Где брал и сколько стоит?
Добавлено через 3 минуты
http://www.wizardfox.net/showthread.php?p=77689#post77689 Посмотри здесь.
in slovakia this model price 280 euro and is this same hardware as octagon 918 ( price 360 euro).
optibox 7750,8750, GI890, nextwawe,saab - possible flashing to octagon 918 and last verion support dre/crzpt.. see changes.
Readme_Version_31-12-08_EMU_AU_V10258
for Octagon HD SF 918 HDTV :
Changes :
- EPG - Event Timer Record add.
--> EPG : 2 x Yellow Button
--> Red Symbol for Record
--> In Timer Menu you can see Program Info with "R" symbol
and also possible to change Time & Duration
- MPEG-4 Cam Module NP4 SD+HD decoding adjusted
--> NP4 Cams : Pocket NP4 Viaccess, Conax, Irdeto, Pro-Crypt, Neotion and
DRE-Crypt (MPEG-4)
- Sat : add. ProtoStar 1 at 98.5°E
- DigiTv AU fix. TEST OK 100% , Thor 0.8W
- DVB-Subtitle bug fix.
--> Thor 0.8W, Sirius 4,8E, Hotbird 13E, Eutelsat 16E,
- Rai Seca ProvID fix.
- E-SATA HDD detection improved
- MCAS Card-Reader improvements (Pls. Test)
- X-Button bug fix.
- Devoloper Mode : Fine Tune Button -> Test Address --> RS232 DEBUG Mode disabled
--> RS232 normal mode enabled
- Add. to Navigate Keyboard Window in following menu points
--> Network and Antena Setup - Change
- AU update still works ;-)
