Не получается запустить WiFi DM8000
Тема в разделе "Dreambox 800/8000", создана пользователем maniak, 24 дек 2009.
Метки:
  1. maniak
    maniak Пользователь
    4 мар 2009
    30
    10
    Приветствую.
    Помогите запустить wlan.
    Имидж -- Gemini 4.5.0.
    root@dm8000:~# ifconfig -a
    eth0 Link encap:Ethernet HWaddr 00:09:34:1C:1F:65
    <skip>
    lo Link encap:Local Loopback
    <skip>
    root@dm8000:~# iwconfig
    eth0 no wireless extensions.
    lo no wireless extensions.
    root@dm8000:~# wlanconfig ath0 create wlandev wifi0
    wlanconfig: ioctl: No such device
    root@dm8000:~# lsmod|sort
    Module Size Used by Tainted: P
    alps_bsbe1 6656 1 bcm7400, Live 0xc0107000
    alps_bsbe1_c01a 20736 1 bcm7400, Live 0xc010c000
    alps_bsbe2 45376 1 bcm7400, Live 0xc018d000
    ath_hal 284192 3 ath_rate_minstrel,ath_rate_sample,ath_pci, Live 0xc0512000
    ath_pci 209968 0 - Live 0xc0493000
    ath_rate_amrr 7248 0 - Live 0xc0397000
    ath_rate_minstrel 14912 0 - Live 0xc039a000
    ath_rate_onoe 6544 0 - Live 0xc037e000
    ath_rate_sample 15424 0 - Live 0xc0381000
    autofs4 17744 0 - Live 0xc0073000
    bcm4501 57424 1 bcm7400, Live 0xc0160000
    bcm4506 80336 1 bcm7400, Live 0xc0178000
    bcm7400 3599280 32 - Live 0xc0608000
    cdrom 43104 2 ide_cd,sr_mod, Live 0xc00a8000
    cifs 228112 0 - Live 0xc0127000
    cu1216mk3 9472 1 bcm7400, Live 0xc0113000
    dreambox_keyboard 5296 0 - Live 0xc00fd000
    dreambox_rc2 5424 1 dreambox_keyboard, Live 0xc00fa000
    fat 54768 1 vfat, Live 0xc00b4000
    fp 13088 4 bcm7400,lcd, Live 0xc007a000
    fpga 287184 1 bcm7400, Live 0xc01ee000
    ide_cd 42512 1 - Live 0xc00c3000
    isofs 26448 1 - Live 0xc00a0000
    lcd 21600 2 - Live 0xc0091000
    lnb_ctrl 6912 5 alps_bsbe2,alps_bsbe1,bcm4501,bcm4506,alps_bsbe1_c01a, Live 0xc0100000
    max4397 4288 1 bcm7400, Live 0xc00d2000
    rt73 303152 0 - Live 0xc0573000
    sd_mod 15504 0 - Live 0xc007f000
    sr_mod 16496 0 - Live 0xc0098000
    stb_core 47600 12 bcm7400,cu1216mk3,alps_bsbe2,bcm4501,bcm4506,alps_bsbe1_c01a,lnb_ctrl,dreambox_keyboard,dreambox_rc2,fp, Live 0xc0084000
    stv0299 11536 1 alps_bsbe1, Live 0xc0103000
    tu1216 45008 1 bcm7400, Live 0xc019a000
    vfat 12224 0 - Live 0xc00d5000
    wlan 256176 11 ath_rate_amrr,wlan_acl,wlan_ccmp,wlan_scan_ap,wlan_scan_sta,ath_rate_minstrel,ath_rate_onoe,ath_rate_sample,wlan_wep,wlan_xauth,ath_pci, Live 0xc03b9000
    wlan_acl 4736 0 - Live 0xc038a000
    wlan_ccmp 8832 0 - Live 0xc03a4000
    wlan_scan_ap 8448 0 - Live 0xc0393000
    wlan_scan_sta 13824 0 - Live 0xc039f000
    wlan_wep 6144 0 - Live 0xc00cf000
    wlan_xauth 1408 0 - Live 0xc0364000
    zd1211b 421792 0 - Live 0xc09f7000
    Чего не хватает что-бы оно заработало ?
  2. gsmteam
    gsmteam Любитель Сат-ТВ
    14 июл 2006
    73
    42
    Установи из блю панели - addons-updates-Wlan-fix
  3. urasik2
    urasik2 Новичок
    5 янв 2010
    3
    0
    У меня тоже такая же проблема,стоитG4.6,даже не включается ,настройки все выставляю пароль и т.д. Помогите,что делаю не так.В аддонах ничего не нашел на тему wi-fi.
  4. urasik2
    urasik2 Новичок
    5 янв 2010
    3
    0
    Всё заработало,поставил обратноG4.5 и всё гут!
  5. KIV-62
    KIV-62 Профи в Сат-ТВ
    15 дек 2009
    724
    660
    У меня были те же проблемы на Gemini 4.6,
    прошился ради спортивного интереса,а эту
    проблему так и не решил,но если чесно то
    сильно и не напрягался,так как перепробовал
    всё что есть на Dreambox 8000 и отановился
    на Oozon,всё работает стабильно,но эмуляторы
    надо устанавливать ручками.
    Так что любая проблема решается,а каким
    образом,каждый решает сам.
    sat.evo нравится это.
  6. urasik2
    urasik2 Новичок
    5 янв 2010
    3
    0
    KIV-62, а как работает wi-fi на Oozone? и офф.карта триколор?И есть ли PIP в этом имедже?
  7. KIV-62
    15 дек 2009
    724
    660
    Начну с конца,PIP есть в любой прошивке,
    с wi-fi проблем нет,за два месяца ни разу
    не отвалилась,с триколором не связуюсь
    принципиально,но карта работает на
    CCam 2.1.3.
  8. umter
    umter Новичок
    18 окт 2006
    26
    1
    Привет всем, кто подскажит на каком имедже уже стоят дрова на стик dwa125?
  9. ostapchikyra
    ostapchikyra Новичок
    7 окт 2010
    1
    0
    Помогите сделать связку DM800 и D-Link DWA-140 вроде все по описанию делаю:
    Скопировал дрова у меня версия 1.50
    Установил все файлы по путям:
    \lib\modules\2.6.12-5.1-brcmstb-dm800\kernel\drivers\net\rt2870sta.ko
    \lib\firmware\rt2870.bin
    \etc\Wireless\RT2870STA\RT2870STA.dat
    Попытался загрузить командой modprobe rt2870sta
    root@dm800:~# modprobe rt2870sta
    modprobe: module rt2870sta not found.
    modprobe: failed to load module rt2870sta
    root@dm800:~#
    Проверил наличие файлов и пути, все на своих местах
    И как узнать кокой у меня образ стоит?
  10. Vlad-nx
    Vlad-nx Новичок
    28 май 2009
    4
    0
    Аналогичная проблема у меня.Стоит Gemini 5.0.Кто нибудь поборол?
  11. Djazz
    Djazz Профи в Сат-ТВ
    20 сен 2006
    226
    66
    пишите какие девайсы по wi-fi тулите, что угодно не прикрутиш
  12. Vivaldio
    Vivaldio Новичок
    5 июл 2011
    3
    0
    Здравствуте счастливые пользователи Дримбоксов!
    Скажите пожалуйста, есть ли у меня шансы смотреть каналы на втором тюнере вовремя записи на первом. Если есть, то буду признателен за конструктивную помощь.
    DM8000HD PVR, HTB+, SMIT DUAL CAM VIACCESS, GEMINI2-510.
    Заранее благодарен. Олег
Поделиться этой страницей
