http://www.kaonmedia.co.kr/eng/product/view_specifi.php?org_num=146&b_code=1&s_code=23
http://img507.imageshack.us/img507/195/17224393860yx3.gif
Compliant MPEG-4/H.264 & Fully DVB-S
PAL (CVBS), YPrPb, SCART(RGB,SVIDEO,CVBS)
SCART TV and SCART VCR, RCA(COMPONENT)
RCA(COMPOSITE), SPDIF(OPTICAL),
HDMI, RJ45, USB2.0*2EA
CAS Optional
NDS, CONAX, IRDETO, CRYPTOWORKS, NAGRAVISION, TF-CAS, Chinacrypt
Transport stream MPEG-4/H.264 [email protected] 1920x1080 interface@50Hz
MPEG Profile/level MPEG-2 MP@HL, MPEG-4/AVC MP@L4
Input bit rate Max. 81,0 Mbit/Sec.
Video aspect ratio 4:3, 16:9, Letter Box
Video formats 576i, 576p, 720p, 1080i,
Video outputs PAL (CVBS), YPrPb, SCART(RGB,SVIDEO,CVBS)
Audio decoding Dolby AAC, AC-3, MPEG-1 layers 1,2 and 3(MP3)
Audio modes Single Mono, Dual mono, Stereo, Joint stereo
Sampling rate 32,0, 44,1 and 48,0 kHz
Tuner & Channel
RF input connector F-type Female (preferable),IEC 169-24 Female (acceptable),75 Ohm
Frequency range 950MHz ~ 2150MHz
Input dynamic range -65 dBm ~ -25 dBm
Symbol rate LDPC/BCH(DVB-S2)8PSK/QPSK : 10 ~ 30Msps
Channel selection system PLL Synthesize(I2C)
A/V & DATA INPUT/OUTPUT
Output connectors SCART TV and SCART VCR,RCA(COMPONENT),
System Resources
Main Processor 300MHz CPU
Flash Memory 64Mbytes
Program DRAM 256Mbytes
EEPROM 32KBytes (Optional Expand)
Power Supply(Internal)
Input Voltage AC 90 to 250V, 50/60Hz
Power Consumption MAX. 40W
Protection Separate Internal Fuse
Type SMPS
Physical Specification
Operation Temperature 0¡É ~ 50¡É
Storage Temperature -20¡É ~ 60¡É
Size(W*H*D) 370*60*275mm
CAS Optional
Tuner & Channel
System Resources
Type SMPS
