OCTAGON_SF1028P_HD_NOBLENCE_V10867__13_12_10
Changes :
- First Realese for OCTAGON SF1028P HD Noblence
- Menu OSD UI & Plugin(s) same like SF1008, SF1008SE and SF1018
Note : YouTube and Internet-Browser preinstalled !
Online SW upgrade : octagon-germany.de
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate : (Pls use Octacam Mcas Plugin)
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1028
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2 + USB3...) !
--> Also can use Samba and FileZila Program !
13 December 2010
Firmware SF 1028P HD v1.08.67
Changes :
13 December 2010
