shuricel
octaCAM__MCAS_EMU_MCLIENT__05042011 (SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P)
[HIDE-POSTS=10]- update : Mcas
--> Conax CA OSD Menu extended
--> SmartCard INFO`s extended (Event Status & subscription status)
--> Cryptoworks bug fix.
--> Irdeto update
--> Conax update
--> NDS update
--> Plugin API V1.07 (V10894) !
[/HIDE]
shuricel
octaCAM__MCAS_EMU_MCLIENT__15042011 (SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P)
[HIDE-POSTS=10]- update : Mcas, Mclient and Coconut
--> Mcas & Mclient bug fix.
--> NDS + Nagravision bug fix.
--> ECM bug fix.
--> OSD Menu bug fix.
--> Memory leak bug fix.
--> Add verify routine after key set (coconut)
--> Homeshare protocol with Mclient improved
octaCAM__MCAS_EMU_MCLIENT[/HIDE]
octaCAM__CS_CCcam_Multi__04052011 - SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P
shuricel
octaCAM__MCAS_EMU_MCLIENT__16052011 - SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P
--> NDS imporved
--> AstroTV support add. (Measat3 91.5°E)
--> SmartCard update problem fix.
--> EMM bug fix.
--> ECM filter bug fix.
--> PMT bug fix.
--> APT & CAT bug fix.
--> Driver update
shuricel
octaCAM__CS_CCcam_Multi__20052011 (SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P)
[HIDE-POSTS=10]- update : XcamClient & XcamConfigure
--> security check error problem fixed
octaCAM__CS_CCcam_Multi[/HIDE]
shuricel
octaCAM__MCAS_EMU_MCLIENT__20052011 (SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P)
octaCAM__MCAS_EMU_MCLIENT__17062011 (SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P)
[HIDE-POSTS=5]- update : Mcas , keydata.tmp
--> NDX V3 + V5 support fix.
--> Reset sequence funktion eingabut
--> Mcas - Configuration :
--> Reset sequence : T1 --> T14 / T14 --> T1
--> keydata.tmp aktualisiert
[/HIDE]
AnatolyMilyaev
не получается запустить обновленную офкарту нтв+ на 1008SE...
MCAS от25042011 ее в упор не видит...
как определить в чем проблемм???
shuricel
octaCAM__MCAS_EMU_MCLIENT__28062011 - SF1008, SF1008SE, SF1008SE+, SF1018, SF1028P
AnatolyMilyaev
попробовал и нет изменений. может в конфигах надо что поменять и такой вопрос - на каком канале и сколько времени делается апдейт новой офкарты???
Попробуй поставь Oscam и попробуй на нем карту. Я картами не пользуюсь сказать не могу конкретно на чем работает карта.
AnatolyMilyaev
спасибо spartak73. кого побеспокоить из местных знатоков на счет офкарты? какая то это кривая здесь тема.... неужели никому не надо чтобы при отвале инета автоматом читалась официалка хотябы лайт с эфирными каналами???
и еще дилетантский вопрос в плаге мкас три плагина мкас сосонут и еще чтото - это зачем???
Coconut это плагин для бисс каналов. Своего рода редактор ключей. Mcas как уже говорилось это эмулятор и плагин для картоприемника, Mclient это плагин для шары.
Evdok
Модератор "Octagon"
Да дело в том, со временем количество обладателей официалок здесь приблизилось к нулю (по понятным причинам). Есть у меня в загашнике Триколоровская карта, и мучался я вначале теми же вопросами - автоматического переключения на карту при отвале интернета. Пробовал разные эмуляторы и т.д., шаманил с настройками... Но, как оказалось, проще было добиться стабильного качественного инета. Знаю, что у людей даже через мобильный инет (модем или сотовый телефон) шаринг работает без проблем.
Тем более, на западе эмуляторы затачивают под своих провайдеров и не всегда наши интересы совпадают.
А так - мкас один из лучших по работе с официалками плагин. Правда, поступали жалобы, что не все наши карты он апдейтит, и нужен модуль.
При его установке действительно появляются три плагина (приложения), два ненужных можно удалить (чем меньше чего-то запихано в ресивер, тем он шустрее и безглючнее работает). Обновиться можно попробовать через меню Плагины, синяя кнопка - вполне возможно, что новые версии этого эмулятора будут там.
AnatolyMilyaev
спасибо Evdok! то есть на сегодня ситуация с официалками почти нулевая. никому не надо и никто не парится. но с шарой дело не в интернет канале - он то как раз гут - выделенка. проблема в другом - шара сервер может не ответить, а тюнер спросит следующий код только секунд через десять. как результат - на экране бан на эти 10 сеунд с надписью нет прав на карте - не очень то и приятно. может увеличить в настройках количество запросов шары? но тогда шара сервер забанит....
по поводу последнего мкаса - проверено - не работает с обновленной офкартой нтв - видать сначала ее надо проапдэйтить на правильном тюнере...
по синей кнопке в плагинах - это же их удаление....
У тебя какая версия софта? На последней версии 10920 добавлена функция скачивания плагинов с сервера. Обнови свой софт.
AnatolyMilyaev
cофтина в 1008се 1.08.52 софт мкас последний автоапдейт мкас с октагонфан работает и в качестве результата - канал закодирован.
