oleg75i
Welcome to the next generation of AZBox firmware: OpenRSi.
Since 2010, there has been a lot of development to offer AZBox HD user an alternative firmware. One of the initiatives came from a team called RTi Team.
The team started with the Modified Official Firmware for the AZBox HD models, an improved version of the official OpenSat firmware.
As the firmware of the RTi team became more mature, the group of enthousiasts took the initiative to build an image, mainly for the Dutch and German market.
Those images are known as RSi E2 0.x
As E2 became more populair among AZBox users, RSi took the initiative to build an image, based on the well known OpenPLi community project.
Today, we are on the virtue of releasing our first OpenPLi based images for all AZBox receivers:
AZBox Elite HD, AZBox Premium HD, AZBox Premium HD+, AZBox Ultra HD, AZBox ME and AZBox miniME.
Firmware and Kernel
We would like to point out that we have decided to separate the actual firmware from the E2 kernel. This is why you will find images, as well as kernel files on our downloadpage.
We would like to explicitly thank the RTi Team for there RTi Core development and the OpenPLi team for there community project. Both, as we believe, focused on developing software for open source linux DVB receivers.
the RSi Team
OpenRSi firmware for AZBox Elite/Premium(+)/Ultra
The first OpenRSi image for AZBox HD Elite, Premium(+) and Ultra models are available.
Keep in mind that the image comes without a kernel.
If you need to install the kernel as well if you did not do that already.
You do not need the kernel if you already used previous E2 images.
Image http://openrsi.rsi-images.org/imagefiles/hd/OpenRSI-openpli-2.1-azboxhd-20120312.zip
Kernel http://openrsi.rsi-images.org/kernelfiles/hd/azboxhd-kernel-20120216.zip
bbsc
Очень интересно.
Хотелось бы поиметь OpenPLI на Azbox.
Кто-нибудь пробовал эту прошивку?
khymera
Скажите пожалуиста в какои последовательности ставить прошивку а то там два фаила patch и kernel
willl
Утром деньги - вечером стулья, вечером деньги - утром стулья. А можно наоборот? ... Можно!!!!
bbsc
khymera, на офсайте только что появилась инструкция для Ме, видимо для HD будет в ближайшее время.
klon8us
Поставил на флешку OpenRSi firmware for AZBox Elite/Premium(+)/Ultra - не завелась.
Там 2 файла, ставил AZUp 2.1.6 сначала rescue mode потом установка patch-kernel.e2 потом рестарт загрузился RTi Core v1.7.0 опять rescue mode - установка patch.e2 рестарт и только скин загрузки и тишина.
ЗЫ Решил сверху еще накатить вчерашнюю их сборку (OpenRSI-openpli-2.1-azboxhd-20120312)- и о чудо = завелась
klon8us
А я вот зайти по фтп не могу не то логин сменили не то пас. DreamboxEDIT тоже не пашет по той же причине.
Реакции: molf
oktub
qantrom, Файла действительно сейчас уже нет. Зайди по ссылке "на офсайте" из #5 поста и закладка Downloads там три файла Е2 и один kernel но уже другой . Вчера их было два.
allllex
Устанавливается, как отдельных два имиджа.
Сначала через AzUp 2.1.6 устанавливается ядро с отмеченной опцией Only kenel. Предварительно файл ядра надо переименовать из patch-kernel.e2 в patch.e2
После окончания первого этапа надо опять войти в режим восстановления и установить сам имидж, сняв галку с опции Kopy kernel.
как установить mgcamd эмуль? не смг его осилить
Стандартным образом через меню установки плагинов. Только mgcamd там версии 1.30d. И не забудьте в файле mg_cfg выставить правильно параметр B: { 06 }
Логин - root
Пароль -
Все новмально работает. Проверь свои сетевые настройки. По умолчанию в бокс прописывается адрес 192.168.1.100
bbsc
Пароль пустой. У меня с пустым работал и telnet и ftp.
Верно, но кому свербит - можно заменить после установки на 1.38
Запуск происходит через софтлинк /etc/init.d/softcam, который дальше ссылается на исполняемый скрипт /etc/init.d/softcam.mgcamd, из которого уже запускается сам бинарник /usr/bin/mgcamd
(пишу по памяти, надеюсь, ничего не перепутал)
Всё это вполне поддается редактированию :)
Хинт: opkg install mc установит mc для удобства редактирования ;)
Имидж откатил на 1.7 из-за того, что не подобрал SD-скина.
К сожалению, скин magic, на который я сильно рассчитывал, работает с тормозами и с уменьшенным видеоизображением, почему-то.
Но надежда остается, имидж мне понравился, надеюсь, будет развиваться.
7729gs
Подскажите пожалуста вчём проблема не могу зайти по фтп в азик пишет ошибку FTP1: < 500 OOPS: vsftpd: not found: directory given in 'secure_chroot_dir':/var/empty пробовал через тотал, ДСС295 некак не получается зарание спасибо
bbsc
7729gs, имидж какой?
Обсуждаемый? Или SifTeam Enigma2 Koala?
klon8us
Переставил по предложенной методе. 14 сборка не загрузилась- зеленка, а вот OpenRSI-openpli-2.1-azboxhd-20120313 заработала. Но так же как и в 12 невидит DHCP. При ручном прописывании IP(192 168 1 1) и DNS Servers(10 0 0 41) в тесте пишет nameserver unconfirmed . И как и 12 сборка
Соответственно ничего залить на него неполучается.
klon8us
7729gs,
мне помогло
root@azboxhd:/# ls /var
cache lib lock log run tmp volatile
root@azboxhd:/# cd /var
root@azboxhd:/var# mkdir empty
root@azboxhd:/var# ls /var
cache empty lib lock log run tmp volatile
Тоесть небыло папки empty и пока я не создал - не пускало
leopold75
С паролем они намутили однако. С пустым не пускает по SCP \ FTP зайти.
Оптимально - первый раз зайти с телнета
user root, сделать passwd на типичный azbox
потом коннектиться как угодно - по SCP \ FTP - пускает нормально.
ssh работает. sftp - не хочет.
klon8us
Никак не могу разобраться с mgcamd. Поставил 1.30d. в mg_cfg выставил параметр B: { 06 }закинул файлики шары- тишина. Пробовал другие версии 1,35 1.38 - аналогично. Толкового описания для mgcamd под Е2 не нашел(есть старые лдля ранних версий е2 там еще какоето меню ставить нужно- вцелом еще больше запутался). :(
allllex
Ты должен установить эмулятор с их сервера автоматом. По зеленой кнопке в плагинах. Тогда правильно прописываются все скрипты и пути. Потом можешь поменять 1.30d на любой. Только название эмулятора должно быть mgcamd без всяких дополнений о версии.
Так запусти mgcamd в Меню. Если не запустишь, не заработает.
bbsc
Он вполне нормально работал у меня.
Вот конфиг:
A: { 00 }
B: { 06 }
C: { 01 }
D: { 01 }
E: { 20 }
F: { 00 }
G: { 01 }
H: { 06 }
K: { 03 }
L: { 03 } 192.168.0.5 514
M: { 00 }
N: { 01 }
O: { 00 }
P: { 02 }
Q: { 15 }
R: { 00 }
S: { 00 }
T: { 00 }
U: { 00 }
Остальные конфиги - от шаровода.
