Demaximos
shuricel,
Y menia toze vkliychenu. Ja dymal mozet but est vozmoznost sovmestnoi rabotu.
A smusl v tom shtobu mozno bulo prosto i krasivo s sharokanala prugnyt Mcas bez tormozenia Mgcamd. Ili eto yze slishkom?
Demaximos, пользуйся кнопкой транслит !!!
shuricel
OctaCAM MCAS EMU 12.04.2010 - SF1018
- Canal+ NL EMU fix. (Ird2, Astra19.2E)
- Bulsatcom EMU fix. (ird2, Hellas Sat 39E)
- Nagra MCAS fix.
- NOVA CY (zypern) EMU add. IRD2 (Hotbird 13 ost /east)
12.April 2010
Koreets08
octaCAM__MCAS_EMU__12042010 ( SF1008 & SF1018 )
--> http://www.lyngsat.com/packages/canaldigitaal19.html
--> http://www.lyngsat.com/packages/bulsatcom.html
- Nagra MCAS fix.
- NOVA CY (zypern) EMU add. IRD2 (Hotbird 13 ost /east) 10.April !
--> http://www.lyngsat.com/packages/nova.html
- Wichtig :
--> bestehende Plugin Nutzerdaten Formatieren (Grьne Taste) Software Download Fenster !
- Important :
--> existing Plugin Format User Data (Green Button) User Data Download !
12.April 2010
  • octaCAM__MCAS_EMU__12042010.rar
    739,7 KB · Просмотры: 8
shuricel
OctaCAM__MCAS_EMU__13042010 - SF10x8
OctaCAM MCAS EMU 13042010 - SF10x8
- keydata.tmp bug fix. (Überschreiben, overwriting)
- Caid 0604 fix. im MCAS
- NOVA CY EMU fix. (keydata.tmp siehe unten !)
13.April 2010
Keydata OctaCAM MCAS EMU 13042010 - SF10x8
- keyfile for octaCAM MCAS EMU Plugin
- pls copy in /var folder
- firstly Stop Mcas in Plugin Menu with green Button
History :
- fix. NOVA CY 08 new key
13.April 2010
  • octaCAM__MCAS_EMU__13042010.rar
    740 KB · Просмотры: 18
  • Keydata_octaCAM_MCAS_EMU_13042010.rar
    4,6 KB · Просмотры: 18
shuricel
AutoUpdate_octaCAM-Mcas_keydata_SF10x8_HD
- Online update for keydata.tmp keyfile
- Stop cas in PLugin Menu
- copy AutoUpdateMcas in /var/bin folder
- Mas Start
- keydata.tmp keyfile upgrad Online auto.
18.April 2010
octagon.gmc.to
  • AutoUpdate_octaCAM-Mcas_keydata_SF10x8_HD.rar
    739 байт · Просмотры: 14
shuricel
OctaCAM CS CCcam Multi 29042010 SF10x8
- Sky HD problem fix.
- update : xcamclient, xcamconfigure & cardclient cfg
- Recording PaTv OK
- Ch zapping time HD to HD less 3 Sec.
- Ch zapping time SD to SD less 2 Sekunden.
- 2 REC. with 1 C line OK (but 2 C lines more better solution)
- Decoding REC ch. in PIP OK (Picture in Picture)
- Sky HD tets on CCCam Server 2011 212 214
- Big thanks to koivo !
- Important :
Support : CCcam, aroureos, radegast, camd33, camd35, cardd, buffy, newcamd, gbox
29.April 2010
  • octaCAM__CS_CCcam_Multi__29042010.rar
    197,5 KB · Просмотры: 16
shuricel
OctaCAM MCAS EMU 12052010 ( SF1008 & SF1018 )
- TV Globo AU fix. (Hotbird 13E)
- SC Treiber fix.
12.Mai 2010
  • octaCAM__MCAS_EMU__12052010.rar
    748,4 KB · Просмотры: 6
shuricel
OctaCAM CS CCcam Multi SF10x8 (13.05.2010)
- Recording problem fix when Playback
- Stability improved
- XcamConfigure update
13.Mai 2010
Источник: octagon.gmc.to
  • octaCAM__CS_CCcam_Multi__13052010.rar
    198,2 KB · Просмотры: 9
shuricel
OctaCAM MCAS EMU 14.05.2010 - SF1018
- Keditor update
--> Plugin Menu : Keditor start with green Button & RESET keys with Blue Button
- DigiTv Au improved (Thor 0.8W)
- RAI AU fix. (Hotbird 13E)
--> Wait arround 1 hour auf Rai channel !
- SC Treiber fix.
14.Mai 2010
  • octaCAM__MCAS_EMU__14052010.rar
    758 KB · Просмотры: 8
shuricel
octaCAM__CS_CCcam_Multi__18052010 - SF1018
- Freezing CH except SkyHD correct.
- Auto Start problem fixed
- Playback problem fixed
- XcamClient new built
18.Mai 2010
  • octaCAM__CS_CCcam_Multi__18052010.rar
    198,4 KB · Просмотры: 35
shuricel
OctaCAM MCAS EMU 24.05.2010 ( SF1008 & SF1018 )
- HD+ ECM fix.
- TNTSAT ECM fix.
  • octaCAM__MCAS_EMU__24052010.rar
    749 KB · Просмотры: 6
shuricel
ОctaCAM MCAS EMU 02.06.2010 ( SF1008 & SF1018 )
- NDX Algo bug fix.
- Sky Italia bug fix.
02.Juni 2010
  • OctaCAM MCAS EMU 02.06.2010.rar
    748,8 KB · Просмотры: 2
shuricel
OctaCAM MCAS EMU 03.06.2010 ( SF1008 & SF1018 )
- Mcas: исправлены незначительные ошибки.
- Keditor: исправлена ошибка зависания.
03.Juni 2010
  • OctaCAM MCAS EMU 03.06.2010.rar
    756,3 KB · Просмотры: 11
samuraj1
Подскажите MCas апдейтит карты 023700 и 040600, если Да то на каком ПО для 1018. Заранее спасибо за ответ.
Evdok
Модератор "Octagon"
Вот здесь у коллег результаты тестирования этого картсервера.
samuraj1
Спасибо, прочитал. Тогда какими средствами, кроме встроенного картридера можно апдейтить и расшарить карты 0237 и 0406, при этом чтобы работал Biss. И можно ли это сделать без переключения на разные варианты, чтобы все работало на одной связке.
Evdok
Модератор "Octagon"
Так ведь коллеги пишут, что на этом все вроде проходит?
В принципе, есть еще один эмулятор-картридер, который теоретически это может. Просто у нас практически нет владельцев этих официалок, в основном шаринг...
samuraj1
Коллегам этот вопрос тоже задан, но там форум немного специфический, хоть и ближе мне территориально. Ответ неопределенный. У меня на сегодняшний день есть любые карты и 0237 и 0406, и ни одна из них на NewCS и OScam не хочет продлевать подписку на 1018. На DM800 и тот, и другой ЭМУ справляется нормально. Поэтому и спрашиваю совета. Хотел узнать может есть варианты??? С уважением...
Evdok
Модератор "Octagon"
Вот здесь и здесь у нас отметились люди с официалками, можно них спросить в личке
