PKT OCTAGON SF1028 E2 HAARP v2 Image 20-08-2011 - USB, SATA, Flash
Enigma2 OpenSource SH4 Duckbox Project GIT-2645 PKT mod SVN-1064 HAARP v2 Image
Image is designed for installation in Flash/USB/SATA devices
Support receiver: Octagon SF-1028, Atevio 7500HD or other clones
Added by sh4 Duckbox Team:
- [stm24] added lzma patch for squashfs
- [stm24] ext4 can now be used for ext2/3
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [multicom-3.2.4_rc3] add new multicom driver
- [eplayer3] playback aac-he streams with aac-lc
- adding opkg binary to default build
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- [stm24] added squashfs-tools 4.0 lzma patch
- add busybox 1.18.5 stable
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
Added by PKT:
- first build on stm24 kernel
- add new WebInterface v 1.6.7
- add cardreader support
- new function "live ecm" in infobar
- update e2 to 2011-07-06-experimental
- 10% faster switching channels
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- Enable autofs support
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- PKT Channel Control v1.03: store Aspect Ratio separate on each channel
- MPlayer fix GS of EOF
- new InstallManager 1.0.6: new visualisation of install process. After format there is ability to abort installation process (this option is limited to 1 minut after start installation ) and also possibilty to change volume level while installing new image
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- DTS Downmix Disable fix
- set cleanupwizard.enable=false
- update font fix
- remove unnused files or many BP menu settings modification
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
- [SF1028 | UFS912] add info about extended partition usage in sysinfo when flash Image is running
- update plugins feed
Advice:
When Image is installed in the flash device - BP->Settings->SpeedUP Tool is recommended to increase amount of free space.
Included Flash Image (.ird) default is set to SF-1028P reseller ID. Before Flashing check Your receiver and change reseller ID if needed.
To change reseller ID we recommeded IRD Resseler Changer for AT7500 from AAF Team.
Пароль для доступа FTP : логин
root пароль
pkteam .
