bbsc
OpenAZBox PLi MOD HD Prerelease 8 (Latest prerelease version)
OpenAZBox PLi MOD HD image is fully based on OpenPLi 2.1 Enigma 2
Kernel: Linux azboxme 3.5.5
Enigma 2: 22. october 2012
Drivers: 22. october 2012
What is new:
1. All AZBox receivers are now running on Linux kernel 3.5.5 , Me, MiniMe, Premium, Elite, Premium+ and Ultra HD.
2. Blindscan support for all models including AZBox Me, MiniMe (AVL2108 & AVL6211), Premium+ and Ultra.
3. AZPlay is official media player, and now is a part of Open AZBox MOD Image for Me, MiniMe, Elite, Premium, Premium+, Ultra HD.
4. Enhanced Card Reader functionality, especially on AZBox MiniMe (For MiniMe you can now manage clock frequency of card reader directly from RTi Sys which is part of Open AZBox MOD Image).
In first Release will be included:
- USB DVB-T Support (Drivers and support for USB DVB-T Tuners are already on Menu->Plugins->Download). All DVB USB Tuners are visible under Enigma 2. So if You have supported USB DVB Tuner you can install support for it, and Your tuner will be visible under Menu->Information->About. For now just is left that we connect all with main driver, this will come in max. 10 days.
- 3G Modem support with control directly from kernel space. This reflect better stability and as result more 3G modems is supported.
To install this image please use AZUp 2.2.7, download link is located below.
Download:
http://www.mediafire.com/download.php?tpls7r725d5n4bk
Download AZUp 2.2.7:
http://www.mediafire.com/?np50n069dgc63qb
Download AZUp 2.2.7 - Setup :
http://www.mediafire.com/?fdovn680o83ca5n
P.S. Похоже, парни немного запутались в нумерации. Реально - Prerelease 8, а не 7.
bbsc
Чего непонятно-то?
Ссылка на источник есть.
Заголовок темы - пререлиз 8.
Файл по ссылке новый, ядро новое, прошивка новая, но называется пререлиз 7.
В тексте источника тоже пререлиз 7.
Путаются ребята в цифрах...
vasol
И не только в цифрах, DISEqC на Premium+ не работает.
bbsc
Да и AzPlayer не особо воспроизводит...
Настроек минимум, размеры видео не регулируются, задержка перед воспроизведением - с полминуты, после выхода из плеера ресивер еле реагирует на переключения каналов...
Откатился.
needz
Ну по этому видео трудно понять, когда он выйдет.
sergik01
Я тоже, честно говоря, не понял, в чём радость?
На форуме RSi такие радостные возгласы. А в чём именно "супер" данного релиза, не понятно.
Одно ясно, что лучше всё-таки подождать версию от RSi, чем использовать имеющююся от RTi. У RSi традиционно лушая реализация медиафункций в Медиацентре.
Так что ждёмс...
oleg75i
У кого премиум+ wi-fi работает, не слетает? У самого элит, у друга прем+ думаю поставить этот имидж.
oleg75i
Жаль, у меня на элите работает без особых нареканий. а что посоветуете на прем+., чтобы и медиацентр более менее работал.
bbsc
oleg75i, если другу не нужно IPTV - ставьте OpenRSI на ядре 2.6, имхо.
Эти прошивки продолжают поддерживаться и обновляться.
Не забудьте, что эти прошивки состоят из ядра (отдельно) и собственно прошивки (отдельно).
Внимательно ознакомьтесь с инструкцией по прошивке.
