allllex
Все новые имиджи от группы
находятся здесь
http://www.newnigma2.to/wbb2/board.php?boardid=67&sid=d129779ac8f0be7ec5b4831af6c1ebec
Newnigma2 v3.1.4
Здесь
Basics:
  • Enigma2 2.6: 22.01.11
  • Enigma2 Plugins 2.6: 22.01.11
  • Newnigma2 Plugins: 22.01.11
DM 800 HD se
  • driver: 15.12.2010
  • secondstage: 80
  • kernel 2.6.18
Changes:
  • Feature: EPGCacheSelector (choose the file and location of the epg cache file)
  • Feature: User can now decide if manual activated infobar should be hidden automatically (settings can be found in system settings)
  • Feature: Installer checks now every x hours or on system startup for updates (settings can be found in system settings)
  • Feature: Devicemanager internal routines changed from hotplug to udev netlink
  • Feature: Now with slovakian translation on feed.
  • Feature: Oled now with number of the currently running channel and improved layout
  • Feature: Simplified picon installation
  • Bugfix: camd menu, camd list wasn't visible sometimes
  • Bugfix: systeminfo crashes in some strange cases
  • Bugfix: dvd speed settings have not an affect
  • Bugfix: dvdhandling improved
  • Bugfix: menu -> plugins (german: erweiterungen) now linked to our onlineinstaller
  • Bugfix: large file support for FAT32 (now its possible to create partitions and files >1GB)
  • Bugfix: dvdbackup .iso image creation
  • Update: nl, lt and fr translations updated
  • Update: dvdread and dvdnav updated
  • Update: satellites.xml by Reinh@rd 15.01.2011
  • Update: dosfstools to 3.0.11
  • Added: enigma2-plugin-extensions-easymedia to feed
  • Added: enigma2-plugin-extensions-fancontrol2 to feed
  • Added: enigma2-plugin-extensions-reconstructapsc to feed
  • Added: enigma2-plugin-extensions-seekbar to feed
  • Removed: dvdburn and depends removed from image (dm8000). Saves 8MB flash
Infos for skinners:
  • You don't have to use skindir/newnigma2 folder for icons, they are now integrated. If you want to use your own png's, dont delete this folder in your skin
  • extInfoBarSkins.xml is removed. Dont use this file anymore, it is no longer available, but you can activate the ecm info screen still via osd preferences
G3wizard: No support for g3wizard. Probably not running. Not needed in Newnigma2 enviroment.
multiboot
: no support for multiboot. Not planned, not wanted! (Но на ВА устанавливается без проблем, главное, чтобы во флеши был актуальный имидж).
g3wizard: no support for g3wizard. Not running, not planned, not wanted!
Обновления драйверов проходят автоматически с сайта поддержки.
Внимание у кого этот имидж стоит на ВА. Сначала обновите имидж, который стоит во внутренней флеши, обновите сам ВА а только потом обновляйте невнигму. Иначе после обновления она может просто не загрузиться при перезагрузке бокса.
Фид для загрузки причиндалов находится здесь:
http://feed.newnigma2.to/stable/dm800se/3.1/
Эмулятор mgcamd 1.38 в подвеске
  • newnigma2-camd-mgcamd1-38.zip
    328,6 KB · Просмотры: 199
seal
Администраторы
для 800 го это мой (лично) любимый имедж
allllex
А у меня 50:50 с EDG-NEMESIS по функциональности. Только скрипт надо для эмулятора писать самому. А скин можно одинаковый подобрать. Аллруссиан слишком яркий и аляпистый.
seal
Администраторы
Newnigma2 team proudly presents:
Newnigma2 v3.1.4
Basics:
DM 800 HD se
driver: 15.12.2010
secondstage: 80
kernel 2.6.18
Changes:
Infos for skinners:
Änderungen:
Feature: Mit dem EPGCacheSelector kann der Dateiname und Speicherort der EPG Cache Datei definiert werden.
Feature: Die Nutzer können nun wählen ob eine manuell aktivierte Infobar automatisch geschlossen werden soll ( NN2 System Einstellungen)
Feature: Es kann nun aller X-Stunden oder bei System-Start auf Updates geprüft werden ( NN2 System Einstellungen)
Feature: Die internen Routinen des Devicemananer wurden von hotplug auf netlink umgestellt.
Feature: Jetzt mit slowakischer Übersetzung auf den feeds.
Feature: Einige Verbesserungen der OLED Anzeige, anzeige der Kanalnummer.
Feature: Vereinfachte Picon Installation.
Bugfix: camd Menü, camd Liste wurde manchmal nicht angezeigt.
Bugfix: Absturz beim Aufruf der Systeminformationen.
Bugfix: DVD Geschwindigkeitseinstellungen hatten manchmal keinen Effekt.
Bugfix: Verbessertes DVD-Handling.
Bugfix: Über "Menü > Erweiterungen" ließen sich keine Plugins installieren / deinstallieren.
Bugfix: LargeFileSupport für FAT32 ( Es konnten keine Dateisysteme und Dateien > 1GB erstellt werden )
Bugfix: Mit DVDbackup konnten keine ISO-Images erzeugt werden.
Update: Folgende Übersetzungen wurden ergänzt NL, LT, FR
Update: dvdread und dvdnav wurden aktualisiert
Update: Neue satellite.xml von Reinh@rd 15.01.2011
Update: dosfstools wurde auf Version 3.0.11 aktualisiert
Added: enigma2-plugin-extensions-easymedia zum feed hinzugefügt
Added: enigma2-plugin-extensions-fancontrol2 zum feed hinzugefügt
Added: enigma2-plugin-extensions-reconstructapsc zum feed hinzugefügt
Added: enigma2-plugin-extensions-seekbar zum feed hinzugefügt
Removed: dvdburn wurde aus dem 8k Image entfernt ( gibt 8mb an Flash Speicher frei )
Information an die Skinner:
Die Icons in /skinname/newnigma2 werden nicht länger benötigt, unsere Icons befinden sich nun im Verzeichnis des jeweiligen Plugins.
Ihr könnt das Verzeichnis jedoch weiterhin für eure individuellen Icons verwenden.
Bitte benutzt die extInfoBarSkins.xml nicht mehr, die Datei wurde aus dem Image entfernt.
Der ECM Info Screen kann jedoch weiterhin in den OSD-Einstellungen aktiviert werden.
Multiboot: No support for multiboot. Not planned. No need for such a tool.
Onlineupdate from v3.1(.x) is possible.
Ein Update von v3.1(.x) ist per Softwareverwaltung möglich.
Your
Newnigma2 Team
Качаем тут
edgar3390
allllex, какой эмулятор mg.camd 1.35 нужно ставить на newnigma? В причиндалах,что-то не нашел. Если можешь, выложи файл. И как его устанавливать, также как на имидж CVS через FTP?
LuckyManX
seal
Администраторы
на ньюнигму ставится из blue panel
charius
Медиа плеер VC 1 не воспроизводит, это както лечится ?
allllex
Обновление:
Newnigma2 v3.1.5
Basics:
  • Enigma2 2.6: 19.02.2011
  • Enigma2 Plugins 2.6: 19.02.2011
  • Newnigma2 Plugins: 19.02.2011
DM 800 HD se
  • driver: 15.02.2011
  • secondstage: 81
  • kernel 2.6.18
Changes:
  • Feature: devicemanager now able to create NTFS partitions (you have to install the package ntfsprogs)
  • Feature: devicemanager now able to create HFSpartitions (you have to install the package hfsplusprogs)
  • Feature: HFS und HFS+ file system support (you have to install the package kernel-module-hfs and/or kernel-module-hfsplus)
  • Feature: picons in channelselection active again in oled
  • Feature: bulgarian translation added in feed
  • Feature: the newnigma2 release version ist now shown in "informations - about"
  • Feature: now DreamDTS supports .ts and .m2ts files
  • Bugfix: formatting drives with more partitions in devicemanger
  • Bugfix: some installer fixes
  • Bugfix: some configsaver fixes
  • Bugfix: Dreambox infrared keyboard
  • Bugfix: installation of some SD picon packages
  • Bugfix: DM8000 kernel and nand flash driver
  • Bugfix: webradio uses now new shoutcast api.
  • Bugfix: newnigma2 weatherplugin
  • Bugfix: sometimes not working Camd Autoreset
  • Update: new Dreambox drivers and SecondStageLoaders
  • Update: vsftp server to v2.3.2-8
  • Update: finnish translation
  • Update: revised spinner and Newnigma2 GUI's
  • Update: gstreamer and dreamdts
  • Added: enigma2-plugin-extensions-dreammediathek
  • Added: ntfsprogs,hfsplusprogs
  • Added: ralink rt73 driver for WLAN sticks
Änderungen:
  • Feature: devicemanager kann nun auch NTFS Partitionen erzeugen (es muss zusätzlich das Paket ntfsprogs installiert werden)
  • Feature: devicemanager kann nun auch HFS Partitionen erzeugen (es muss zusätzlich das Paket hfsplusprogs installiert werden)
  • Feature: HFS und HFS+ Dateisystem-Unterstützung (es muss zusätzlich das Paket kernel-module-hfs und/oder kernel-module-hfsplus installiert werden)
  • Feature: picons in channelselection im oled wieder aktiv
  • Feature: jetzt mit Bulgarischer Übersetzung auf den Feeds
  • Feature: im Menü "Informationen - Über" wird nun die Newnigma2 Release Version angezeigt
  • Feature: DreamDTS unterstützt nun auch .ts und .m2ts Dateien
  • Bugfix: formatieren von Laufwerken mit mehreren Partitionen im devicemanger
  • Bugfix: einige installer fixe
  • Bugfix: einige configsaver fixe
  • Bugfix: Dreambox Infrarot Tastatur
  • Bugfix: Installation von manchen SD Picon Paketen
  • Bugfix: DM8000 kernel und nand flash Treiber fix
  • Bugfix: webradio auf die neue api angepasst und ein paar mehr Suchoptionen eingebaut.
  • Bugfix: newnigma2 wetterplugin PLZ Suche
  • Bubfix: Camd Autoreset funktionierte manchmal nicht
  • Update: neue Dreambox Treiber und SecondStageLoader
  • Update: vsftp Server auf v2.3.2-8
  • Update: finische Übersetzung
  • Update: überarbeiteter Spinner und newnigma2 GUI's
  • Update: gstreamer und dreamdts
  • Added: ralink rt73 Treiber für WLAN Sticks
Hinweis: Sollte es beim Update zu Problemen kommen und beim Neustart Error im Display stehen dann muss der SecondStage mit Dreamup neu geflasht werden.
Notice: If u have problems after update and the display shows "Error", then u have to flash the SecondStage with dreamup.
Your
Newnigma2 Team
http://www.newnigma2.to/wbb2/thread.php?threadid=10541&sid=a1be0cde5ac7714cc2dfa03180133a43
edgar3390
Добрый день, всем.
После многочисленных тестов, решил все-таки остановиться на newnigma.
Хочу поставить во внутрннюю флешь Newnigma2 v3.1.5 и больше не скакать с имиджа на имидж.
Такой вопрос: что делать со вторым файлом- загрузчиком? Лить буду через вебинтерфейс, его надо накатывать сверху после основного nfi. файла прошивки или нет?
LuckyManX
что значит вторым файлом?
в имидже уже все есть... ставишь через веб и все...
файлы загрузчиков дают на всякий случай... если во время установки произошли какие то проблемы и имидж не загружается...
allllex
Зачем поясниловку Newnigma2 v3.1.5.txt кладут в архив? Чтобы читали, что там за особенности и нюансы. Там все написано, открыл хотя бы для приличия:
Переводчик сейчас у всех стоит, понять можно.
vadiaravolk
DM 800 HD se: Newnigma2 v3.2
Basics:
* Enigma2 2.6: 24.03.2011
* Enigma2 Plugins 2.6: 24.03.2011
* Newnigma2 Plugins: 24.03.2011
DM 800 HD se
* driver: 09.03.2011
* secondstage: 82
* kernel 2.6.18
Changes:
* Bugfix: some small fixes in ecamdctrl
* Update: xmltvimport plugin and sources/channels updated
* Added: driver for Realtek 802.11n USB wireless LAN controllers
* Added: enigma2-plugin-extensions-serienfilm
* Added: enigma2-plugin-extensions-webbouqueteditor
Notice: No update possible. U have to flash our new image. The new kernel and secondstage update for the Dreambox 8000 allows you to use the full flash size of 256MB.
GP3wizard: No support for gp3wizard. Probably not running. Not needed in Newnigma2 environment.
Your
Newnigma2 Team
СКАЧАТЬ
dortmundez
DM 800 HD se: Newnigma2 v3.3 antworten | zitieren | editieren | melden |
Newnigma2 v3.3
Basics:
Enigma2 2.6: 28.09.2011
Enigma2 Plugins: 03.11.2011
Newnigma2 Plugins: 03.11.2011
DM 800 HD se
driver: 03.09.2011
secondstage: 84
kernel 2.6.18
Notice: Onlineupdate is not possible.
Changes:
Bugfix: some small fixes for openvpn
Bugfix: configsaver crashed when u restored a playlist, which already exists. fixed saving on a medium which is formatted in fat
Bugfix: some devicemanger fixes
Bugfix: installer for picon installation with all kind of devices which have a non alphanumeric character in the devicename
Bugfix: dvd/cd playing fixed. dvdautomount removed from expert settings. not longer needed
Added: Kerni.NN2.No2-MD (thx to Kerni)
Added: enigma2-plugin-extensions-mediadownloader depend for simplerss
Added: enigma2-plugin-extensions-yttrailer (thx to _Dr_Best_)
Removed: xmltvimport from feeds. not longer works with new e2
For Skinners: rc.png and rcold.png renamed to rc0.png und rc1.png. new rc2.png is rc of new dm7020hd. New screen: SatBlindscanState
Info: mkv + idx/sub not longer work with new e2
changelog e2: dm800hd se
IMPORTANT: Starting today (that was 05.09.2011) images for the models DM500HD, DM800 SE and DM800HD PVR include an improved flash error correction feature.
In order to benefit from the improvements, it is required that you either flash the new image with the latest version of DreamUP (V1.3.3.9) or flash a new second stage loader ( DM500HD DM800HD PVR DM800 SE ) before flashing the image via your browser or other means.
WICHTIG: Seit dem heutigen Tag (das war der 05.09.2011) enthalten die Images für die Dreambox Modelle DM500HD, DM800 SE und DM800HD PVR eine verbesserte Fehlerkorrektur für den Flash-Speicher.
Um die Neuerungen benutzen zu können, muss entweder ein vollständiges, neues Image mit der neuesten Version von DreamUP (V1.3.3.9) geflasht werden, oder zunächst ein neuer Second Stage Loader ( DM500HD DM800HD PVR DM800 SE ) installiert werden, bevor darüber ein neues Image geflasht wird.
SECONDSTAGE DOWNLOAD: DM800HD se
here u can find USB to UART driver
Your
Newnigma2 Team
Image:
http://www.newnigma2.to/wbb2/thread.php?threadid=13620&sid=17eced2228efb8ff61fabc4587518c60
allllex
edgar3390
как ставить 2.3.3 онлайн обновлением или переустанавливать заново, в частности на ВА-WW? во внутренней флеши стоит OzOon с 84 загрузчиком.
