OCTAGON_SF1028P_HD_NOBLENCE_V10887__18_02_11
for Octagon HD SF 1028P HDTV - NOBLENCE :
Changes :
- Upgrades & Imporvements :
--> NEW : NTFS Filesystem support add.
--> Please format the HDD & USB (storage) by the STB Menu
--> More NTFS Filesystem functions will add. soon by coming SW versions
--> Tuner Status (T1 & T2) by FAV & SAT Menu add.
--> Pls. press FAV Button on Live TV Mode
--> Audio problem on Turksat42E fix.
--> Rumeli TV Sync. problem fix.
--> Stopping symptoms after Divx file Play fix.
--> Fix. End decoding for multimedia file play
--> In USALS menu, supporting to the third decimal place with Longitude & Latitude
--> xxx,xxx°E & N - (USALS DiseqC 1.3)
--> Menu - Installation - Positioner Setting : USALS
--> Dish Longitude & Latitude
--> Wi-Fi USB Devices add. as following :
--> EDUP EP-MS150N, EP-MS150NW
--> Airlink AWLL6075
--> TRENDnet TEW-648UB, TEW-649UB, TEW-624UB rev C1
--> Corega CG-WLUSB2GTST
--> D-Link DWA-131 rev A1, rev C2, rev E1
--> D-link dwa-140 B1,B2
--> Belkin Components F5D8053
--> Linksys wusb100n v1, v2
--> Linksys wusb600n v1, v2
--> Treiber Version update
--> Root File Sytsme Version update
--> Build Version 4354
Firmware_Octagon_SF1028P_HD_NOBLENCE_18.02.2011
Changes :
