NEU V10909 : OCTAGON_SF1018_HD_ALLIANCE_V10909__19_05_11
Changes :
- Upgrades & Imporvements :
--> NTFS Dateisystem Support add.
--> Storage EPG Data to HDD add.
--> Storage during Power OFF
--> storage/HDD/epg.txt
--> Separate Storage configuration add.
--> config.fdu - root/var/etc
--> SmartCard reader driver update
--> Satellite & Transponder Data update
--> New OSD Menu Language add. : thai
--> Translation misstakes for following OSD Languages modify :
--> german, czech and slowak
--> Div. minor bugs fixed for stability
--> Build Version 4943
Wichtig: Pls stop before SW Download Plugin`s from Plugin MENU !
Please make after SW update Factory Reset (System Recovery) !
Plugin : it can check ntfs file system with HDD which is formatted as ntfs system
you can download it into USB memory (plugin/bin/ntfsck)
Or copy via FTP ntfsck to root/var/bin
this 'ntfsck' doesn't need to change 'State' and 'Start Type'
Online SW upgrade : octagon-germany.de
OCTAGON SF1018 HD ALLIANCE
OCTAGON SF1008 SE HD INTELLIGENCE
OCTAGON SF1008 HD INTELLIGENCE
Обсуждение.
Changes :
Обсуждение.
