Lyngbox
valdis1974
подскажите кто может чайнику! вот этот рессивер http://www.lyngbox.com есть где в продаже? и возможен ли на нем шаринг?
Добавлено через 13 минут
Технические данные:
* HDTV support (720p and 1080i)
* Supports H.264/MPEG-4 AVC and MPEG-2
* Built-in tuners for both satellite TV (DVB-S/DVB-S2) and terrestrial TV (DVB-T)
* Internal slot system which makes it possible to install an additional tuner card
* 4:3 and 16:9 TV screen format support
* Teletext decoding
* Dual Common Interface slots for use with pay-TV channels
* PVR functionality with hard disk
* Possibilities to store recordings on an external DVD recorder connected with USB2
* DiSEqC 1.2 support for controlling LNB and motorised dish
* Remote control as standard and a wireless remote keyboard as accessories
* Channel selection by typing the name (or the beginning of the name) of the channel on the keyboard
* View images from a digital camera connected to the LyngBox
* Can store up to 50000 channels
Interfaces
* DVB-S2 input
* DVB-T input + output (pass-through)
* Expansion slot for additional tuner card
* 2 Common Interface slots
* HDMI-output.
* Component output
* Composite output
* SCART output (RGB and composite)
* S/PDIF optical output with AC-3 support
* Stereo audio (2 RCA)
* 4 USB 2.0 ports
* Ethernet connection (100BaseT)
Hardware Specifications
* Size (WxHxD): AxBxC cm
* STi7100 CPU (three cores: 1x266 MHz, 2x400 MHz)
* 96 MB System Memory
* 160 GB Hard Disk
* OLED front panel display
Пока на него нет эму --нет!
Как появится -да!
Всё зависит от того заинтерессуются ли ним авторы эмуляторов..
Список тюнеров широк с линуксом..но ...
То есть огласите весь список? Вот он:
1. ABCOM IPBox 900HD, PVR, 1x CI, USB - Preis ca. 430? - Linux
2. ABCOM IPBox 9000HD, PVR, 2x CI, USB, LAN - Preis ca. 550? - Linux
3. Arion AF-4000 HDCI, 2x CI - Preis ca. 390?
4. Arion AF-8000 HDCI, 2x CI - Preis ca. 290?
5. AzBox HD, 1x CI, USB, LAN - Preis ca. 310? - Linux - noch nicht lieferbar
6. Chess HD, 1x CR, 2x CI - Preis ca. 230? - EMU, AU?
7. ClarkeTech 5000 HD, PVR, 2x CI, 1x CR, USB - Preis ca. 295?/Combo ca. 360? – EMU, AU
8. Comag HD-S CI 100, 1x CI, USB - Preis ca. 180?
9. DGStation Cuberevo, 2x CI, LAN, USB - Preis ca. k.a. - Linux - noch nicht lieferbar
10. Dreambox DM 8000, PVR, 4x CI, 2xCR, USB, LAN, DVI, DVD(Optional) - Preis ca. 800? - Linux - noch nicht lieferbar
11. Edison Argus HD, 2x CR, 2x CI, LAN, USB - Preis ca. k.a. - noch nicht lieferbar
12. EZ-BOX 8000 HDTV, PVR, 2x CI, USB - Preis ca. 470? - Linux
13. Eycos HD S 80.12 CI, PVR, 2x CI, USB - Preis ca. 450? - EMU, AU?
14. Fortec Star PASSION HD, 2x CI, USB - Preis ca. 220?
15. Ferguson HF-8800 HD, 2x CI, 1x CR - Preis ca. 290? – EMU, AU
16. Ferguson HF-8900 HD, PVR, 2x CI, 1x CR, USB - Preis ca. 310? – EMU, AU
17. Golden Interstar Xpeed, 2x CI, USB - Preis ca. k.a. - noch nicht lieferbar
18. Grundig DSR 8770 HDTV, ?? - Preis ca. 300? - noch nicht lieferbar
19. Humax PR HD 1000S, 2x CI, Premiere zertifiziert - Preis ca. 205?
20. Humax HDCI 2000, 2x CI - Preis ca. 210?
21. Humax PR-HD3000 / HD5000 ?? - Preis ca. k.a. - noch nicht lieferbar
22. Humax HDR-5000, PVR, 2x CI, USB - - Preis ca. k.a. - noch nicht lieferbar
23. Humax iCord HD/Entavio, PVR, 2x CI, USB, LAN - Preis ca. 470? (160GB HDD) - Linux
24. He@d SD 8100, 2x CR, 2x CI - Preis ca. 290?
25. He@d SD 8500 Black Panther, PVR, 1x CR, 2x CI, USB - Preis ca. 300? - noch nicht lieferbar
26. Homecast HS 5001, 2x CI - Preis ca. 170?
27. Homecast HS 5101CI, 2x CI - Preis ca. 265?
28. Homecast HS 8100 CIPVR, PVR, 2x CI, USB - Preis ca. 500? (250GB HDD)
29. Inverto IDL 5520 - Scena 5, 2x CI, USB, LAN - Preis ca. k.a.
30. Inverto IDL 8000 HD, PVR, 2x CI - Preis ca. k.a. - noch nicht lieferbar
31. Jepssen PVR-S2 HD, PVR, 2x CI, USB - Preis ca. 300? - noch nicht lieferbar
32. Kathrein UFS910, 2x CI, USB, LAN - Preis ca. 285? – EMU, AU - Linux
33. Kathrein UFS 901, 1x CI, Premiere zertifiziert - Preis ca. 200?
34. Kaon KSC 660 HD, 2x CI, USB - Preis ca. 280?
35. Kaonmedia KFC-G2 NS, PVR, USB, LAN - Preis ca. k.a. - noch nicht Lieferbar
36. Kaonmedia K-660HD, USB - Preis ca. k.a. - noch nicht lieferbar
37. Lyngbox, PVR, 2x CI, USB, LAN - Preis ca. k.a. - Linux
38. Macrosystem Enterprise HD, PVR, 2x CI, USB, VGA, DVI - Preis ca. 1.400? (250GB HDD) - zur Zeit nicht lieferbar
39. Opensat X9000HDCI, 2x CI, 1x CR - Preis ca. k.a. - noch nicht lieferbar
40. OPTICUM 7700 HD CICX, 1x CR, 2x CI - Preis ca. 300? EMU, AU?
41. Pace DS 810 KP, 1x CI, 1x CR, USB, Premiere zertifiziert - Preis ca. 170?
42. Pace DS 810 XE, 1x CI, USB - Preis ca. 110?
43. Philips DSR 9004, 1x CR, 1X CI, Premiere zertifiziert - Preis ca. 750?/incl. Abo 24Monate
44. Philips DSR 9005, 1x CR, 1x CI, USB, Premiere zertifiziert - Preis ca. 200?
45. Reelbox Lite (mit Reel Extension HD), PVR, 2x CI, 1x CR, LAN, DVD - Preis ca. 700? + ca. 200? f. Extension HD-Card EMU, AU - Linux
46. Reelbox Avantgarde, PVR, 3x CI, 1x CR, 2x LAN, DVD-RW - Preis ca. 1470? EMU, AU - Linux
47. Smart MX 96, 1x CI - Preis ca. 230?
48. Smart MX 95, 1x CR - Preis ca. 160? - kann nur MPEG2
49. Skyplus HD 2000, 1x CR, 2x CI - Preis ca. 270? -noch nicht lieferbar
50. Sonavis One, PVR, CR, LAN, USB, DVI, VGA, Firewire - Preis ca. k.a. - noch nicht lieferbar
51. Technisat Digicorder HD S2, PVR, 2x CI, USB - Preis ca. 500? (160GB HDD)
52. Technomate TM-6800, 1x CR, 2xCI, PVR, USB - Preis ca. 410? EMU, AU?
53. Technomate TM-6900, 1x CR, 2xCI, PVR, USB - Preis ca. k.a. - noch nicht lieferbar
54. Telestar HDS 1, 1xCI, LAN, VGA - Preis ca. 270?
55. Topfield TF 7700 HSCI, 2x CI, USB - Preis ca. 235?
56. Topfield TF 7700 HD PVR (Twin-Tuner), 2x CI, USB - Preis ca. 540?
57. Topfield TF 7710 HSCI, 2xCI, USB - Preis ca. 300?
58. Thomson Sky HD Box, 2x CI, USB, LAN - Preis ca. k.a. - nicht in Deutschland lieferbar
59. Vantage HD 6000S, PVR, 2x CI, 2x CR, USB - Preis ca. 300? - noch nicht lieferbar
60. Vantage HD 7100S, PVR, 2x CI, 2x CR, LAN, USB - Preis ca. 400?
61. Quali-TV QS1080IR, VGA, DVI - Preis ca. k.a. - nicht mehr lieferbar
62. Zenith HDTV-Box, PVR, ?x CI, USB, LAN, DVD-RW - Preis ca. 700? - noch nicht lieferbar ca. I/2008
63. Zinwell ZDX-410HD - Preis ca. 625?
Если оставить в стороне Kathrein UFS910, более интересны под номерами: 1/2/23/45/46.
Конечно стоит ждать появления на продаже и этих: 5/9/10/37.
ждать не когда появится вообще тюнер с LAN и Linux, а именно ЭМУ!!
Как только услышите-можете покупать..
valdis1974
Ну скорее всего за Ip-box 9000hd возьмутся быстрее и посерьезнее чем как с катрейн!
Кому что!На всяк товар есть свой покупатель..цена играет тоже роль..
Как только тюнер станет интересным -на форуме естественно откроется и соответствующий подраздел..это очевидно..
