OCTAGON_SF1018_HD_ALLIANCE_V10837__26_08_10
for Octagon HD SF 1018 HDTV - ALLIANCE :
Changes :
- Stability on Main SW improved
- Hang-up during long time recording - Fixed
- Hang-up during receiving EPG data - Fixed
- BlindScan function improved :
--> H/V control problem fix.
--> hang-up fix.
- Missing some TP in Auto Scan - Fixed
- German language error - Fixed
- Alarm message appears if storage capacity is not enough for the recording - Improved
- Playback problem of Radio channel recordings - Fixed
- Resolution problem at Zapping Mode Freeze and Resolution Auto mode - Fixed
- PMT File Update/Delete error fix.
- Unicable function - Improved
--> Improtant : Kathrein ESU33 Wall Socket Timing Adjustment will fix by coming SW
--> for Unicable-Protection (Turn off 18V after 400ms)
- Video error at the beginning of PIP - Fixed
- Incorrect PMT data filtering - Fixed
- Incorrect time information during EPG Event Search - Fixed
- Error if pressing Power button during recording - Fixed
- Showing current resolution when you change the resolution to above 576i in PAL TV - Improved
- Timeshift playback function - Improved
- Hang-up when recording multifeed service - Fixed
- Not able to change Audio track of a recording - Fixed
- Saveing the default (wifi-ethernet) configuration in Network Setting - Improved
- Time information of recordings shows the starting time of program - Modified
- User font (font - ttf file) Download via USB Stick add. + improved
--> create font folder and copy to USB Stick
--> Connect USB Stick to STB
--> Menu - System Setup - Data Transfer : Data download from USB Storage or
--> Software Download popup OSD : With left/right Cursor Buttons font folder finding
--> Red Button Download
--> User Font File setup Menu - Configuration - Language Setting
- MHW-EPG exit error - Fixed
- Auto. Timeshift when recording is done (stop) even though Timeshift start setting is Manual - Fixed
- Error in front LED of 430mm twin tunner model - Fixed (SF1018)
- MDU LNB Setup modified & improved (only for Digitürk Provider - Eutelsat 7°E)
- Boot procedure modified : HDD Check & Start1 improved
- Front Button Brightness Function fix.
- censorship add. & fix. by parental control
--> Menu - Configuration - Parental Control :
--> Censorship No Block, 4, 6, 8, 10, 12, 15, 18
- Online Firmware Upgrade URL fix. oud.gmc.to
--> Menu - Installation - Netzwork Setting : Firmware Upgrade Server
- Weekly day showing by EPG (left topside) EPG Quick info
- SAT & TP Data update
Online SW upgrade : oud.gmc.to
ОБСУЖДЕНИЕ
Файловый архив.
Changes :
--> hang-up fix.
ОБСУЖДЕНИЕ
Файловый архив.
