Покажите медиа-инфо обоих видео.
General
CompleteName : C:\Users\Alexander\Documents\Vancouver - The City By The Sea (HD Time-Lapse)_(1080p).mp4
Format : MPEG-4
Format_Profile : Base Media / Version 2
CodecID : mp42
FileSize/String : 51.5 MiB
Duration/String : 2mn 6s
OverallBitRate/String : 3 405 Kbps
Encoded_Date : UTC 2009-11-06 19:16:03
Tagged_Date : UTC 2009-11-06 19:16:03
gsst : 0
gstd : 127476
gssd : BD49AA8E5MH1289650059670432
gshh : v18.lscache6.c.youtube.com
Video
ID/String : 2
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : [email protected]
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 3 frames
CodecID : avc1
CodecID/Info : Advanced Video Coding
BitRate_Mode/String : Variable
BitRate/String : 3 278 Kbps
BitRate_Maximum/String : 34.2 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 24.000 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.066
StreamSize/String : 49.6 MiB (96%)
Title : (C) 2007 Google Inc. v08.13.2007.
Audio
ID/String : 1
Format : AAC
Format/Info : Advanced Audio Codec
Format_Version : Version 4
Format_Profile : LC
CodecID : 40
BitRate/String : 125 Kbps
BitRate_Maximum/String : 234 Kbps
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 44.1 KHz
Compression_Mode/String : Lossy
StreamSize/String : 1.90 MiB (4%)
720
General
Complete name : C:\Users\Alexander\Documents\We Are The Fallen - With Or Without You (U2 MASHUP MONDAYS COVER!!!)_(720p).mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 82.5 MiB
Duration : 5mn 28s
Overall bit rate : 2 107 Kbps
Encoded date : UTC 2010-05-21 22:32:14
Tagged date : UTC 2010-05-21 22:32:14
gsst : 0
gstd : 329048
gssd : BD49AA8E4HH1288210616279895
gshh : v21.lscache8.c.youtube.com
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 5mn 28s
Bit rate mode : Variable
Bit rate : 1 979 Kbps
Maximum bit rate : 3 273 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.089
Stream size : 77.5 MiB (94%)
Tagged date : UTC 2010-05-21 22:32:15
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Codec ID : 40
Duration : 5mn 28s
Bit rate : 125 Kbps
Maximum bit rate : 164 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 4.92 MiB (6%)
