Neutrino by BPanther.
GIT-rev255
Changes:
- Due to changes in the GIT is currently no FB queries possible. Erstmal so I had to remove the scripts, which use a FB-query, until I find another way. A new menu is now active and should be explained by itself. However, transferring a small hint: After the neutrino programs must be restarted once (Menu> Services) so that they can be recognized and enabled.
- Alternative tuner driver disabled. If you want to use it, rename it to / var / lib-misc cx24116.k_ in cx24116.ko the file and start the box again.
- Due to the FB-query problems must, unfortunately, the file / var / etc / automount.conf now be adjusted manually to the HDD to be able to mount automatically at startup. A "is live mount" this also is no longer possible.
Download in sat-universe
Совсем свежии.
