam.
This should be a webcamera that can give jpeg stream.
It may be, for example, axis webcams , dlink webcams or more else .
Setting up
Open cam.config, edit cam_url, cam_width, cam_height, time_refresh in accordance with your settings.
Notice
There, in cam.config, cam_url, by default, is the first link of axis web cam that I found in internet.
I don't know what is it and where is it. But I leave this url just for example.
I'm not sure that this link will be work in future.
http://rapidshare.com/files/366347985/nlb11834_9000.zip
Добавлено через 10 часов 22 минуты
Спасибо.
Вот здесь о скине с скриншотами, возможно для просмотра придется зарегистрироваться http://pkteam.pl/viewtopic.php?f=50&t=1730
